Old Nov 29, 2001, 04:01 PM
steveUK is offline
Find More Posts by steveUK
Bradford, UK
Joined Nov 2001
kyosho F16 - Few Questions
Hi Guys, I'm new to electric flight and have just aquired the above model. I wondered if any of you guys could tell me how you have set this model up regards elevator/aileron throw and CofG.
Also ive been told it flys well on 8 cell 2000mAh, can any of you guys back this up.
So far the things I've noticed about this model are the near useless elevator rods that are supplied with the kit, and the practically impossible to apply decals, apart from this I am quite happy with it and looking forward to giving it its maiden flight.
Thanks in advance for any advice.
Steve
Bradford
UK
steveUK is offline Find More Posts by steveUK
Old Nov 29, 2001, 04:50 PM
TeamSlacker is offline
Find More Posts by TeamSlacker
St. Cloud, MN
Joined Sep 2001
The couple flights I've had on mine so far have been with an 8 cell 2000 pack. Flies Ok and is also my first EDF.
I used the included elvetor rods with one change, instead of using a Y harnes on both servos and bending one rod, I used a seperate rcv channel on the 8103 and mixed the channel which allowed both elevator linkages straight runs.
I have the throws and CG set as speced in the manual
Didn't have any probs with the decals, just took my time, and it WAS very time consuming.
Do a search on the forum for F16 and you will find lots of usefull info for this EDF. Sounds like the hot battery setup is 8 cell CP1700's (if I remember right). Some have also droped the 2 ail servos and did a taileron setup.
TeamSlacker is offline Find More Posts by TeamSlacker
Old Nov 29, 2001, 05:05 PM
BioHazard is offline
Find More Posts by BioHazard
CMFC Secretary (UK)
BioHazard's Avatar
Swindon, UK
Joined Oct 2000
I've configured my completely differently - Taileron only.
I've two sets of rate dialled in -
For highspeed / general handling it is 130% of the specified throws.
For takeoff / lowspeed, I have full 90° deflection on both up and down movements.
Not much use for you.... but a few people have made this mod and have been asking about control throws.
BioHazard is offline Find More Posts by BioHazard
Old Nov 29, 2001, 05:46 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Re: kyosho F16 - Few Questions
Originally posted by steveUK
[...] how you have set this model up regards elevator/aileron throw and CofG. Also ive been told it flys well on 8 cell 2000mAh [...]
The Kyosho recommended throws on ailerons & elevators seemed just right to me - if you reduce the roll rate it will be <i>boring</i> , the CG location tends to be a bit forward, it should be moved at the back end of the Ky recommended range - and ready to give some up elevator when you launch it! I have seen almost every Ky F-16 at my field have this problem...
The elevator linkages are a bit flimsy but actually work ok, you can replace them with thicker piano wire.
A friend noticed a big diference when he switched (following my suggestion) from an 8x2000 to and 8x2400 pack, the latter provides more power. Running in the motor (dry) is recommended as it will draw ca. 33 Amps.
(<A href=http://aeneas.ps.uci.edu/edf/f16/f-16_mine.mpg> Here's </A> how mine flies with an Aveox 1010/2y.)
Herb is offline Find More Posts by Herb
Old Dec 01, 2001, 12:25 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Herb
I'd have loved to see your video clip, but when nothing had happened for a bit I had a look at the link- is it really 17.7mB? Estimated download time for that was over an hour so I'll have to pass for now.
Have flown my F-16 several times now. This one was picked up already built at the LHS for a very cheap price. The only mod I've made was to replace the very flimsy pushrods with thicker ones. Four 9g servos with both ailerons and elevators operating independently and no mixing. Using the recommended throws and C of G position. With the stock motor and 8x2400 I find it very slow indeed but very easy to fly. She won't loop from level flight, my first attempt ended in a passable impression of a tailslide though. Other F-16 pilots with much faster models have said that mine flies great, but perhaps they are just being polite . She does get away from a handlaunch easy enough and climbs well but is nowhere near as fast as I had expected from seeing toehr ones fly.
I had high hopes that the reduced weight of the 8xCP1300s might make a difference. That didn't happen so I don't think it's a weight issue. I'd put it down to either the rough ducting, the stock motor really just not being powerful enough, or on it's last legs. I'll make some modifications over the winter and maybe a replacement more thrusting motor is in order before next spring.
cheers
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Dec 04, 2001, 12:02 PM
Stuey is offline
Find More Posts by Stuey
Aylesbury,UK
Joined Apr 2000
My setup is a MF480 with a PLETT 200-25-4 on 9 zapped RC2000's from my spare car racing cells. Draws about 31 A on startup down to 27-28 A later on. I am getting a good 5 mins, now it goes like stink compared to standard stooging around speed. I will try 10 Pana2000 or CP1700's when i get round to it.I did try tailerons but didnt work so well for me.
Stuey is offline Find More Posts by Stuey
Old Dec 04, 2001, 02:03 PM
steveUK is offline
Bradford, UK
Joined Nov 2001
Thanks alot guys for your replys, much appreiated, I've set the aircraft up with the standard throws with an optional 80% less aileron deflection for the first few flights. Battery wise I've gone for 8 1250 scr and 8 2000 MaH sets to trial. I'm hopefully gonna fly this weekend, depending upon the weather.
Steve
Old Dec 05, 2001, 04:39 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally posted by Stuey
...I will try 10 Pana2000 or CP1700's when i get round to it.
There is a BIG difference in price & performance between the Panasonic 2000 NiMHd & the Sanyo CP 1700's! Go for the CP1700's at higher performance for 1/2 the price (I paid $3 each).
By the way you can link up elevators & ailerons to one servo on each side and save the weight of two elevator servos...
Old Dec 06, 2001, 06:52 PM
Capt. Dave is offline
Find More Posts by Capt. Dave
Hatboro Pa. USA
Joined Jan 2001
Wow, this is wild I just signed on to do a search on this jet. I was trying to sell mine a few weeks ago but decided to build it when I didnt get any real bites.
So anyway its done and now I need to power it up with the right batteries. Before I do the search I thought I saw where you 1010 2Y guys were using ten 1250mah zapped NiCads. Is this correct. I am using the 1010 2 Y.
Any help would be great. See my completed F-16 in the PIC below.
Capt. Dave is offline Find More Posts by Capt. Dave
Old Dec 07, 2001, 02:23 AM
steveUK is offline
Bradford, UK
Joined Nov 2001
Hi all,
Well I've finally finished my model. Took my time to hopefully ensure a trouble free 1st launch. I've set the CofG to 115mm and changed the elevator pushrods for a little studier versions as I was having trouble acheiving uniform throw distance with the supplied rods. Ive also added a little RF sheilding to the electronics. I purchased some Sanyo 1250's which melted the bat. packaging on the first run so that was a waste of money, not sure what happened there.
It turns out that one of my work colleges was the british national aerobatics champion 2 years on the trot so I've enlisted his help for the first days flying, as I want to bring the model home in one piece, I'll let you all know how it goes.
Bye.....
Steve
Bradford
UK
Old Dec 07, 2001, 10:12 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I RUINED a pack of 2400s a while back by doing a static run in my living room and not having any air blowing over them. The plastic tubing peeled back in a lot of places and after that the battery pack never would give the voltage it used to, I had killed about half the cells.
Now if I do a static run I get a room fan to blow across the battery as I run it down. When you're flying you have the cooling air coming through your cooling holes in the fuselage and then the hot air exits out the back, but with a static run you don't have this. I learned the expensive way.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Dec 07, 2001, 04:55 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... I'm not sure what happened there with the shrink-wrap but don't throw the batts away yet!!!!
I regurly melted the shrink-wrap on my 1250/2000/2400's and it's ok, they all get quite hot above 40A. BUT as long as they cells are insulated (no shorts) that's fine.
I would suggest a) checking pack/cells b) checking all insulations c) re-wrap some/all cells in some heat resistant insulator like Kapton or similar. d) ensure good cooling of batts even after flight AND never recharge when they are hot. Hope this helps
Just got my kyosho HOR in the mail. Have a few questions before I build it. ^jynx^ Motorcycles 10 Jun 18, 2005 09:23 PM
Kyosho F16 now sluggish? Andy W Electric Ducted Fan Jet Talk 21 Jul 04, 2001 02:35 AM
Just ordered a Kyosho F16.. BioHazard Electric Ducted Fan Jet Talk 3 Jul 04, 2001 12:57 AM
BAC Lightning,am designing twin EDF version,just a few questions! bipeflyer Electric Ducted Fan Jet Talk 4 Jun 30, 2001 05:02 PM
Kyosho F16 Dangerous Dick Electric Ducted Fan Jet Talk 12 Jun 26, 2001 12:42 AM
