Old May 21, 2013, 03:23 PM
bob cripe is online now
Find More Posts by bob cripe
United States, NV, Laughlin
Joined Oct 2012
Help Turnigy 9x
I have a Turnigy 9x it took me 2 days to get it to bind to the HK Q-bot Quad, but in the process the radio will either not bind at all with the v911 or v912 or will bind and start at 50% throttle and not respond to any stick on the v949 and X-1 and just try and fly away. I had the module in and out several times, could I have damaged the micro coax cable? Any help would be appreciated. thanks. Bob
bob cripe is online now Find More Posts by bob cripe
Old May 21, 2013, 03:36 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It can't be the coax as the Q-Bot doesn't use the transmitter's normal module. Rather the supplied module works like AnyLink and plugs into the trainer port.
I don't understand your references to v911, v912 and v949. These do use the regular Turnigy module so can't work if the Q-Bot module is plugged in.
Please explain more clearly.
Daedalus66 is online now Find More Posts by Daedalus66
Old May 21, 2013, 10:44 PM
Joined Oct 2012
no longer binding
I got the q-bot to bind and fly with the adapter, I removed the adapter and the radio no longer works with the other models that are programed in. They all worked great until I used the HT8 adapter.
Old May 22, 2013, 06:49 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
You do have the regular module properly seated and nothing plugged into the trainer port?
Is it possible that in your experimenting you removed the regular module and damaged the connections or coax? There should be no need to remove it, as plugging anything into the trainer port removes power from the module.
Old May 22, 2013, 08:00 AM
c131frdave is offline
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
I've talked to several people that have had this problem. They get one shot to bind and then it won't cooperate after that. My friends' solution? Get a FrSky module and plug it in instead. lol Good luck to you!
c131frdave is offline Find More Posts by c131frdave
Discussion MultiWii MicroWii ATmega32U4 Flight Controller/ Turnigy 9X Help LandToAir Multirotor Electronics 7 Jul 19, 2013 02:12 AM
Discussion Turnigy 9X TX and Crius AIO Pro V1 HELP deepskysteve Multirotor Talk 0 Apr 14, 2013 12:05 PM
Question need help!! turnigy 9x er9x frsky telemetry theviper0308 Radios 0 Apr 05, 2013 12:22 AM
Discussion Throttle inverted on phoenix 4 with turnigy 9x - please help leopereira Simulators 3 Jan 15, 2013 04:19 PM
Discussion Need help with elevon mixing on Turnigy 9X radio. mrebman Radios 4 Jan 14, 2013 07:45 PM
