Old Jul 27, 2001, 04:55 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Ooops - sizzle sizzle sizzle little cells
Word to the wise.
When flying lots of different models at one and charging vastly different sized packs don't just double check your charger settings - treble check them
Don't do what i did tonight -
take off the nicely charged 8x2000RC pack that had just finished charging at 4.00Amps
Then connect the 7x250mahAAA pack and change the charging current to 0.40amps - then press charge.
Else there is a chance that you'll come back about two minutes later to a red hot sizzling pack - the legend R staring at you from the LCD window and the realisation that it was the DISCHARGE current that you had set to .40A and you had just pumped 4 amps into you baby AAA pack.
After being left in the middle of the pit area on their own they cooled down eventually and indeed gave a good duration flight on the Lite Stick later on. I don't hold ou much hope of their longevity though.
I mean 4 amps! - lesse - thats a 16C charge rate.
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 27, 2001, 05:00 PM
Mighty Mik is offline
Find More Posts by Mighty Mik
Berkeley, CA USA
Joined Apr 2001
What charger did you do this with?
Originally posted by leccyflyer:
Word to the wise.
Mighty Mik is offline Find More Posts by Mighty Mik
Old Jul 27, 2001, 05:16 PM
Sloping off....
leccyflyer's Avatar
Joined Sep 2000
Mik
This was with a Robbe Infinity charger - it must have seen the peak (probably just like a virtual Mt Etna as it happens) because the charge had been terminated within a couple of minutes - hence the R in the LCD display. So at least it didn't make the pack into an incendiary device in the back of the car.
cheers
Brian
Old Jul 27, 2001, 05:51 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
leccy,
A few weeks ago I stuffed 5amps into a 8x500 Zagi pack by mistake. So far there's no sign of damamge/detoriation.
Look at it as low-level zapping!
tim
tim hooper is offline Find More Posts by tim hooper
Old Jul 27, 2001, 06:58 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
yeah, very easy to do.. in a hurry.. set up the charger.. oops, wrong profile.. or forgot to add a decimal point.
tic is offline Find More Posts by tic
Data 2dogrc's 15C Burst 20C Dualsky 620 Test! They're HOT! SIZZLE! SIZZLE! 2dogrc Batteries and Chargers 7 Mar 03, 2006 08:30 PM
Lipo: More little cells, or few bigger cells? 717 Batteries and Chargers 3 Mar 25, 2005 03:33 PM
Diablotin: Big Plane with Little Cells kelvin Sport Planes 42 Oct 06, 2003 11:50 AM
Yippee! Etech's are tough little cells n2wizard Batteries and Chargers 20 Aug 15, 2003 09:42 PM
Sunday at the Sizzle? Dereck Electric Plane Talk 4 May 27, 2001 10:01 PM
