Old May 23, 2013, 02:55 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Big Blue design by Joe Gross
I came across this design and it has no thread.. so here is one ...please post your info and videos here...
basic info
- The material is Protection Board III fanfold insulation.
It's like Bluecor, except has film on only one side.
WING:
-The wing is 30 X 18.25 (root) X 14 inches at the tips before rounding.
-Trailing edge of wing is 1.75 inches lower than the leading edge
-Elevon chord is 5 inboard; 3.5 outboard.
Wing struts are bamboo skewers. No spars
FUSELAGE:
-Fuselage is 10 inches tall, not counting canopy and vertical stab,
-Top of vertical to bottom of fuselage is 14 inches.
-Rear horizontal fuselage is 2 inches wide. .
-Horizontal fuselage at the nose is 5 inches wide before rounding.
-The firewall is 4.5 inches in front of the wing at the root
Rudder:
-Rudder chord ranges from 6.25 to 4 inches
Specs
-- CG is 25% MAC.
-Wing loading 2.28 oz/sq ft.
- AUW 7.7 oz. (or 218g).
- The motor is a Turnigy SK2122-1570
-Prop 8x4.3 SF
-Battery 2S 350 Indoors, 2S 460 for Outdoors
davereap is online now Find More Posts by davereap
Old May 23, 2013, 02:56 AM
davereap's Avatar
Joined Feb 2005
videos.
Big Blue Fun at the MADS Field (6 min 22 sec)
Old May 23, 2013, 02:58 AM
davereap's Avatar
Joined Feb 2005
indoor flying I love the way this performs
Crazy RC Indoor Fun! (3 min 2 sec)
Old May 23, 2013, 03:03 AM
davereap's Avatar
Joined Feb 2005
drawings. in pdf format
Old May 23, 2013, 03:05 AM
davereap's Avatar
Joined Feb 2005
some dimensions for a smaller version at 22.5" span.. to fit my size EPP sheets
and the sketchup drawing at 30" ... the sketchup file is in the zip
Old May 23, 2013, 03:55 AM
EpicRC is offline
Find More Posts by EpicRC
Just another FPV addicted teen
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Wow very cool ive got a 1300kv blue wonder on order might have to make one of these
Ben
EpicRC is offline Find More Posts by EpicRC
Latest blog entry: 450 pics
Old May 23, 2013, 05:13 AM
hiko is offline
Find More Posts by hiko
New Zealand
Joined Apr 2012
I have one of those motors would it be a good match for 22.5 span?
hiko is offline Find More Posts by hiko
Old May 23, 2013, 05:43 AM
jkishan16 is online now
Find More Posts by jkishan16
Getting Somewhere :D
United Kingdom, England, Loughborough
Joined Dec 2012
Hi guys,just a few questions here
1)Is this a good beginner plane?Looks easy to build and also maybe fly slow(?)
2)I am going to use the A0 plans provided above,so do I just cut the 2 pieces and slide the wing into the fuse and then glue it fixed in place?
3)"The wing is 30 X 18.25 (root) X 14 inches at the tips before rounding." what does the root value and rounding mean?
And finally,the CG is 25% MAC,what does MAC mean?
Sorry, I'm not that good with abbreviation here,so I would greatly appreciate all and any help
jkishan16 is online now Find More Posts by jkishan16
Old May 23, 2013, 06:08 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
1. Don't know what you mean by beginner? If a first plane, no, if you have some experience and are comfortable with ailerons it might be OK. Simple enough to build and repair.
2. You could do that or split the fuselage in two pieces and then add them to the wing.
3. The root is the (center) section of the wing that meets the fuselage.
4. The MAC is Mean (average) Aerodynamic Chord (width). So it's the point on one wing where if you draw a line, the area on both sides would be identical.
I may have to build one of the little ones, I'm a sucker for Low Aspect Ratio wings. Might be fun with the little 10g motor. Thanks Dave.
Azarr
Azarr is offline Find More Posts by Azarr
Old May 23, 2013, 06:34 AM
Joined Dec 2012
By beginner I meant after amply flying and crashing of the Nutball :P
Have read a lot about it recently in the Nutball thread,that's what brought me here
Old May 23, 2013, 07:45 AM
uberjay is offline
Find More Posts by uberjay
Canada, ON, London
Joined May 2011
yeah... beginner ... it might be okay; however, it does not have the self-righting characteristics that the nutball has. So I'd suggest starting with the nutball then working up to this. But certainly, this could easily be a second plane. A first if you have help to guide you, but if you're on your own then a second ;-)
Nice Dave, thanks for putting this up. I'll have to check the PDF's, but any details on the motor mount angles? It looks like you build the nose square and the natural angle of the wing through the fuse takes care of the down thrust - ie. if you level the wings on a table the nose of the plane will be angled down slightly. Cool.
Cheers,
J
uberjay is offline Find More Posts by uberjay
Old May 23, 2013, 09:41 AM
joseico90 is offline
Find More Posts by joseico90
Lets break some props :D
joseico90's Avatar
United Kingdom, Liverpool
Joined Jun 2008
15 incher "Little Blue"
Here goes mine, done at 50% of original size..
Ready for maiden, too windy at the moment.
Now I'm gonna make a full size one too
joseico90 is offline Find More Posts by joseico90
Old May 23, 2013, 09:47 AM
uberjay is offline
Canada, ON, London
Joined May 2011
Hey Jose... surely you could hover that baby in your shop ;-) LOL
Actually, could be fun to tether the tail to a weight on middle of the floor then slowly throttle up into a tethered hover. Indoor amusement for those who have bad weather ;-)
J
Old May 23, 2013, 10:11 AM
joseico90's Avatar
Joined Jun 2008
it will hover off my hand with ease, but being Depron it will break if I crash it in here, no way...Jose
Old May 23, 2013, 10:16 AM
uberjay is offline
Canada, ON, London
Joined May 2011
..., no way...Jose
ROTFL... that's a great expression for you! LOL
Your nickname from now on should be, "No Way!" Jose ;-)
But I do hear you about Depron... that's why I suggested the tethered tail approach... to launch and catch just throttle up ;-).
J
Discussion Frame designs By Joe Joecnc2006 Multirotor Talk 304 Oct 26, 2015 07:22 PM
Sold big joes sittin on axial 8 hole beadlocks gguzman767 Cars - Trucks and Parts (FS/W) 4 Apr 21, 2013 06:49 PM
Sold Vintage Joe Bridi designed Sun Fli IV kit made by Sky Glass hobbyfun100 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 02, 2013 05:24 PM
Question Joe Gross Altus, OK countilaw Electric Plane Talk 0 Jan 23, 2012 09:51 PM
Yippee! First Video with the SSV2 designed by Joe. allthai Aerial Photography 6 Sep 16, 2005 05:59 AM
