Espritmodel.com Heli Air
Old Jan 15, 2004, 10:19 PM
Rancho SA, CA NorCal
Joined Apr 2002
Just bought my cam, but have Questions
So I just picked up a Largan L330 3.4mp CCD w/ 6.6 interpolated mode for $120 @ Fry's
Here's the weight info minus 2 AA batteries and SD card
138 gram = 4.8678067 ounce
Dimensions are
3.99" (W) x 2.17" (H) x 1.44" (D)
What powerplant, prop, battery (Lipoly), and ESC do you guys recommend? I would like it to fly very smoothly and still maintain good slow speed characteristics.
Thanks for the help,
phuzzy3d
phuzzy3d is offline Find More Posts by phuzzy3d
Old Jan 16, 2004, 07:47 AM
BAR-STOOL's Avatar
Lakeville Minnesota USA
Joined Jul 2002
Hay phuzzyY3D
Whats the wingspan of you camera. Or are you going to send it up in a RC plane. IF you are going to use a RC plane what did you have in mind.
BAR-STOOL
BAR-STOOL is offline Find More Posts by BAR-STOOL
Old Jan 16, 2004, 02:52 PM
Frequent User
yb2normal's Avatar
Broomfield, CO, USA
Joined Jan 2001
yb2normal is offline Find More Posts by yb2normal
Old Jan 16, 2004, 03:47 PM
Joined Apr 2002
Well my camera doesn't have a wing I was going to use a Slow Stick, sorry if I didn't mention this. I'm up for buying a brushless motor that $80 or cheaper using lipolys for juice. I'm guessing my takeoff weight will fall around 25 ounces. Will I need a wing support like the one you have illustrated in another thread Bar-Stool? Thanks for the help.
Old Jan 16, 2004, 04:19 PM
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
Wing support would be a good idea for that much weight. An alternative to the compression strut is flying wires attached to (and across) the landing gear. I believe JMH is using flying wires if you want to have a search for it.
Brushless options are Razor (use the GWS gearbox/pinion), MiniAC 1215/16 (will need to drill pinion or use aftermarket GB), Astro 010, or a PJS-5xx, -800, or Nippy Black 1812/100. The last few are outrunners, no gearbox required. The Astro is probably the wimpiest of the bunch, but it doesn't need as big a battery, so it may yet work out. The others will give ~ 1:1 thrust/weight.
Figure $70-90 for the motor alone. Brushless ESC/BEC will run an additional $70 or so. Full throttle draw will be up to or over 18 amps depending on gearing, prop, and number of lipo cells, so a 2100 or 2p 1500 might be needed.
Karl
Karl Bē is offline Find More Posts by Karl Bē
Old Jan 16, 2004, 06:01 PM
TRP
TRP's Avatar
Morgan Hill, Ca
Joined Jun 2002
What's the Wingspan of your camera...
That was good.
Ted
TRP is offline Find More Posts by TRP
Old Jan 16, 2004, 08:47 PM
Joined Apr 2002
I just picked up my Slow Stick (backordered) and a 2cell eTech 1200mah pack. The hobby shop has a Mini 1216 brushless for sale. If I was to get this what GB and Prop would be recommended? Thanks Again
Discussion Fixed my trex but have a few questions about setup mdavenport Mini Helis 1 Jul 19, 2007 08:11 PM
Yippee! I finaly bought a brushless motor..... but I have some questions. BrMiHi08 Power Systems 25 Jun 25, 2005 11:22 AM
Just bought a Vivicam 3750...but I have some questons for the Nikon Coolpix owners. Randy Due Aerial Photography 6 May 17, 2004 11:43 AM
Ok, time for my second plane, the dandy sport it is, but I have questions.... DoomsDay Parkflyers 6 Nov 29, 2003 03:26 PM
Just got my Pencam today!!! A few questions: thor4944 Aerial Photography 18 Nov 30, 2002 06:24 PM
