Old May 19, 2013, 01:47 AM
redboat219 is offline
Find More Posts by redboat219
Philippines
Joined Jan 2005
Acrylic Tubing for WTC
Been looking for a source of polycarbonate tubing for a homemade wtc. Being in Asia I'm hardpressed to locate a supplier. What I did find are acrlylic tubing. As I've read several post about acrylic suddenly cracking on the table I'm a bit wary of getting it. Don't want to spend on something that can fail on the day I get it in the mail.
My question is, how good is acrylic compared to polycarbonate?
redboat219 is offline Find More Posts by redboat219
Old May 19, 2013, 10:33 AM
CaptainNemo12 is offline
Find More Posts by CaptainNemo12
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Might as well be using ABS or PVC. So far everyone that I've asked on RC-submarine forums have told me to avoid acrylic.
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old May 19, 2013, 10:42 AM
shaneperch is offline
Find More Posts by shaneperch
Joined Jul 2004
I would say use it and be watchful for cracks. if that is all you can get. If you know of anyone in the USA that can send you some Lexan tubing then try that route. I am going to take my motorhome over to get an AC unit installed. I will get some of that lexan tubing they use for the sewer system, they make nice WTCs they interlock. They may have that in Asia. I don't know.
shaneperch is offline Find More Posts by shaneperch
Old May 19, 2013, 10:58 AM
Roedj is offline
Find More Posts by Roedj
Michigan, USA
Roedj's Avatar
Joined Apr 2008
Bob Dimmack of OTW Designs has been using acrylic/plexiglass for years with little or no problems. Email him on the proper method of machining it.
Dan
Roedj is offline Find More Posts by Roedj
Old May 19, 2013, 11:40 PM
Philippines
Joined Jan 2005
I think OTW gets away with using acrylic because their wtc is based on a sealed water tank ballast system that doesn't involve a lot of machining to the tube. On my wtc I want to go with a vented tank with a snort system. This would entail a lot of drilling for the flood holes and vent valve assembly. Lots of potential cracking.
Old May 20, 2013, 06:10 AM
Roedj is offline
Michigan, USA
Roedj's Avatar
Joined Apr 2008
Not really.
In the pump section there are several holes:
1) Positive and negative battery,
2) Water inlet for the pump,
3) Forward push rod.
In the ballast tank section there are holes for:
1) Water inlet,
2) Three holes for various water level probes,
3) Hole for interconnecting tube to motor section
4) The baffles
In the motor section there are:
1) Hole for interconnecting tube to pump section.
2) Propeller shaft,
3) Two holes for push rods.
On each of the end caps there are three holes for the connecting brass rods that hold the whole WTC together.
Dimmack and company know how to drill plexiglass - try asking him.
Dan
Old May 24, 2013, 07:47 AM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
The trick with working acrylic or PMMA to give it the correct name is to use tools with little or no negative rake. This includes drill bits, which need to be specially sharpened for working with acrylic, or you can purchase drill sets witht he correct grinding ready done.
You must take light cuts, to prevent the tool digging in and heat build up in the work which causes stresses. A little water helps keep the tool and work cool, you can also mix a little soap in with the water to lubricate, but usually unnecessary.
Bear in mind that extruded acrylic tubing and sheet is full of stresses from the manufacturing process, ideally the work should be 'normalized' afer completion which should anneal the stresses out the material. However this is quite tricky to do with out access to an accurate temperature controlled oven, and is probably unnecessary.
Parts made from acrylic are more rigid than other plastics, and resist scuffing better, it also polishes much more nicely than polycarbonate, however it is far more brittle and is probably the trickiest of all thermoplastics to work with. PVC, ABS and polycarbonate are all a lot more forgiving to work with, and won't crack if you drop them on the deck.
Here in the UK PVC is the cheapest plastic usually, and makes excellent watertight enclosures. It's usually filled, which makes it opaque (PVC is transparent if unfilled) but that is not a major handicap, after all if a boat is going to spring a catastrophic leak, then it's most likely to do so with the hull all buttoned up, so you won't see it anyway, until it's too late.
Finish your Kilo!
Sub culture is offline Find More Posts by Sub culture
Old May 24, 2013, 11:12 AM
Philippines
Joined Jan 2005
Yes Andy. I'm working on it. Have to finish so I can work on my dream boat next, a Revell Type VII. That's why I need materials for the WTC. Already tried Australia and Singapore, most only have acrylic and those with polycarbonate require a minimum order of more than 1 length of tubing ( 5 pc of 8 ft long tubes, might as well open my own wtc shop).
Old May 24, 2013, 07:21 PM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
As mentioned over in the Sub Driver Forum, try Taobao, my friend. Easy to find & order via Chrome.
http://sammy811.taobao.com/search.ht...&queryType=cat
If you want a more easier route, contact Lin at BH Model & he can set you up with bulk tube or a WTC cylinder for cheap. Email is bhmodle@163.com.
herrmill is offline Find More Posts by herrmill
Old May 25, 2013, 01:43 AM
Philippines
Joined Jan 2005
Hermill I tried that site, having some difficulty understandIng the site even with Google translator. Will try to get in touch with BHModels instead.
Old May 25, 2013, 05:38 AM
Philippines
Joined Jan 2005
I did find what I need at Amazon but I'm still checking of they'll ship to the Philippines. I've read post that some people employ a courier service between Amazon and them.
Question Graupner Shark with WTC redboat219 Submarines 0 Mar 11, 2013 06:16 AM
Discussion Assembling WTC Nose Cone ir3 Submarines 5 Jan 30, 2013 04:35 AM
Help! Clear U-47 wtc Tube UK_SCORPION Submarines 11 Jun 09, 2008 05:01 PM
Discussion acrylic tubing wolfsong Submarines 10 Feb 06, 2006 11:35 AM
Acrylic over Krylon or Krylon over acrylic? fliir Scale Kit/Scratch Built 10 Nov 20, 2005 07:37 PM
