Old Apr 29, 2013, 08:42 PM
kgd1 is offline
Find More Posts by kgd1
kgd1's Avatar
United States, NJ, Plainsboro Township
Joined Aug 2009
Gaui X3
:This will be my next 450/480
http://www.rcmania.hk/portal.php
kgd1 is offline Find More Posts by kgd1
Old Apr 29, 2013, 11:10 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Good choice by the looks of it! I bet quality will not be an issue.
I really like the design. Its a bit more conventional compared to the warp360 but somehow i like the Gaui better. I think due to the battery placement.
The TT does seem correctly engineered. i'm more of a belt-guy but i would not hesitate to give this a try. The tail slider should work really well.
I already got a mini-Protos as a upgrade from the trex style 450, otherwise this heli would be #1 on the "to get" list.
Any word out for prices of the kit?
sp00fman is offline Find More Posts by sp00fman
Old Apr 30, 2013, 05:14 AM
Tomcoleman is offline
Find More Posts by Tomcoleman
Joined Mar 2013
whats the release date?
Tomcoleman is offline Find More Posts by Tomcoleman
Old Apr 30, 2013, 01:43 PM
fishfiend is offline
Find More Posts by fishfiend
Joined Jun 2008
You don't need any more helis....
fishfiend is offline Find More Posts by fishfiend
Old Apr 30, 2013, 07:39 PM
kgd1 is offline
kgd1's Avatar
Joined Aug 2009
Not yet.
Sometime in July
LOL
Old May 01, 2013, 04:17 AM
Joined Mar 2013
just 1 more
Emil was intrested in it
Last night i got sign off on a Goblin 500
Old May 01, 2013, 06:59 AM
Joined Jun 2008
just 1 more
You have a disease. ..
Old May 01, 2013, 10:41 AM
Joined Mar 2013
i like this disease
Old May 04, 2013, 05:15 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
what's the specs? Main blade length?
pitchp is offline Find More Posts by pitchp
Old May 04, 2013, 05:20 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
http://www.flying-hobby.com/shop/gau...t-p-11787.html
425 - 460mm mains
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old May 04, 2013, 05:29 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Originally Posted by Dejavu*Xion View Post
Dej, that's the x4. kgd1 mentions on his heading Gaui x3. I'd like to know the specs please for the x3
Old May 04, 2013, 07:20 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
Here is the spec and main blade is 325mm. Also, main shaft is 6mm, spindle shaft 5mm, tail shaft is 4mm, different from traditional 450. also, it has 3 holes on pitch control arm,..
http://www.rcmania.hk/article-1182-1.html
look like Gaui put a lot improvement on X3, I can't wait for release day, hopefully in July...
wlee1017 is offline Find More Posts by wlee1017
Old May 19, 2013, 11:07 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Really nice heli from what I can see. A couple of upgrades would be a CF tail pushrod and turnbuckle pitch pushrods. I don't like the little circlip you need for the battery tray locking. Hopefully someone will come up with a better method.
Nice features are the slide in battery, slant main gear, good space for Rx/FBL unit, three bearing main, all shafts are oversized, micro or mini tail servo and the tail control assembly, which should be near slop free, but I'm not sure if I like the idea of threads in the tail pitch slider pulley.
I also hope it has thrust bearings in the tail.
Some good pictures here:
http://www.helifreak.com/showpost.ph...1&postcount=39
beenflying is offline Find More Posts by beenflying
Old May 20, 2013, 04:33 PM
Need More PURPLE !!
Joined Aug 2012
Oooopppsss.... My bad .
I seem to have X4II on the brain lately.
Thanks for the pics Bflying..I think as time goes on i will be buying Gaui over Align. Aligns quality is good. But the step up to a " bit" better is welcomed in Gaui.
Also looks as if the "long" 6s 1300mah paks will fit, Yes ?
Old Jun 16, 2013, 11:26 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It looks like the X3 is going to have mini servos on cyclic:
GAUI X3 prototype testing. Team GAUI Alvin Chai. (2 min 36 sec)
GAUI X3 testing. Prototype. Full CNC upgrade parts. 3S 2200mah. Mini servo cyclics, Mini or Micro tail servo. 3100 HS. CAPABLE running 350mm blades
For Sale Fioroni Torsen X3 for mp777 noamganot Cars - Accessories (FS/W) 1 May 02, 2013 04:30 PM
Sold 75.00 Gaui GU-344, Scorpion Motors & Gaui ESC's from 330X knichefilms Aircraft - Electric - Multirotor (FS/W) 7 Mar 14, 2013 02:46 PM
Sold x3 E-flite 25amp Pro ESC (x3) $30 shipped each ton2di Aircraft - Electric - Power Systems (FS/W) 0 Jul 29, 2012 10:35 PM
Sold 800mAh 3s lipos x3 - Gaui brand radiohead Aircraft - Electric - Batteries & Chargers (FS/W) 5 Aug 14, 2010 01:16 PM
Sold Lot of micro servos: S3154 (x4), S-75 (x4), HS-65MG (x3), HS-56HB (x3) FrankW Aircraft - General - Radio Equipment (FS/W) 8 May 03, 2009 08:33 PM
