This thread is privately moderated by catford, who may elect to delete unwanted replies.
Old May 23, 2013, 10:23 PM
catford is offline
Find More Posts by catford
Esky
Joined May 2013
How to Set Up the GP750 Gyro
A head lock gyro must identify the neutral position of a helicopter to maintain the aircraft's stability during flight. This type of gyro uses the front end (head) of a radio-controlled (RC) helicopter as a point of reference. It derives its name from the fact that it locks the helicopter into a position that keeps the nose in a specific position during flight. A gyro will return the RC helicopter to center to prevent a loss of control. Learn how to set up your GP750 head lock gyro to ensure that your RC helicopter remains stable and functioning at optimal performance.
Instructions
1Connect the gyro's gain wire into the gain channel of the receiver, then connect the rudder channel into channel 4 (sometimes labeled "RUDD") of the receiver.
2Plug the rudder servo into the servo input on the gyro, located on the bottom right edge of the device.
3Turn on the RC helicopter and receiver, then rotate it left to see whether the rudder gyro compensates by moving the aircraft to the right. If the helicopter doesn't move to the right, press the "SET" button until the "NOR/REV" light illuminates, then use the right joystick to change the setting form green (NOR) to red (REV) or vice versa.
4Press the "SET" button until the "Limit" light (the fourth light from the left) illuminates. Move the rudder joystick as far left as the aircraft's mechanics permit, then press the "SET" button to set the limit. Repeat this process for the right limit setting.
catford is offline Find More Posts by catford
Discussion Help please how to set up flaparons tazz666 Beginner Training Area (Aircraft-Electric) 21 Jan 12, 2014 01:33 PM
Question How to set up a really, really long range fpv (6 miles)? David97 FPV Talk 35 Jun 08, 2013 11:52 PM
Discussion Trouble setting Align GP750 gyro moejean 3D Electric Heli Flying 3 Mar 27, 2013 06:30 PM
Sold Align GP750 Gyro Jrami608 Aircraft - Electric - Helis (FS/W) 0 Feb 11, 2013 08:48 PM
Sold Align GP750 Gyro helinut4ever Aircraft - Electric - Helis (FS/W) 0 Jan 18, 2013 01:04 PM
