Old Jan 21, 2004, 12:23 PM
hermperez is offline
Find More Posts by hermperez
know it all
Miami, Fl
Joined Nov 2003
Beanie, what prop and gear ratio were you using with the 350c?.. did it have enough power to climb vertical?
Mine at 12.8oz with 3 lipos and the 350c 5.33 gearbox and gws 9*7 has unlimited vertical.
Originally posted by beanie
hi gws fanatic,
i fly my formosa on the stock 350 with an 8cell kan 1050 pack. she gained 1.6oz after fiberglassing with 0.75 and paint. that was first attempt at glassing, so i'm sure you can get it way under that if you have had some experience. she seems to fly well like this without evidence of being underpowered.
hermperez is offline Find More Posts by hermperez
Old Jan 21, 2004, 03:18 PM
beanie is online now
Find More Posts by beanie
Ann Arbor, Michigan, United States
Joined Sep 2003
hi hermperez,
i am using the stock 350C (5.33:1) with a 10x8 prop on 8cell kans. AUW is 19.9oz. i dunno about unlimited vertical because my piloting skills basically suck. but she doesn't feel underpowered. she seems to move a lot faster than a friend of mine who is running completely stock on balsapr 700mah 8cell battery.
-beanie
beanie is online now Find More Posts by beanie
Old Jan 21, 2004, 07:10 PM
daddysblazer is offline
Find More Posts by daddysblazer
Crash Test Pilot
Erie, PA
Joined Dec 2003
Can anyone tell me where you are getting this fiberglass cloth, and what it is called (brand name?).
What types are good for E-RC and which should I avoid?
Thank You very much
Brett
daddysblazer is offline Find More Posts by daddysblazer
Old Jan 21, 2004, 08:29 PM
USSfishkiller is offline
Find More Posts by USSfishkiller
Joined Oct 2003
Im about to glass a formosa. Im using hangar 9 .5oz cloth. Here is the part # HAN3620. Check with your LHS to order or if you dont have a shop, just order direct from horizonhobby.com. I also just picked up a SMALL jug of minwax at home depot for 4.00 and also a large spray can (cool) of the same thing for 8.00. Dunno which one works better but I will find out. also, if it matters, the guy at home depot said to use a foam brush instead of bristled. Ill find out if he's correct. The minwax jug says to use bristled so who knows.
btw, the cloth retails for $5.99 for 1 sq. yard.
USSfishkiller is offline Find More Posts by USSfishkiller
Old Jan 22, 2004, 10:19 AM
Vanning is offline
Find More Posts by Vanning
WAA pilot #21
Vanning's Avatar
Princeton NJ
Joined Dec 2003
Maybe a dumb question, but that never stopped me before...
Anybody ever glass a Slowstick wing? Worth it? Ive beaten the heck out of mine, and a little rigidity wouldnt hurt either.
Vanning is offline Find More Posts by Vanning
Old Jan 22, 2004, 05:34 PM
Joined Oct 2003
dunno, sounds like that would be worth trying.
Old Jan 23, 2004, 03:53 AM
Fiasco is offline
Find More Posts by Fiasco
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
I finally got around to finishing up my glassing of the 109. I estimate my total flying weight when I am finished at 18oz.
Can't wait to tackle my chosen camo scheme!
Fiasco is offline Find More Posts by Fiasco
Old Jan 23, 2004, 08:35 AM
gws fanatic is offline
Find More Posts by gws fanatic
gws fanatic's Avatar
U.S.
Joined Jan 2004
any pics?
gws fanatic is offline Find More Posts by gws fanatic
Old Jan 23, 2004, 10:56 AM
know it all
Miami, Fl
Joined Nov 2003
so how much weight did the glass add?
Old Jan 23, 2004, 04:16 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
a good place to get .5oz glass it cstsales.com
I got 2 yrds for $5 at their booth at hobby visions in vegas a couple months back... i've glassed quite a bit of my last two mustangs and still have a lot left. I only glass the center of the wing, wing saddles, and under the nose and aft belly.
If the .5oz glass at cstsales is a little expensive give them a phone call and they'll work a deal with you on some 'left overs' from other larger orders that they have laying around.
Phreakish is offline Find More Posts by Phreakish
Old Jan 23, 2004, 07:12 PM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
All finished fiberglassing and trimming. Weight with
3 JR NES235 servos
Phoenix 25
Razor 2500
.5 oz fiberglass
16.1 oz
So should be at 17oz when its painted rtf.
Old Jan 24, 2004, 09:42 AM
U.S.
Joined Jan 2004
again....any pics?
Old Jan 24, 2004, 06:11 PM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
Right now the pix don't really reveal much. The model looks exactly like it did before I put fiberglass cloth on in pictures.
Old Jan 27, 2004, 02:56 AM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
Ok I have the base colors on the plane. I have not done the crackle paint camo scheme but that is next. Then, panel lines and weathering.
Target Scheme: Rohwer of JG3
Old Jan 27, 2004, 04:19 AM
Fiasco is offline
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
Flying weight is 16.6 ounces. The 2200 3S tanic pack fits in the battery tray of this 109 perfectly. I had to sand the outside walls of the battery tray to remove 1mm from each side to fit the tanic packs width. I also trimmed a few mm of the fill styrofoam over the top of the battery tray to fit the batteries height.
With the tanic 3S 2200 and the Razor 2500 out front, the plane balances at 56mm from the leading edge. The plane balances spot on with the Tanic installed snuggly in the battery tray in the normal battery location. The phoenix 25 controller and JR610 receiver are as close to the front as the space provided over the top of the wing would allow.
I was worried about potential CG problems needlessly it seems. It just magically balanced spot on with the pack/engine I chose.
2 new GWS planes...glassing? xoon Parkflyers 27 Jan 03, 2005 11:26 AM
glassing gws planes 2 Tommy D GWS (Grand Wing Servo) 0 Aug 25, 2004 04:09 PM
Glassing GWS Planes Part II Michael Heer GWS (Grand Wing Servo) 0 Aug 25, 2004 03:57 PM
covering or glassing on GWs planes submarco Parkflyers 6 May 12, 2004 05:56 AM
Spare parts for GWS planes, where to get? Bleriot Parkflyers 8 Oct 25, 2001 08:48 AM
