This thread is privately moderated by NashVegas, who may elect to delete unwanted replies.
Old Jul 06, 2013, 11:48 AM
135boom is offline
Find More Posts by 135boom
United States, WA, Pasco
Joined Oct 2005
I'm switching over to the extra 300 prop on mine (10.5x9) after reading this
http://www.rcgroups.com/forums/showthread.php?t=1748159
42 amps, 550 watts, power 25 1250 on 3s 10.5x9 prop
135boom is offline Find More Posts by 135boom
Old Jul 06, 2013, 11:50 AM
135boom is offline
Joined Oct 2005
I bet 4s is nuts!! Cg has to be a lil off with a 4cell pack I imagine
Old Jul 06, 2013, 01:26 PM
NashVegas is online now
Find More Posts by NashVegas
Jus 1 more plane is all I need
NashVegas's Avatar
United States, TN, Nashville
Joined Mar 2013
CG is not bad with 4s, but I like mine a little nose heavy. Also, I don't have to worry about nose overs since the two fields I fly at both have nice long paved runways
I haven't tried 4S with the Extra 300 prop with the Power 25. That's how I burned up my stock motor so I'm a bit gun-shy. I'm running the Power 25 with 4S on the stock prop and it really moves out.
I'm currently building a 2nd P47 razorback conversion and putting a big honkin' Hacker A30-10XL v3 900kv motor in it. It will handle the Extra 300 prop, and 4S. Wrenching on it today in hopes of a maiden tomorrow.
NashVegas is online now Find More Posts by NashVegas
Old Jul 10, 2013, 12:47 PM
135boom is offline
Joined Oct 2005
Well..the stock prop certainly turns more rpm and provides better takeoff power, while the extra 300 prop is a bit faster with better vertical using 3s and power 25.
I will have to buy a new extra prop, because I'm missing a little bit on the ends to be 100% positive with a conclusion, but as if now I actually prefer the stock prop on there
Old Jul 10, 2013, 02:13 PM
NashVegas's Avatar
Joined Mar 2013
How did you fit the stock prop on the Power 25? Did you use a prop reamer?
Old Jul 10, 2013, 03:13 PM
135boom is offline
Joined Oct 2005
Used the stock prop adaptor and stock prop. All fits right on
Old Jul 10, 2013, 03:14 PM
135boom is offline
Joined Oct 2005
Same shaft size on original BL15 and the power 25
Old Jul 11, 2013, 07:13 AM
NashVegas's Avatar
Joined Mar 2013
Man, what a dummy I am. I've been flying with the wrong motor mount adapter. That's what you get when you have too many motors lying around. To make maters worse, I had to ream out the stock prop to fit the adapter i've been using. I made it fit but it was unbalanced. I didn't notice that it was unbalanced until I put a 4S battery in and hit WOT. The prop began to chatter at high speeds.
Thanks for the heads up. I now have the correct adapter and a brand new stock prop installed. Can't wait to fly it !
Thank God for these forums!
Richard
For Sale Price reduced to 150 pnp on previous parkzone p47 Bnh105 Aircraft - Electric - Airplanes (FS/W) 2 Jun 14, 2014 09:09 PM
For Sale parkzone p47 air frame no motor/esc. Wildcat29 Aircraft - Electric - Airplanes (FS/W) 0 May 18, 2013 10:20 PM
Sold parkzone p47 with flaps and retracts installed 200 shipped! Bnh105 Aircraft - Electric - Airplanes (FS/W) 1 Apr 24, 2013 11:44 AM
For Sale Parkzone P47 with flaps, MINT arik434 Aircraft - Electric - Airplanes (FS/W) 0 Mar 29, 2013 08:20 PM
