Old May 21, 2013, 05:14 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Question
What does the single digit number on GWS prop mean?
Not the diameter and pitch, example being this EP8040. But there is a single digit number under it.
Some props have a 1 and some have a 2.
wopachop is offline Find More Posts by wopachop
Old May 21, 2013, 05:46 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Probably designates CW and CCW.
bartricky is offline Find More Posts by bartricky
Old May 21, 2013, 06:12 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
It may be the mold number.
Sparky Paul is offline Find More Posts by Sparky Paul
Old May 21, 2013, 07:04 PM
bartricky's Avatar
So much for that guess...
I found two GWS 8040 props one has a 1 and one has a 2 on it.
They look identical otherwise.
Old May 21, 2013, 09:15 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
My guess is something with the molds as well. I've wondered about this as well - the props themselves are identical.
Piece is offline Find More Posts by Piece
Old May 21, 2013, 10:09 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
None of the GWS props I have exhibit a number like that. Just the GWS and diameter/pitch. GWS on one blade, and EP1147 (for example) on the other.
Old May 21, 2013, 11:24 PM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
hope that GWS CEO Mr.Lin could answer the good question
regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old May 21, 2013, 11:38 PM
wopachop is offline
Joined Apr 2007
I was thinking molds as well. But why only two? My collection of GWS's has more number 1's.
Paul your post brings up more questions. First i went and checked my props. I have EP series between 7-10" and also a few slow fly props. Every single one of my props has a number 1 or 2 near the trailing edge. Except for an EP-0843 that i bought from Heads Up, a reputable dealer in my opinion. Now this prop is catching my attention. First it doesnt have the single digit, also its an 0843, with a zero before the eight. It says GWS, but the font and color of the prop and size of the letting is different from these 2 other slow fly GWS's im comparing to.
I wonder is this a knock off GWS? Or maybe a really old GWS?
Other questions:
What do you guys think of GWS slow fly props? I read they sucked. The few i have feel like wasted money in my hands.
GWS props are more flexy than an APC, does that matter especially when considering flying style?
Do small diameter GWS props work better than the larger diameter?
Old May 21, 2013, 11:48 PM
bartricky's Avatar
I have a bunch in my prop box.
I only used them on my first brushed/geared Slow Sticks.
IMHO They just suck too many amps unless your doing 3D.
Old May 22, 2013, 01:51 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Their slow fly props (any slow fly props) draw many amps after a point because its an undercamber, with considerable drag that puts lots of resistance to a motor not spinning for slow flying rpm.
Teddy Ong is offline Find More Posts by Teddy Ong
Old May 22, 2013, 04:55 AM
bartricky's Avatar
They are popular on quads.
Old May 22, 2013, 09:06 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Why not use GWS HD.. they appear to be efficient (at least in static testing) and can cope with far higher RPM (100,000rpm/diam) than the flimsy GWS RS (40-50,000rpm/diam).
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 22, 2013, 03:20 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
The GWS Reduction Series props are generally inappropriate for most modern aircraft with modern power systems. They're called the "Reduction Series" for a darn good reason: They were originally developed for use with GWS's own brushed/geared reduction units, many of which kicked out less power at full throttle than some of our motors use with no load. My first Slow Stick came with an EPS400 motor and gearbox, and even THAT included an HD-series prop.
Discussion What do Motor Numbers Mean? ForeverFlying Power Systems 5 Apr 17, 2013 08:45 AM
Discussion What does KV mean and the max? eliterussian6941 Power Systems 17 Feb 25, 2013 04:13 PM
Question What do the numbers on the motor mean??? bencookrc Power Systems 6 Jan 20, 2013 12:34 AM
Question What do the numbers on props mean exactly ??? Desert flier Beginner Training Area (Aircraft-Electric) 8 Nov 06, 2006 07:30 AM
What does the number on this Kokam cell mean? Fredrik W Batteries and Chargers 9 Mar 16, 2003 04:09 PM
