Old May 05, 2013, 12:47 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
The New Turnigy 3D-H Flybarless System V1/V2
Guys there seems to be a New FBL system from Turnigy
http://www.hobbyking.com/hobbyking/s...ol_System.html
The all new Turnigy 3D-H FBL System is breaking all of the rules by offering top-notch performance at an unbelievably low price. Affordability, ease of use and compatible with any helicopter from 250~800 size, the 3D-H makes going flybarless on your machine a no-brainer!
The 3D-H supports just about any servo type, digital or analog, standard or narrow pulse width. Compatible with 90/120/140 swashplates and featuring excellent pirouette optimization functionality, the 3D-H ticks all of the right boxes!
We've flown the 3D-H on our own helis and we are very impressed with its performance and ease of setup. It didn't take long at all to have our HK450 in the air with this system. All programming is done via the transmitter sticks and confirmed by LEDs on the control unit. This keeps things simple and eliminates the need for bringing a PC to the field should you need to make adjustments.
There are 3 adjustable potentiometers on the top of the 3D-H that allow quick adjustments for fine tuning. You can adjust the cyclic gain, cyclic response and tail dynamic (stopping power) by simply turning the pots. This furthermore simplifies setup by allowing for quick and easy fine tuning at the field.
Features:
• High performance 3-axis FBL system
• Compatible with 250~800 size helicopters
• Pirouette optimization functionality
• 90/120/140 swashplate support
• Aluminium case to reduce vibration
• Easy to setup
Specs:
Weight: 23.8g (without wires)
Operating Voltage: 3.5~8.5V
Sensor Technology: MEMS angular rate sensors
Cyclic Servo Type: Digital or Analog 50Hz/65Hz/120Hz/200Hz
Tail Servo Type: Digital or Analog 960us/760us/1520us
Adjustable Cyclic Servo Frequency: 50Hz/65Hz/120Hz/200Hz
Adjustable Tail Servo Frequency: 50Hz/165Hz/270Hz/333Hz
Included in box:
Turnigy 3D-H 3-Axis Flybarless System
Gyro mounting pads
All necessary wire leads
Price: $49.99
Note:You may need an external BEC, depending on your setup.
Setup Videos same as the HB800, special thanks to HobbyCoolTech
http://www.rcgroups.com/forums/showp...5&postcount=71
Read what one of the Hardest and Best reviewers has to say about this product
mhills quote: "
Originally Posted by mhills51 View Post
Just walked in. It flys just like my beast, maybe even snappier
http://www.rcgroups.com/forums/showp...&postcount=152
Turnigy 3D-H V1
ALZRC 450 pro pilot mitsos3d Flybarless Systems 3D-H TURNIGY (5 min 16 sec)
The Turnigy 3D-H V2 is here!
The all new Turnigy 3D-H V2 FBL System is breaking all of the rules by offering top-notch performance at an unbelievably low price. Affordability, ease of use and compatible with any helicopter from 250~800 size, the 3D-H V2 makes going flybarless on your machine a no-brainer!
The 3D-H V2 retains all the great features and ease of setup of the original version, but now adds S.BUS functionality, PPM composite signal and DSM2/DSMX satellite receiver support as well!
The Turnigy 3D-H V2 supports just about any servo type, digital or analog, standard or narrow pulse width. Compatible with 90/120/140 swashplates and featuring excellent pirouette optimization functionality, the 3D-H V2 ticks all of the right boxes!
We've flown the 3D-H V2 on our own helis and we are very impressed with its performance and ease of setup. It didn't take long at all to have our Assault 700 in the air with this system. All programming is done via the transmitter sticks and confirmed by LEDs on the control unit. This keeps things simple and eliminates the need for bringing a PC to the field should you need to make adjustments.
There are 3 adjustable potentiometers on the top of the 3D-H V2 that allow quick adjustments for fine tuning. You can adjust the cyclic gain, cyclic response and tail dynamic (stopping power) by simply turning the pots. This furthermore simplifies setup by allowing for quick and easy fine tuning at the field.
Features:
• S.BUS, PPM and DSM2/DSMX satellite receiver support
• DSM2/DSMX satellite receiver connection lead included
• Easy to setup
Specs:
Weight: 22g (without wires)
Included in box:
Turnigy 3D-H V2 3-Axis Flybarless System
OrangeRX/Spektrum/JR (DSM2/DSMX compatible) satellite receiver connection lead
Gyro mounting pads
http://hobbyking.com/hobbyking/store...e_Support.html
Price: $49.99
PDF Manual
http://www.hobbyking.com/hobbyking/s...6X53414X41.pdf
http://www.hobbyking.com/hobbyking/s...6X53414X23.pdf
Bench test "ALL" your electronics, prior to installation in your heli.
Turnigy 3D-H V2 Forza 450 pilot: Blue Sky thanks to nascar1929
FORZA Turnigy 3DH V2 調整中 (3 min 55 sec)
pitchp is offline Find More Posts by pitchp
Old May 05, 2013, 02:08 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Lol
Its not out yet
Hmm I just cant quite put my finger on it , but it looks like a product i have seen before
jombo is offline Find More Posts by jombo
Old May 05, 2013, 02:12 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
yes jombo,
BIGAOLE Flybarless system(BGL007-007)
but are they the same??
Old May 05, 2013, 02:18 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
Naa , that's not it . Either way , I love the ZYX. I just flew it today , It makes any hack look good
Old May 05, 2013, 02:21 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
you don't even want to know the price?? fine! bbl
Old May 05, 2013, 02:23 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
If it comes in under 60.00 shipped , well then it may be a tester
Old May 05, 2013, 03:05 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
well onlyfinehelis has them for $59
http://onlyfinehelis.com/flybarless/...control-system
I'll only be in on it if the firmware is upgradeable and if it's under $50 shipped!
Old May 05, 2013, 10:29 PM
volumax is offline
Find More Posts by volumax
Joined Mar 2012
Originally Posted by pitchp View Post
well mhobbies has them for $80 shipped.
http://www.mhobbies.com/hobbymate-fb...gyro-mems.html
hahaha you really want a bargain!
volumax is offline Find More Posts by volumax
Old May 06, 2013, 12:06 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
With that much FBL systems releasing everyday, it's the only way HK can compete with them. Their products have to be better and cheaper to win their customers! Take for example the Tarot ZYX-S it's $50, it's gotta be cheaper than that, otherwise what's the point??
Old May 06, 2013, 08:30 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
jombo, it's the bigaole flybarless clone. It looks soo similar to it!
if this 3d-h can perform like the bigaole flybarless. and it's under $50 shipped. It would be just right!
I like what I see with the bigaole vids.
Jesper Tange - beam 450se 1-4-2013 (3 min 26 sec)
We need to see the specs of this 3d-h gyro, only then we can really tell if it's an exact clone
Old May 07, 2013, 08:35 AM
fishfiend is offline
Find More Posts by fishfiend
Joined Jun 2008
Well its out now on the new items page guess what... $50
A bargain!
fishfiend is offline Find More Posts by fishfiend
Old May 07, 2013, 11:19 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Yep specs are very similar to the bigaole. This thing is gonna sell like hotcakes.
Old May 07, 2013, 11:35 AM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
Not bad , Not bad at all for 49.00. So I think Pitchp should test it out for us , Since he is the only one who hasn't tried one yet
The only thing that concerns me is the lack of computer support programing . It is all done by the sticks . But that shouldn't be too hard just different to do as the lights would tell you what step your on .
Pitchp , this one is for you
Old May 07, 2013, 11:38 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
lol! Let's do it together jombo for good old time sakes. add to cart jombo..... add to cart.
Old May 07, 2013, 11:43 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Geez, I already have three FBL units and none mounted in helis yet! An Align 3G, a 3GX, a Tarot ZYX-S. Even the Align 3G upgraded to newest firmware should be good for a scale flyer I am told. I don't even know what to mount in which heli! I have an HK450 FBL that I was going to use with the the ZYX and I was going to put the 3GX in my HK550 since that's my best FBL unit. Now I'm hearing this one is a microbeast V1? And some have said the firmware can be upgraded?
shahram72 is offline Find More Posts by shahram72
Sold NEW!!! JR TAGS01 flybarless system with G tune adapter Mike Fortune Aircraft - Electric - Helis (FS/W) 0 Apr 23, 2013 10:29 PM
For Sale Brand New iKon Flybarless System Howeroll Aircraft - Electric - Helis (FS/W) 0 Apr 17, 2013 10:56 AM
Sold Brand New, never opened Align 3GX Flybarless System Raydee Aircraft - Electric - Helis (FS/W) 3 Apr 03, 2013 05:14 PM
For Sale iKon Flybarless System Brand New Howeroll Aircraft - Electric - Helis (FS/W) 2 Apr 01, 2013 02:11 PM
Discussion New Turnigy V-Bar 600 Flybarless System bwoollia 3D Electric Heli Flying 20 Mar 17, 2011 08:49 PM
