Old Feb 02, 2004, 02:10 AM
Fiasco is offline
Find More Posts by Fiasco
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
It does not have to be minwax. Any water based polycrylic will work.
Fiasco is offline Find More Posts by Fiasco
Old Feb 02, 2004, 10:34 AM
tim61 is offline
Find More Posts by tim61
Senior Soil Sampler
tim61's Avatar
USA, WA, Port Orchard
Joined Nov 2000
I just spotted this thread, and thought I would throw in my 2 cents.
I glassed and painted a GWS 109 last month. I have not flown it yet, as I was delayed in finding a suitable spinner, but now I am ready to go. The power system is a 3 blade 9.6" SG Varioprop, GWS 400 "I" gearbox with a Cobri shaft ( www.e-flightline.com ), a Himax 5300, Phoenix 25 speed control, and a Tanic 2200 3s battery. The prop pitch is set to draw 22 static amps. This same set-up with a less efficient prop went 64mph in a GWS Spit on our radar gun. We are anticipating slightly higher top speed with the 109, due to the Vario Prop.
I glassed the 109 with 1/2 ounce cloth and Minwax poly, then painted with Delta acrylic craft paint thinned with Windex. I lightly misted the entire plane with Krylon Matte Clear after applying the decals.
The spinner is one I made from a plastic easter egg. Correct looking spinners are impossible to find, and I am not sure how durable the egg spinner will be, but we will see.
I think it is worth mentioning that there are several fabrics which can be used in place of fiberglass cloth. Jerry Hall has been using a light weight Dacron material he gets at Walmart with good results, and I have been told that Silkspan works well too. If you are finishing in a mattefinish, you probably don't need to ad any fillers to smooth the finish, as the weave in the fabric seems to enhance the matte look.
Tim
tim61 is offline Find More Posts by tim61
Old Feb 02, 2004, 10:35 AM
tim61 is offline
Senior Soil Sampler
tim61's Avatar
Joined Nov 2000
bottom
Old Feb 02, 2004, 10:39 AM
tim61 is offline
Senior Soil Sampler
tim61's Avatar
Joined Nov 2000
Easter egg spinner before installing prop and motor
Old Feb 02, 2004, 10:41 AM
tim61 is offline
Senior Soil Sampler
tim61's Avatar
Joined Nov 2000
This whole process worked so well, and was so easy to do, that I am currently glassing a Zero on floats (Rufe), a Corsair, and an F-82 Twin Mustang, all with Himax motors.
Tim
Old Feb 02, 2004, 10:49 AM
headless is offline
Find More Posts by headless
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
Very nice, tim... where can i find one of those? I've been itching for a dual mega 16/15 powered foamie...
headless is offline Find More Posts by headless
Old Feb 02, 2004, 02:36 PM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
Tim61,
Did you use the provided GWS stickers or did you create your own. If you did create your own, what paper did you use.
I used clear color slide decal paper but printers dont shoot white so there is no white in my decals.
Old Feb 02, 2004, 08:05 PM
tim61 is offline
Senior Soil Sampler
tim61's Avatar
Joined Nov 2000
Headless,
I made it up out of a GWS P-51, a spare GWS Fuse, and a foam wing center section I cut out of pink foam. It is in the early stages of construction, and the picture is actually of the mock-up with a cardboard center section and elevator. I am still working out the bugs, like where to carry the batteries, etc. Should be screaming fast though!
Fiasco
I used the stock GWS stickers on this one, but I cleared them with Krylon Matte Clear bfore I cut them from the sheet, then I cut them as close as I could to the edges of the actual markings. Worked out ok, but I am happier with the custom Vinyl Decals I did for my Corsair (R.I.P., look out for that school.....!) The GWS decals are kind of cool in that they are a little transparent, so the panel lines show through, but the adhessive is a joke. Good results for a first effort, though. These foam planes are a hoot! Next up, I am building a custom pink foam A-1 Skyraider that Jerry Hall cut for me. Should be sweet!
Tim
Below you can see the vinyl decals we cut for the Corsair. I liked them so much, I am doing a second set for the replacement Corsair. This one wasn't glassed......big mistake
Old Feb 03, 2004, 01:31 AM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
vinyl eh? I tried water slide decal paper but the catch with that is there is no white. It is also very expensive paper, but the ultimate lightweight 'sticker'.
Tell me more about the vinyl decal paper your using! What is it? How well does it work? Cost? And where can I get some
Old Feb 03, 2004, 03:23 AM
tim61 is offline
Senior Soil Sampler
tim61's Avatar
Joined Nov 2000
It is actually sign makers vinyl, like they use on those ads you see on car doors, or store windows. Usually around $5 a yard, and can be cut with an xacto. I actually have a friend who has the computer controlled cutter like the sign shops use, so he does the decals for me. The only draw back is that the tape you use to apply the decal will take stock GWS paint off, so you can only use it on glassed planes.
Tim
Old Feb 04, 2004, 03:02 AM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
So you have to apply tape to the decal to hold it on?
Do they have the vario in stock? Their site still says pre-orders. How do you like the vario?
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
Old Feb 04, 2004, 09:12 AM
tim61 is offline
Senior Soil Sampler
tim61's Avatar
Joined Nov 2000
No, the signmakers vinyl is self adhesive, really strong stuff. But to apply it, you use a transfer tape, like a masking tape, that holds the decals in place until you rub them down. It is like those decals you can buy for your car window, where you see the decal through the tape, if you know what I mean.
Yes, E-Flightline is stocking the Varioprops. As far as I know, they will be the only distrbutor in the US with stock on hand. However, I just found out yesterday that the initial order was delayed in shipping due to a mistake on the Zip code, so it may be a week before they have them. That is why in the picture of my 109's spinner, there is no prop. My 3 blade hub is in that order.
Of all the props I have tried thay are my favorite, not only for how they look, but also because they can be pitched for maximum performance. And, if you break a sigle blade, you can replace just that blade. And, did I mentiuon how cool they look????
Tim
Old Feb 04, 2004, 09:55 AM
The Disturbed 1 is offline
Find More Posts by The Disturbed 1
Flying Fanatic & Lunatic
The Disturbed 1's Avatar
Sillicon Valley, California, USA
Joined Dec 2003
Originally posted by Fiasco
Canned air stinks
litterally smells horrible!
The Disturbed 1 is offline Find More Posts by The Disturbed 1
Old Feb 04, 2004, 03:18 PM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
Color Slide Decal Paper
I found a site that sells both clear and white water decal paper for $1 a sheet.
The have a starter pack that contains 10 clear and 10 white sheets of decal paper. This stuff works great!
http://www.decal-paper.com
2 new GWS planes...glassing? xoon Parkflyers 27 Jan 03, 2005 11:26 AM
glassing gws planes 2 Tommy D GWS (Grand Wing Servo) 0 Aug 25, 2004 04:09 PM
Glassing GWS Planes Part II Michael Heer GWS (Grand Wing Servo) 0 Aug 25, 2004 03:57 PM
covering or glassing on GWs planes submarco Parkflyers 6 May 12, 2004 05:56 AM
Spare parts for GWS planes, where to get? Bleriot Parkflyers 8 Oct 25, 2001 08:48 AM
