Old Jan 12, 2004, 04:53 PM
temp_oct is offline
Find More Posts by temp_oct
I told them, I was drunk.
temp_oct's Avatar
Bangkok, Thailand
Joined Aug 2003
Next best thing to solite?
I've finished my first balsa (Miniflash). It has Solite covering by most. I could say it is pretty easy to work with and I'm impressed with the quality of the covering.
However, there are two thing to concern;
1. The 'solid' color is not so solid. It's a little transparent. (I use the white one)
2. It is so shinny!
Both are definately the right things for Miniflash, but my next project will be a warbird. This won't look so right with those attributes.
So, what is the good alternative to solite with more 'solid' and 'dull' finish? I really don't wanna spray over some dull finish . 1-step solution would be nice if possible .
temp_oct is offline Find More Posts by temp_oct
Old Jan 12, 2004, 05:35 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Maybe LiteSpan (sinthetic silk) ???
You may want to contact a moderator to have the title of this thread changed to 'Matte finish alternative for Solite?' or some such...
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 12, 2004, 05:47 PM
temp_oct is offline
temp_oct's Avatar
Bangkok, Thailand
Joined Aug 2003
Thanks Gene.
I've used Airspan on some part of my Miniflash, but the color is not solid (about the same as Solite), but it has 'dull' finish. Is Litespan thicker? How's the weight w/ Balsaloc applied?
Do you have any pix of the the covering job from this Litespan?
Old Jan 12, 2004, 06:13 PM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
Try oracover from www.hobby-lobby.com it is three times heavier than Solite but seeing that you don't use that much to cover a plan the size of a typical parkflyer - they weight doesn't add up that much. Compared to other covering it is very light weight - just heavier than Solite. From reading about everyone else using Solite, the oracover is easier to work with and doesn't suffer the same bad habbits that Solite does.
Give it a try.
cadconversions is offline Find More Posts by cadconversions
Old Jan 12, 2004, 06:40 PM
temp_oct is offline
temp_oct's Avatar
Bangkok, Thailand
Joined Aug 2003
Is it available in matte finish?
I searched the forum and found only the glossy one. Do they make matte finish?
Old Jan 12, 2004, 07:36 PM
Stevens AeroModel is offline
Find More Posts by Stevens AeroModel
Truss-Loc Monkey
Stevens AeroModel's Avatar
Colorado Springs, CO
Joined Feb 2002
I remember reading that there was a chemical you could use to dull solite but it was not readily availiable in the states.... The olive drab / silver / black / white / and cream are all good warbird colors if you can dull the finish. Perhaps someone remembers what this chemical was?
-Bill
Stevens AeroModel is offline Find More Posts by Stevens AeroModel
Old Jan 13, 2004, 02:20 AM
Shawn Davis is offline
Find More Posts by Shawn Davis
Little Rock,AR,USA
Joined Jun 2001
I like shopping bags, comes in all kinds of colors. Ues the thin
krinky sounding, briddle ones. I have found that they are a bit
stronger and the stuff is lite and free!
Shawn Davis is offline Find More Posts by Shawn Davis
Old Jan 13, 2004, 03:34 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
-Bill
In this thread Tim references a product called Prymol in the UK. Is this what you're thinking of, Bill? I wonder if it's available on this side of the pond.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jan 13, 2004, 04:06 AM
fixwingagain is offline
Find More Posts by fixwingagain
fixwingagain's Avatar
Boise Gowen Fld, Idaho, United States
Joined Feb 2003
I am getting ready to cover my first set of wings and was shocked by the sheen.
I was wondering if anyone has tried sanding with a fine grain. Oracover that is. I am unsure of the other films having never seen them before.
fixwingagain is offline Find More Posts by fixwingagain
Old Jan 13, 2004, 06:01 AM
OhioMike is offline
Find More Posts by OhioMike
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
I read in a past issue of "Flying Models", an article that i dont want to quote in case the info was wrong? That Litespan and Airspan are no longer marketed per se...That they were bought out by coverite and are now marketed totally as coverlite? Has anyone else heard this as well?
OhioMike is offline Find More Posts by OhioMike
Old Jan 13, 2004, 07:35 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Try some 00 steel wool on some scrap. It works on monocote.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jan 13, 2004, 08:39 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
SoLite can be painted, Roy Walton has been painting SoLite for quite some time with great results. He says the Krylon Fusion works well.
If you like the color of the covering but just want to change the sheen, try spraying a coat of clear matte coating on it.
As for the translucency of the "solid" colors, not much to do about that other than going to different covering. White and yellow are quite translucent, black and dark blue are not. It's never bothered me, but I don't model scale stuff.
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 13, 2004, 09:17 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
If you fancy taking the gloss off a 'film covering, you'll get a more uniform finish if you do it to the 'film before applying it to the model.
One route to a pinted finish is to cover your model in a document laminating film - 'Doculam' is one brand name. This stuff is clear, but takes paint well and is cheap too.
I've sprayed Doculam with Krylon - didn't even bother cleaning one piece and I couldn't even sand the paint off
D
Dereck is offline Find More Posts by Dereck
Old Jan 13, 2004, 10:58 AM
Truss-Loc Monkey
Joined Feb 2002
Yep that's the critter. Thanks Martin I have heard rumors that it is not avail. on this side of the pond. Would love to be proved wrong as I have some projects I'd like to try it on.
-Bill
Martin
Discussion This is amazing. Not rc but next best thing. Bilbobaker Other Websites 0 Jan 30, 2007 11:08 PM
Discussion Next best thing to FPV? JMSTECH FPV Talk 3 Jan 19, 2007 08:29 AM
Poll the next best thing? wilton0 Micro Helis 17 Feb 26, 2006 12:34 AM
Next best thing genovia Parkflyers 2 Feb 24, 2002 03:45 PM
Next Best Thing to a SKAT? kepople High Performance 46 Oct 16, 2001 08:38 AM
