Old Apr 29, 2013, 01:12 PM
Saqueeb is offline
Find More Posts by Saqueeb
Saqueeb's Avatar
United States, MN, South St Paul
Joined Dec 2011
FPV goggles
hello, i'm thinking of getting some goggles for my fpv, for now i have been using a homemade head mounted display and a LCD on my GS.
First is it possible to just connect the goggles to my 1.2 rx video out?
second if i were to purchase some that come with the 5.8 system can i simply run the Vout from my 1.2rx to the Vin on the 5.8tx and then get the video signal in the goggles form my 1.2 system that way? cord free basically?
finally what is a good setup with 640x480 minimum around 300.00 or less?
thanks!
Saqueeb is offline Find More Posts by Saqueeb
Old Apr 29, 2013, 01:14 PM
Qnzkrew is offline
Find More Posts by Qnzkrew
United States, RI, Cumberland
Joined Mar 2008
http://www.readymaderc.com/store/ind...ex&cPath=11_22
Qnzkrew is offline Find More Posts by Qnzkrew
Old Apr 29, 2013, 02:42 PM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
First is it possible to just connect the goggles to my 1.2 rx video out? Yes
second if i were to purchase some that come with the 5.8 system can i simply run the Vout from my 1.2rx to the Vin on the 5.8tx and then get the video signal in the goggles form my 1.2 system that way? cord free basically? Yes, and this is what I do.
For <$300 the Fat Shark Predator V2 is a all around good starter set, thats just my opinion.
thanks!
Hope this helps
Wrice4 is offline Find More Posts by Wrice4
Old Apr 29, 2013, 03:02 PM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
thank you that does help!!
now one more question.
is the 5.8 system worth it to get the predators, or am i better offjust wiring in and using the dominators?
it sounds like the dominators have a much better picture.
thanks
Old Apr 29, 2013, 03:26 PM
Wrice4 is offline
Wrice4's Avatar
Joined Nov 2012
thanks
The dominators have the best picture out of all the Fat Shark goggles. I chose the Attitudes instead because they have a slightly less picture quality, but have a 35 degree FOV, adjustable IP, and have headtracking built in. Althought i have never used the heatracking, it is still an option if I ever want to.
I started out on 5.8. Loved it. The only reason I moved to 1.3 is because of penetration. When I got my quad I flew low and so I needed a stronger signal for behind objects. So I fly 1.3 and use my 5.8 as a relay to wirelessly send my signal back to my goggles.
5.8 is a great system to start on or for people that have been fpv-ing for 10 years. Nothing wrong with 5.8. It has the best picture out of all the freq, and can still go longer range with the right setup. Just make sure that you have a clear line of sight between the vtx and vrx.
Check out fat sharks website for a chart that has all of the goggles on them and a comparason.
Old Apr 29, 2013, 06:10 PM
c131frdave is offline
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
The Boscam goggles have 5.8 and 2.4 built in. Plus head tracking. Video in and out. I like mine, but they are the only pair of goggles I've ever had, so...
c131frdave is offline Find More Posts by c131frdave
Old Apr 30, 2013, 12:16 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Just keep in mind the band restrictions. Fat shark w buit in Rx only receive from ImmersionRC and airwave type vTx. Boscam/fox tech goggles w built in Rx receive from a much wider range of vTx. I have old fatshark base goggs which suck, and the Boscam AIO goggles which rock.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Apr 30, 2013, 02:53 AM
fatshark is offline
Find More Posts by fatshark
fatshark's Avatar
Shenzhen, China
Joined May 2007
Well, not really a fair comparison as the BASE goggles were in production before Boscam and most of the world even knew what FPV was. Lets at least acknowledge that the goggles you are using as a bench mark for Fat Shark quality are out of production and been replaced by newer models. Sure, in retrospect the BASE goggles could've been designed better, but at the time there were no other products for me to reference. The Attitudes have proven to be a very popular goggle.
Fat Shark
fatshark is offline Find More Posts by fatshark
Old Apr 30, 2013, 08:34 AM
Wrice4 is offline
Wrice4's Avatar
Joined Nov 2012
Fat Shark
I love my attitudes. Wouldn't trade them for anything.
Old Apr 30, 2013, 08:40 AM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Fat Shark
So the current Base SD goggles sold at hobbyking still uses the same optics as the first gen? I would have thought they've upgraded the LCD and lenses Am planning on getting an LCD monitor initially and eventually upgrading to a baseSD.
Hajile is offline Find More Posts by Hajile
Old Apr 30, 2013, 08:47 AM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
so the boscams look like they are 370.00+ that is a good amount of $$ for just the goggles, where as the altitudes are 360.00 and that comes with the 5.8 system included.
now it seems that the boscams may have a better picture, but is it ~100.00 better??
i ask because if it is, then i dont have an issue spending the extra $$. for those who have used them how would you rate in order of best to worst image quality:
boscam, dominator, altitude.
thanks!
Old Apr 30, 2013, 10:50 AM
fly by night
Joined Sep 2011
Boscam only come with both 5.8 and 2.4 rx built in. Also head tracker is std.
It is true the newer top model Fats harks have great image quality, similar to the Boscams. Ideally try them all as there are FOV differences. Iirc the attitude have wider FOV which some prefer and others do not prefer.
I had to rewire my Boscams due to weak connectivity. I do not know what FS wiring is like these days
Ideally some day maybe someone will offer a gogg with multi band vrx, unlike today.
Old Apr 30, 2013, 01:34 PM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The only thing I dislike about my FatShark Dominators are the colors are grayish. I prefer vivid colors. Other than that, I can't say a single bad thing about them.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Apr 30, 2013, 01:49 PM
Too many numbers
Joined Oct 2010
thanks!
This isn't correct. They come with BOTH 2.4ghz and 5.8ghz receivers, and head tracking. And if you go to Hobbyking and click on them- and wait for a few minutes for the "one time offer" window to pop up, they are $348.
Old Apr 30, 2013, 02:15 PM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
but i still need a Vtx.... i am running 1.3ghz....so i would need a 5.8 or 2.4 vtx also....
i'd have to say at this point i'm leaning toward the dominators, + a 5.8 system to put in them. (but no one has them in stock) or the Attitudes that come with everything.....but sound to have worse image quality??? i just have a hard time spending ~500.00 on a wireless goggle solution.
and i do not plan on using the head tracker.
Sold Headplay Goggles with FPV-plastics goggle mod and RV Liberator protector. capn FPV Equipment (FS/W) 4 Mar 20, 2013 01:05 PM
Sold FPV Goggles NEW. Vuzix 310XL Video goggles with iPad adapter jasper7821 FPV Equipment (FS/W) 2 Feb 09, 2013 12:50 PM
Sold PRICE DROP! I-scape II FPV goggles. Perfect starter goggles!! kicekilla FPV Equipment (FS/W) 8 Oct 26, 2012 06:47 PM
Sold I-scape II FPV goggles. Perfect starter goggles!! kicekilla FPV Equipment (FS/W) 0 Sep 10, 2012 04:37 AM
Sold Headplay Goggles in Rob's FPV Plastics & Goggles!! - LPU EyeFlyPlanes FPV Equipment (FS/W) 5 Oct 30, 2011 11:02 AM
