Tamiya Agrios 4x4 TXT-2
Check out this 4x4 1/10th Scale 4WD
The Agrios is built around the new TXT-2 chassis.
Tamiya has always been known for its semi-scale vehicles, and the 1/10th scale Agrios is no exception. Built on the new TXT-2 chassis, the Agrios features dual 540 motors, 4-link suspension tied to solid axles, and dual shocks at each corner. It's also setup for rear-steer. The majority of this monster truck's chassis parts are black resin and plastic, with a few driveline parts being metal. But Tamiya has already developed a full line of metal upgrade parts to outfit this beast. The Agrios does require full assembly and painting of it's clear lexan body.
Specs:
  • Scale: 1/10 scale
  • Construction type: assembly kit
  • Terrain use: multi-purpose
  • Drive-train: 4WD
  • Drive type: gearbox
  • Drive line: solid axle
  • Differential type: gear
  • Suspension: 4-link
  • Steering mechanism: direct servo
  • Shock damper: oil-filled damper x8
  • Shock damper material: plastic
  • Tire type: rubber
  • Motor: 540-brushless type x2
  • Bearings: shielded ball bearing
Link to product
There are no posts
fully hopped up tamiya txt 1 monster truck junbug Cars - Cars and Parts (FS/W) 11 May 24, 2004 02:12 PM
WTT tamiya txt for arf cp heli junbug Aircraft - Electric - Helis (FS/W) 0 May 06, 2004 11:25 AM
Alert brushless eco 8 for tamiya txt monster truck junbug Aircraft - Electric - Helis (FS/W) 0 Jan 29, 2004 02:34 AM
Tamiya TXT-1 f/t ru5tl3r Aircraft - Electric - Airplanes (FS/W) 0 Mar 02, 2003 08:49 AM
For Sale: Tamiya TXT 3dwanabe Cars - Cars and Parts (FS/W) 0 Dec 13, 2002 01:53 PM
