Old May 25, 2013, 04:15 AM
py5rx is offline
Find More Posts by py5rx
py5rx's Avatar
Joined May 2008
Hexacopter - Tarot T680,DJI Naza M+GPS,
Hi,
After done my HT-FPV Quadcopter project I would to have now a better platform to to take photos and use some GoPro Gimbal.
For me the better way to get SUCESS is share and learn with you my experience
=====SETUP=====
Frame: Tarot T680 OK
ESC: Turnigy Multistar 30 Amp Multi-rotor Brushless ESC 2-4S (OPTO) OK
Motor: Turnigy Multistar 4225-610Kv 16Pole Multi-Rotor Outrunner OK
Prop: 12x60 Carbon Fiber OK
Flight Controller: DJI Wookong M+GPS v2.0 OK
Waypoints: DJI iPad Ground Station
Futaba T8J 2.4Ghz OK
Gimbal: Home made Gimbal (To be used with GoPro 3D box)
Gimbal Controler: Alex Mos Brushless Gimbal Elektronics incl. Sensor & Flyduino GBM4006 0.21mm 150 Turns Motor for Alex Mos OK
Battery: 6x TURNIGY 4S 5800mAh 25C OK
AUW will not be more than ą3,280g
Frame:
DJI iPAD Ground Station
Gimbal:
Home made based on this model:
Gimbal Controller:
ESC:
Motor:
Spec:
KV(RPM/V): 610
Lipo cells: 4s
Max Surge Watts(W): 330
Working current: 16 amps
Max.current(10s): 22 amps
No Load Current: 0.3 amps
Intemal Resistance: 0.091 ohm
Number of Poles: 16
Dimensions(Dia.xL): 42 x 24.5 mm
Shaft: 6 mm
Prop: 12 x 3 - 12 x 6
Weight: 86g
Propeller
Battery
eCalc website, do you think the values is correct?
I try to enter more accuracy as can.
4S1P
4S2P (this means 2 lipos 5800mAh connector in parallel right?)
Best regards.
py5rx is offline Find More Posts by py5rx
Old May 25, 2013, 04:45 AM
chuenwe is offline
Find More Posts by chuenwe
chuenwe's Avatar
United States, NY, Huntington Station
Joined May 2012
To change from 4S1P to 4S2P, you have to increase the Model Weight with the add'l battery weight. Roughtly add'l 700g or so.
Another way to use eCalc is to put in the frame weight as the Model Weight and change the "incl. Drive" to not include Drive. And the rest of the calculation will add the motor, the ESC, and the battery weight to the AUW for you.
chuenwe is offline Find More Posts by chuenwe
Old May 25, 2013, 04:59 AM
py5rx is offline
py5rx's Avatar
Joined May 2008
Then I enter 3624g incl. Drive and the flight time decrease from 23.5min to 17.8min
Sounds more real now?
Old May 25, 2013, 10:57 AM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
Yes, It sounds a bit better now.
Usually the Hover flight time won't increase a lot when adding more batteries since the Hovering Throttle usually is at low percentage. When adding more weight, the Hovering Throttle will increase and decreasing hover time.
Old Jun 05, 2013, 04:51 PM
py5rx is offline
py5rx's Avatar
Joined May 2008
Hi,
Frame arrived and pre-mounted. Good quality but the arms is not shine as the body I dunno why, the motors support have a place to fix ESCīs.
I liked the quality of propellers, looks good quality and are good balanced.
Change DJI Naza M GPS to Wookong M GPS flight controller.
Old Jun 15, 2013, 07:25 AM
py5rx is offline
py5rx's Avatar
Joined May 2008
Some photos:
No space to mount electronics inside frame, than will be fixed on top plate.
Old Jun 21, 2013, 01:59 PM
electrik77 is offline
Find More Posts by electrik77
Joined Jun 2012
Hello py5rx, can put real image engine Turnigy Multistar 4225-610Kv 16Pole, I have understood that the image is not real in HobbyKing. I'm putting together a hexa Tarot FY680 and I opt for the 4225-610Kv Turnigy Multistar or HP2814-810KV of rctimer. Many thanks
electrik77 is offline Find More Posts by electrik77
Old Jun 21, 2013, 05:09 PM
py5rx is offline
py5rx's Avatar
Joined May 2008
Hello electrik77,
Motors not arrived yet, I will post photos soon they arrive.
Old Jun 21, 2013, 05:41 PM
Joined Jun 2012
Originally Posted by py5rx View Post
Hello electrik77,
Ok, thanks!!!
Old Jun 21, 2013, 05:52 PM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
Some photos:
move your flight controller to where your PMU is but on the other side align with IMU by the orange bar and put the battery plate on to protect your electoric. If you crash there goes your flight controller. Move your gps more to the front it right on top of the IMU is not a good idea and dont have any wire crossing your antenna Rx. Using the screw that hold the boom clamp to hold your gps is not an idea and have locktite on them when you fly zip tide the boom dont let the plastic clamp hold by itseft. have fun
Askyvision is offline Find More Posts by Askyvision
Old Jun 21, 2013, 05:59 PM
Joined Jun 2012
Right, and the direction of the gps is erroneous, the cable goes forward I have understood
Old Jun 21, 2013, 06:07 PM
Albuquerque USA
Joined Dec 2012
well maybe i havent finish yet but posting a picture unfinish could be misslead to some newcomer when the look for help. These picture will sure crash the copter when it in gps
Old Jun 21, 2013, 10:32 PM
ebaydan777 is offline
Find More Posts by ebaydan777
Joined Jun 2013
why are people running such large props on these units? I'm looking to get the fy680 and am wanting to run 1147 rctimer CF props, with these motors: http://www.foxtechfpv.com/sunnysky-v...tor-p-860.html
and 40A Plush ESC's with about 5000mah battery maybe more if I want to get 15 minutes of flight (also adding a gimble and ardupilot)
ebaydan777 is offline Find More Posts by ebaydan777
Old Jun 22, 2013, 05:29 AM
py5rx is offline
py5rx's Avatar
Joined May 2008
Hi,
Askyvision:
I will take your comments in concern. I dinīt mentioned the first photos was not the final place of electronics and is just to have one first idea to where and how install the all parts.
I review the mount this morning while wait for the other parts to arrive, please take a look.
I not understood well where did you say to put the GPS, did you mean fix on top of battery plate?
ebaydan777:
I choose this propeller with reference at ecalc and motor information.
Cheers,
Old Jun 24, 2013, 03:36 PM
py5rx is offline
py5rx's Avatar
Joined May 2008
Hi,
1š post updated "lipos OK "
The lipo's arrived fron HOBBYKING DE, good chance to review the ship service
Almost all cells arrived with 3,84v
Cheers,
Sold DJI NAZA M with GPS & GPS Protector $350 Shipped priority mail CONUS MJB9 Aircraft - Electric - Multirotor (FS/W) 8 May 05, 2013 08:43 AM
Sold 550 size dji hexacopter with naza & gps hadawayj Aircraft - Electric - Multirotor (FS/W) 0 Apr 24, 2013 02:51 PM
Sold Brand New DJI F550 Hexacopter With a Brand New Naza M Controller and GPS Howeroll Aircraft - Electric - Multirotor (FS/W) 3 Feb 27, 2013 12:11 PM
Discussion DJI OSD for NAZA GPS and WK-M ? Velociraptor73 Multirotor Electronics 31 Oct 12, 2012 11:00 PM
Discussion DJI S800 w/ NAZA M & GPS? Campbell1082 Electric Heli Talk 9 Sep 03, 2012 01:37 PM
