This thread is privately moderated by NashVegas, who may elect to delete unwanted replies.
Old May 24, 2013, 04:40 PM
NashVegas is offline
Find More Posts by NashVegas
Jus 1 more plane is all I need
NashVegas's Avatar
United States, TN, Nashville
Joined Mar 2013
Video
Parkzone P47 Rocketship
E-Flight Power 25 1250kv with a Hobby Lobby eRC 65amp SBEC. I am using the stock 9.5x7.5 prop, and a 3S 2200 30C battery. Total blast!
Parkzone P-47 Mod (1 min 18 sec)
NashVegas is offline Find More Posts by NashVegas
Old Jun 03, 2013, 01:57 PM
135boom is offline
Find More Posts by 135boom
United States, WA, Pasco
Joined Oct 2005
Have you tried your setup with the extra300 10.5x9?
Just installed a 60 in it..waiting for the power 25.
What kind of flight times are you getting?
135boom is offline Find More Posts by 135boom
Old Jun 03, 2013, 03:56 PM
NashVegas's Avatar
Joined Mar 2013
I have not. This video was taken using the stock 9.5x7.5 prop. I am very new to the hobby, and afraid to push the engine. I actually own the extra300 prop. Do you think it will be okay with this motor if I only use 3S batteries? I don't own a watt meter either.
The reason I had to swap the motor out in the first place is because I fried the stock motor with the extra300 prop and a 4S battery. Came to a screeching halt in mid flight and locked up. Luckily I was able to put her down in a soft field.
Old Jun 04, 2013, 01:33 AM
135boom is offline
Joined Oct 2005
To be honest I don't know for sure, but I'll find out lol. Says the prop range on 3s goes to 10x10, so it will be close. I believe the x300 prop is 10.5x9.
I don't have a watt meter myself, otherwise Id try it out on there first.
What kind of flight times are you getting out of the stock prop?
Old Jun 04, 2013, 05:47 AM
NashVegas's Avatar
Joined Mar 2013
I set my timer for 6 minutes then land, so around 7 minutes. When recharging, I am putting 1000mah back into the spent batteries. I'm a bit conservative because i've heard stories of batteries getting burned out due to extended flight times. I don't mind the 6-7 min flight times since I have a box full of batteries
Old Jun 04, 2013, 07:40 AM
135boom is offline
Joined Oct 2005
That's pretty good!
135boom is offline
Joined Oct 2005
Seems plenty fast with the stock prop! How's the vertical?
Old Jun 04, 2013, 08:33 AM
NashVegas's Avatar
Joined Mar 2013
Vertical is straight up, no issue there.
And thanks for planting the seed in my head about the Extra 300 prop! Now I have to try it
Guess I'm going to have to invest in a watt meter if I'm going to be doing this much experimenting.
Old Jun 04, 2013, 01:12 PM
135boom is offline
Joined Oct 2005
Surprised nobody has tried it out.
That's awesome news on verticals!!
Old Jun 04, 2013, 01:21 PM
NashVegas's Avatar
Joined Mar 2013
Just so that I'm not misleading......vertically it will climb right up out of the sky. I don't mean vertical as in hovering 3D
Old Jun 04, 2013, 06:16 PM
135boom is offline
Joined Oct 2005
I knew what ya meant. Probably close to unlimited..
Old Jun 06, 2013, 02:25 PM
135boom is offline
Joined Oct 2005
Are you using the stock plastic motor mount?
Was noticing there are aluminum mounts out there for it..but not sure if its necessary.
Old Jun 06, 2013, 03:31 PM
NashVegas's Avatar
Joined Mar 2013
Yes, stock plastic motor mount. The E-Flight Power motor was an exact fit.
Old Jul 04, 2013, 01:14 AM
135boom is offline
Joined Oct 2005
Put the 25 in today. Love it!
Old Jul 04, 2013, 04:51 AM
NashVegas's Avatar
Joined Mar 2013
Realistically I should have waited to capture this video. I just ran a 4s battery with the same setup and it blows the performance in this video away!
For Sale Price reduced to 150 pnp on previous parkzone p47 Bnh105 Aircraft - Electric - Airplanes (FS/W) 2 Jun 14, 2014 09:09 PM
For Sale parkzone p47 air frame no motor/esc. Wildcat29 Aircraft - Electric - Airplanes (FS/W) 0 May 18, 2013 10:20 PM
Sold parkzone p47 with flaps and retracts installed 200 shipped! Bnh105 Aircraft - Electric - Airplanes (FS/W) 1 Apr 24, 2013 11:44 AM
For Sale Parkzone P47 with flaps, MINT arik434 Aircraft - Electric - Airplanes (FS/W) 0 Mar 29, 2013 08:20 PM
