Joined Jan 2004
Patent link
Here is the link to the pixelito patent :-
http://v3.espacenet.com/textdoc?IA=A...PN=WO03080433. The hinge for the tab magnet could be mounted outside of the coil as in some of Graham Stabler's 'inside story' illustrations or the magnet could be pivoted by bringing the shaft out in between two adjacent coils, as in some of the other designs. If the coil radius is R and the coils are separated by a distance R then the field at the midpoint, and some way along the axis, is uniform. Within a single coil it's probably more or less uniform to a first approximation. Perhaps someone might comment on how the single/double coils affect the proportionality of the coil response? |
Joined Jan 2004
Pixelito patent
The pixelito patent is public domain. All patent applicants must agree to their patent being published. Full protection against unathorised commercial exploitation is provided by the patent application (and continues for a considerable period providing it is subsequently granted by the patent examiners).
The following is nearly the same in every country.:- The specification shall contain a written description of the invention, and of the manner and process of making and using it, in such full, clear, concise, and exact terms as to enable any person skilled in the art to which it pertains, or with which it is most nearly connected, to make and use the same, and shall set forth the best mode contemplated by the inventor of carrying out his invention. On the danger of invalidating the patent by Mr Van de Rostyne using a secret Tab mag in the pixelito model, instead of a motors as illustrated in the document see http://www.baypatents.com/News/news_...play.asp?ID=35 "Since patents have been invalidated for failure of the applicant to adequately present or describe the invention, it is important that we be sure to include in the application a sufficient description to permit one skilled in the field to which the invention pertains to make and use not only some form of the invention, but the best form of the invention known to us at the time the application is filed. For example, if we know that the preferred form of the invention requires use of a particular material, or processing of a particular sort, we must fully disclose this in the application. Put differently, if we decide that some aspect of the invention is really proprietary and a trade secret and therefore do not disclose this aspect in the application even though it relates to the preferred embodiment of the invention, not only will any resulting patent likely be invalid, we also may be held liable for significant damages occasioned by others who have been sued for infringement of the patent, or who have improperly paid royalties thinking the patent to be valid, or who have had to change what they were doing, or were investing monies to design around what they thought to be a valid patent. " |
| Thread Tools | |
| Build Log diy pixelito 2 | somt1033 | Micro Helis | 1 | Dec 20, 2006 04:44 PM |
