Old Jun 26, 2013, 08:27 AM
Suzukistreet is offline
Find More Posts by Suzukistreet
United States, VA, Louisa
Joined Jan 2013
I freaked out a little first time I experienced this, but reading page 10 in the manual shed some light -
Advanced-Motor-Stop-Type:
Notes of Intelligent Mode
(1) In ATTI. / GPS ATTI. Mode, it has landing judgment, which will stop motors.
(2) Start motors in ATTI. / GPS ATTI. Mode, you have to execute CSC and then push throttle stick
over 10% in 3 seconds, otherwise motors will stop after 3 seconds.
(3) During normal flight, only pull throttle stick under 10% will not stop motors in any control mode.
(4) For safety reason, when the slope angle of multi-rotor is over 70 during the flight in ATTI. / GPS ATTI. Mode (may be caused by collision, motor and ESC error or propeller broken down),
and throttle stick is under 10%, motors will stop automatically.
Notes of Intelligent Mode & Immediately Mode
(1) If you choose the Immediately Mode, you should not pull throttle stick under 10% during flight,
because it will stop motors. If you do it accidentally, you should push the throttle stick over 10% in
5s to re-start motors.
(2) DO NOT execute the CSC during normal flight without any reason, or it will stop motors at once.
(1) If you choose the Intelligent mode, and the throttle stick is under 10%, this will trigger the landing
Procedure, in any control mode. In this judgment, pitch, roll and yaw controls are denied except
the throttle, but multi-rotor will still auto level.
(2) In any control mode, DO NOT pull throttle stick under 10% during normal flight without any
reason.
(1) Any of these two cut off types will only work properly if TX calibration is correct done.
(2) In failed-safe, CSC is denied by the main controller, motors will hold their state.
Originally Posted by Dkonline View Post
Hi guys! I'm a little confused! Help, please!
I made oktokopter with Naza-m v2, and everything is fine, BUT!
It runs very abnormal - I am starting by CSC and then nothing - motors do not start...
After, when I quickly increase the gas up to 50% - only in this case - motors start, and if I reduce the gas - they switched off.
BUT!))) If I waited for 5 seconds, I can reduce gas to 11% and everything works. And I can fly..
I think - maybe NAZA broken, but everything other works perfectly, flies well, etc.
I do not even know "where to look."
In the Remote-Control there are default settings gas from -100% to +100% and no any trim, etc.
And I have Naza-M v2 Firmware v3.12.
Heeelppp!)
Suzukistreet is offline Find More Posts by Suzukistreet
Old Jun 26, 2013, 08:31 AM
blackbrabus is online now
Find More Posts by blackbrabus
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
Just a little note, I was test flying my HAL with v2 NAZA and gps and though I would test the zero throttle in flight decent limiter............all motors cut off and it fell like a stone......full throttle and recovered really well.......these are my findings but I have the throttle set to immediate off and not intelligent.....I'm guessing this is the reason for the falling stone act.
blackbrabus is online now Find More Posts by blackbrabus
Old Jun 26, 2013, 08:36 AM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
Seems reasonable for a mode named "IMMEDIATELY".
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Jun 26, 2013, 08:45 AM
Joined Nov 2011
yep. I absoutly $h!t myself......then remebered I had it set to immediate
Old Jun 26, 2013, 09:24 AM
Empire Support 3 is offline
Find More Posts by Empire Support 3
Empire Hobbies Support
Joined May 2013
Heeelppp!)
If you are using other brand ESC than DJI, please make sure you calibrate each ESC to your TX.
Empire Support 3 is offline Find More Posts by Empire Support 3
Old Jun 26, 2013, 10:03 AM
djp321 is offline
Find More Posts by djp321
Joined Jun 2013
Originally Posted by fatbutcher View Post
To answer your question, my understanding is you can still use a Naza V2 in ATTI mode regardess of if the GPS is fitted or not. So you should be able to either disable it or fit it after your one off trip.
Hi,
Thanks for your input.
My question was if i can use atti mode without the LED and PMU?
( i will not use the gps unit on that one off trip regardless)
Basically it comes down to whether i should go for the v1, or the v2.
It's a matter of number of units i'd have to install to use the atti mode.
Also - The PMU and LED on the v2 - do they have to be mounted in a specific way? As in horizontal? or could they be mounted vertical without any issues.
Your help is really appreciated :-)
Br,
Dennis
djp321 is offline Find More Posts by djp321
Old Jun 26, 2013, 10:15 AM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Originally Posted by djp321 View Post
Hi,
Br,
Dennis
I would get the V2, your then up to date with DJI. You can place the PMU and LED any way you see fit to accommodate your other electronics, just make sure your Naza FC is properly oriented with the front of the aircraft.
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jun 26, 2013, 10:53 AM
daskim is offline
Find More Posts by daskim
Videographer/Product Reviews
daskim's Avatar
United States, WA, Spokane
Joined Oct 2012
Does this still have to be done if you have replaced the original TX with the same brand and model as the original one? My first one bit the dust, and have purchased a second one.
- - david
daskim is offline Find More Posts by daskim
Old Jun 26, 2013, 11:29 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Leave Nothing To Chance
- - david
In view of the abnormal behavior several pilot's are reporting, if you change any component, I'd recommend that you reset everything...
T J Gilbert is online now Find More Posts by T J Gilbert
Old Jun 26, 2013, 11:34 AM
daskim is offline
daskim's Avatar
Joined Oct 2012
Man, I wish flying were a little more predictable than what it has become.
thanks
- - david
Old Jun 26, 2013, 12:02 PM
Empire Support
Joined Feb 2009
Details...
thanks
- - david
FWIW, even if there were no issues, I'd personally still reset everything.
I'm not saying that covering as many details as possible eliminates issues, but it surely reduces their likelihood...
I'm one of the fortunate pilots that have not had problems.
And I'm pretty OCD about the details...
Old Jun 26, 2013, 12:11 PM
dartmouth01 is offline
Find More Posts by dartmouth01
Joined Oct 2006
I look a it like the Mac/PC dynamic. Macs work great right out of the box, but that's heavily influenced by the fact that try control the hardware tightly, so there are less places to go wrong. PCs are very customizable but that also makes them more prone to failures and conflicts. If you are to buy a Phantom, odds are good that it'll fly right out of the box. If you buy all different components and put it together yourself, odds are you'll have to debug it before it flies perfectly.
thanks
- - david
dartmouth01 is offline Find More Posts by dartmouth01
Old Jun 26, 2013, 12:14 PM
daskim is offline
daskim's Avatar
Joined Oct 2012
I agree.
I just thought replacing one TX with a second identical TX wouldn't necessitate going through a second throttle calibration.
- - david
Old Jun 26, 2013, 12:21 PM
Empire Support
Joined Feb 2009
Everybody Has One...
I agree.
- - david
You asked for opinions.
I gave you mine.
If you really feel a second identical TX won't necessitate going through a second throttle calibration, it won't hurt my feelings if you don't.
I am not one of those posters that goes berserk if you choose to go your own way...
In fact, it will be interesting to see how it works out.
All will most likely go well.
Are you feeling lucky?
I even promise not to say "I told you so..."
Old Jun 26, 2013, 12:27 PM
ZACATTACK's Avatar
Joined May 2011
Does anyone here know what the original default factory settings are in the 30A OPTO ESC's or where to locate this information? It would be good to know so people can set their parameters in the ESC's purchased from other manufactures exactly like DJI sent them to us. Note: the ESC's coming from DJI cannot be adjusted. Thanks!
Discussion NAZA GPS ***Owners Thread*** FIRST PAGE LINKS UPDATED 8-13-12 blade strike Multirotor Electronics 14916 Apr 04, 2016 02:02 AM
Discussion DJI Naza FC - First Page Has Links and Tips Tahoe Ed Multirotor Electronics 22254 Jan 30, 2016 08:16 PM
Sold Brand New DJI F550 Hexacopter With a Brand New Naza M Controller and GPS Howeroll Aircraft - Electric - Multirotor (FS/W) 3 Feb 27, 2013 11:11 AM
Wanted Naza/GPS or WK-M v2 timelrd Aircraft - Electric - Multirotor (FS/W) 1 Feb 22, 2013 05:17 AM
Sold Naza M and Naza M GPS Twinkletoze Aircraft - Electric - Multirotor (FS/W) 1 Feb 06, 2013 11:58 PM
