Old Jan 13, 2004, 04:15 PM
No Step is online now
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
Trim paint on Monokote/Ultracoat
Been modeling for decades and decades but never tried painting trim on Monokote or Ultracoat. I've trim out a rather large area (in red) on my Volksplane with trim sheet but can't seem to get away from having many small air bubbles. I tried using Windex under the trim sheet to enable me to sweep out all the air but it didn't work as well as I had hoped. When it dried I still had bubbles.
Anyone have success painting trim on film covering? Does it scratch off?
Fred G.
No Step is online now Find More Posts by No Step
Old Jan 14, 2004, 12:01 AM
averen is offline
Find More Posts by averen
Love my Pike Superior!
averen's Avatar
Austin, TX
Joined Jul 2003
When I'm doing trim I generally use Monokote Solvent. You just put it on the underside of the top layer of film and press it against the second...it forms a great bond and you have some working time to get rid of air bubbles...no need for a heat iron either.
Averen
averen is offline Find More Posts by averen
Old Jan 14, 2004, 12:25 AM
No Step's Avatar
Joined May 2003
Oh thanks, I'll try it. I never thought of that.
Old Jan 14, 2004, 07:06 PM
No Step's Avatar
Joined May 2003
I tried the Monokote Solvent. It worked much better. I used it to lay down Monokote over Monokote. I didn't use Monokote Trim Sheet. Since it was a large piece (24 x 2 3/4), I did it progressively rather than laying it down all in one shot. (I tried that and had to remove it. It dried too quickly.) I have hardly any bumps at all, smaller pieces would be simple.
I also did a test on scrap Monokote by scuffing it up with steel wool and painting with Krylon (for electric planes). It did excellent as well. I couldn't scratch it off after drying 24 hours. But It didn't have the same gloss as Monokote. I don't know what would happen if you had to go over that area with a iron or gun to tigthen up the covering though.
I'm happy with the Trim Solvent. Thanks.
Fred G.
Old Jan 15, 2004, 10:33 AM
averen is offline
averen's Avatar
Austin, TX
Joined Jul 2003
Glad it worked out for you!
Averen
Old Jan 18, 2004, 06:53 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I'm using thin sign making vinyl. The seller says it is actually porous and so the bubbles will disappear. We'll see...
It does stick to solite well and it's not very opaque.
feathermerchant is offline Find More Posts by feathermerchant
Old Jan 19, 2004, 12:30 PM
No Step's Avatar
Joined May 2003
Let us know if it indeed is porous. I've used the vinyl from small businesses that cater to modelers, but isn't porous.
I also tried the Monkote Solvent on Solite: Ultracoat and Monookote ON TO Solite and it didn't seem to work. The edges curled some and it didn't stick well after 24 hours.
Old Jan 19, 2004, 12:34 PM
averen is offline
averen's Avatar
Austin, TX
Joined Jul 2003
The Monokote Solvent generally only works when it's monokote to monokote...I haven't found anything else that it will work on.
Old Jan 22, 2004, 11:09 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Another technique on the vinyl is to wet the surface with soapy water so you can slide the vinyl around and squeegee the bubbles out before it dries.
The trapped bubbles do seem to be getting smaller...slowly
Old Jan 29, 2004, 02:35 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I've scuffed the surface of the covering lightly with a scotch bright pad, and cleaned with aceton/denatured alcohol Then painted with normal Rustolium. Even after 10 years, the paint hasn't come off. THis was on a glow plane. For my electrics I use the Krylon fusion. No need to scuff. Stays tight. I hear this is not fuel proof. Haven't tested as I haven't built a glow plane in about 2 years.
rcav8r2 is offline Find More Posts by rcav8r2
Old Jan 30, 2004, 02:10 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
Which covering exactly did you do this on? MC or UC? I am looking to do some trim work on Ultracote Lite myself.
Roger
RMihara is offline Find More Posts by RMihara
Old Jan 30, 2004, 06:10 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Well I did this on older Monocote. The forumal has seemd to change. I no longer use Monocote as it seems to shatter after a few years. Since I switched to Ultracote, I haven't had a plane where I needed to paint. I did use the Fusion on SoLite this past summer, and it worked GREAT. Looks like it is part of the covering. Misted the first coat, and then did a heavier 2nd coat. I forget how long I let it dry between coats, but it wasn't too long. I also have it on some open areas and it looks just as good as on sheeted surfaces.
I don't see why it(Fusion) won't work on the UCLite though. Maybe try a test patch. This is what I did for testing on the Solite. I covered a mock up of an open and sheeted surface. Skuffed half, and then painted strips of various paints. Found the Fusion stuck the best by far, and it didn't need skuffed. Testers ModelMaster was a distant second amd that was after I skuffed it. I didn't try Rustolium.
Old Feb 01, 2004, 12:13 PM
Marion is online now
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
I like Xylol (get it at your local "home depot") for sticking Monocoat to Monocoat. It sticks as tight as the Monocoat solvent, but is less "aggressive" in use. It doesn't make as much a mess as the Monocoat solvent -- no bleading of the color from the bottom of the Monocoat. Besides, it is LOTS less expensive :-)
Marion is online now Find More Posts by Marion
Old Feb 02, 2004, 11:38 PM
No Step's Avatar
Joined May 2003
I just noticed today that Monokote's LustreKote matching paint says it can be painted onto Monokote. I thought it was for painting things like fiberglass cowls to match adjacent Monokote. They say scuff it with steel wool, clean, and paint. That would solve my disimilar gloss problem of using Krylon. I've used LustreKote to paint a fiberglass fuselage to match Monokote wings. I wasn't impressed how the paint comes out of the can. It's a very course spray, doesn't layout nice on the model, but it ends up smoooth when dry. I tried everything to get a nice spray out of the can,... heated it under running hot water, warm room air temperature, etc,.. still sprayed poorly but nice when dry. Don't know how it could apply well to Monokote without getting a thick coat on it.
Fred G.
Old Feb 03, 2004, 09:49 AM
RJB is offline
RJB
Find More Posts by RJB
RJB
Joined Oct 2003
You can apply paint to MonoKote or UltraCote. I've been doing it for a few years now with good results. The surface first needs to be scuffed, I use sanding pads from my local auto paint store. Don't use 400 wet/dry as it very easily cuts through the covering. Before painting, wipe the surface with alcohol to remove all dirt and finger oils. I've used LustreKote and Krylon paints and haven't had any problems with either.
To answer the question about shrinking MonoKote after painting it: yes you can. You'll need to use a heat gun (not an iron) on a low heat setting. Don't heat one spot for very long or you'll blister the paint, keep the heat gun moving. You'll see the paint start to get glossy as the heat softens it. Hope this helps!
Cheers!
RJB is offline Find More Posts by RJB
Testors Paint on Foam - just a fyi jazzster Foamies (Kits) 2 Aug 21, 2007 12:43 AM
Question Printing on Monokote trim? Michael in Toronto The Builders Workshop 6 Apr 28, 2007 08:47 AM
Paint on Monokote Dustoffer Fuel Plane Talk 3 Aug 09, 2004 09:13 AM
Paint on tissue? Rooster287 Electric Plane Talk 12 Feb 21, 2002 02:17 PM
removing stock paint on TM? barn buster 50 Parkflyers 29 Nov 30, 2001 06:52 PM
