Old May 01, 2013, 02:50 PM
pburress is offline
Find More Posts by pburress
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Contest
BBCC 2 - Easybuilt's Pitcairn Fleeting - pburress
--NOTE-- Final Pics are on Post #29 on Page 2
My entry in this contest is Easy Built Model’s Pitcairn Fleetwing at 16” span. I ordered the model from http://www.easybuiltmodels.com/ca04.htm and entered the contest with literally minutes to spare before the entry deadline.
The Fleetwing was built in 1925, for use as a trainer and passenger carrier. In 1929 a Fleetwing C3261 took 20th place in the National Air Races. Apparent this airplane is still flying, though it crashed in 2012 and needs repairs.
One interesting note I found while researching is that the first Fleetwing prototype crashed on it’s maiden flight, due to control cables being reversed. Sound familiar to any modelers out there?
I will keep this as close to it’s free flight design as possible and will try to keep it modestly powered with the goal of low weight. I have a brick from a Parkzone Vapor. Not sure what motor I’ll use at this point, but the final weight will be a consideration there. According to Easybuiit’s site, the (free flight) prototype of the model weighed 18.1 grams.
This project is next in my build queue so I won’t be starting immediately. Currently I am working on a 12” Farman Sport Parasol over in the Scale Electric Planes forum, and will finish that before I dive into the Fleetwing.
pburress is offline Find More Posts by pburress
Old May 01, 2013, 05:24 PM
BrundleFlyBy is offline
Find More Posts by BrundleFlyBy
Never stop being a kid.
BrundleFlyBy's Avatar
United States, CO, Manitou Springs
Joined Jan 2012
Welcome to the fray. I chuckled a bit to see your last-minute, bid-sniper-style entry into the contest.
I just wanted to mention... I could be wrong, but I believe the Vapor bricks have a lower current limit than the bricks in the higher performance micros, and won't be able to run anything but a Vapor motor. You might want to check into this.
Cheers,
Dave
BrundleFlyBy is offline Find More Posts by BrundleFlyBy
Old May 01, 2013, 05:35 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Phil,
You should be able to come in at around 30-35 grams with that one and a Vapor brick and 7 mm motor unit should be fine. I run the 7 mm unit, and 5x3 GWS prop on the old Vapor bricks I have without problems. Since even the Mini Vapor brick can handle them (I've read) I can think of no reason the bigger brick won't.
I'm looking forward to seeing how this goes. It's my sort of plane and I like that you're sticking with the original build style.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old May 01, 2013, 05:58 PM
Ken USA is offline
Find More Posts by Ken USA
United States, IN, Hammond
Joined Jan 2013
I'm looking forward to seeing this one fly. It looks great
Ken USA is offline Find More Posts by Ken USA
Old May 01, 2013, 11:31 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Thanks guys. This will be fun. I subscribed to the contest thread a couple of weeks ago and hemmed and hawed. I will double check the specs on my brick. Specifically it's from a night vapor. I will start updating when I start building, but it may be a while on that as I have one to finish first and family visiting next week to put a kabosh on the build time!
Old May 27, 2013, 08:31 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
So Pete, can you point me to one of these 7mm motor units that will plug into the night vapor brick?
Old May 28, 2013, 02:10 AM
Norfolk, England
Joined Sep 2001
HK list one, but it comes without a plug. If I can solder one on, anybody can. If you don't like soldering, and don't mind a heavier, faster model, go with a P-51 or Champ motor unit.
Pete
Old May 28, 2013, 09:13 AM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
I guess I'm a dummy because I don't see that on Hobbyking.com... what should I search for?
Old May 29, 2013, 02:27 AM
Norfolk, England
Joined Sep 2001
Here you go mate. It's under motors, on gearboxes and parts.
http://www.hobbyking.com/hobbyking/s...box_GPS_7.html
Pete
Old May 29, 2013, 09:44 AM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Ah, thanks Pete. I searched their site twice and even tried their CS chat with no luck. I picked up the motor and gearbox for the Parkzone P51 but at 8.5mm it seems overkill for this airplane. I will order the HK 7mm and save the P51 motor for a future project.
Old May 29, 2013, 10:13 AM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
My name is Phil, and I am a pin-aholic.
This stabilizer is not going anywhere!
Old May 29, 2013, 06:55 PM
cd_webb is offline
Find More Posts by cd_webb
United States, AR, Hope
Joined May 2009
Yep, I'd say she's "stuck".
cd_webb is offline Find More Posts by cd_webb
Old Jun 13, 2013, 04:24 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
I've been busy
I finished my other build of Peter Rake's 12" Farman Parasol and it was a great success, so I am stoked to finish this Pitcairn. The rudder was framed (yes I used lots of pins), then hinge points for the sewn hinges as well as a plate to hold the control horn were added. The tail feathers were lightly sanded and covered in the kit supplied tissue.
Old Jun 13, 2013, 04:35 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Next came the fuselage, built in a standard manner. I thought that it might be tricky due to the roughly triangular cross section up front, but it came together very well, and very straight!
Since I will just attach the motor with epoxy, I decided to add a little depron to the firewall, to give it some depth to hold the motor securely using less glue.
I also, on a whim, added some cardstock to the inside of the nose. I was thinking this would be helpful to attach the brick and battery tray. This remains to be seen and I may end up removing some of this later on.
Old Jun 13, 2013, 04:39 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
I like the plans, but I'm surprised that no CG is given!
Contest BBCC 2 - Trenton Terror - NOW BBCC 3 pulserudder Balsa Builders 43 Nov 04, 2013 01:28 PM
Build Log BBCC 2 - Guillow's Arrow - BrundleFlyBy BrundleFlyBy Balsa Builders 156 Oct 21, 2013 07:04 PM
Build Log BBCC-2-Guillow's P-40 RC Conversion- Scotty909 scotty909 Balsa Builders 25 Jul 20, 2013 09:35 AM
Discussion BBCC-2. "Twelve" CL to RC KenUSA Ken USA Balsa Builders 0 Mar 27, 2013 05:47 PM
Discussion Randy"s Turn on the PCA-2 Pitcairn randynsaudi Auto Gyros 50 Jun 19, 2011 02:47 PM
