RangeVideo MicroPNT & MiniPNT
RangeVideo has introduced a new line of pan and tilt heads designed around the KX1, KX2, and KX6 fpv cameras.
A lightweight and aerodynamic pan/tilt for your fpv platform
RangeVideo has introduced a new line of pan and tilt heads designed around the KX1, KX2, and KX6 fpv cameras. The Micro PNT for the KX1/2 cameras, weighs in at only 33 grams with the camera. The Mini PNT for the KX6 camera weighs in at 77 grams with the camera. They are available in either translucent red and black, and include servos.
Micro PNT Specs:
  • Unique streamlined design
  • Designed for the popular KX2 camera (micro) and KX6 camera (mini)
  • Very low drag coefficient
  • Extremely compact and robust design
  • No external cables
  • 120 degree pan servo included
  • 120 degree tilt servo included
  • Weight: ≈22 grams (including KX2) or 77 grams (including KX6)
  • Mountable options:
  • On top of air frame
  • Hanging under air frame (between landing gear)
  • Pointing forward (Roll & tilt function)
Link to product website
Rangevideo pan and tilt head for KX2 and KX6 FPV cameras (0 min 36 sec)
Old Apr 29, 2013, 11:50 AM
AtTheCross is offline
Find More Posts by AtTheCross
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
very kewl
AtTheCross is offline Find More Posts by AtTheCross
Old Apr 29, 2013, 12:29 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Nice and Compact! That smaller (micro) KX2 Cam can be powered 5v-12v (great option).
rclab1 is offline Find More Posts by rclab1
Old Apr 29, 2013, 01:20 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Will RMRC cameras be able to fit in these?
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Apr 29, 2013, 02:28 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
The larger PnT will probably fit some cameras, check rangevideo website for KX-6 (mini PnT) and KX-2 (micro PnT).
boopidoo is offline Find More Posts by boopidoo
Old Apr 30, 2013, 01:30 PM
corsair2014 is offline
Find More Posts by corsair2014
United States, TX, Cypress
Joined Jan 2012
could it fit the Turnigy Micro fpv cam from Hobbyking?
corsair2014 is offline Find More Posts by corsair2014
Old Apr 30, 2013, 01:36 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
They are designed around specific cameras: the KX1, KX2, and KX6. If your camera in question has the same dimensions as those listed, then you're in luck. If not, then you might persuade it to fit with some hacking, but to be honest I can't say. This PNT is brand new and not been out in the public long enough for people to test fit other cameras.
Matt
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Apr 30, 2013, 09:31 PM
Tuk is offline
Tuk
Find More Posts by Tuk
Tuk
Joined Oct 2012
Add
Tuk is offline Find More Posts by Tuk
Old May 11, 2013, 04:10 PM
Cyberdactyl is offline
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
One of the potential problems that worry me with these new mini gimbals like this one and the upcoming gimbal for the Foxtech V2 and V3, is the large moment put on the servo shaft in any sort of moderate to hard landing.
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old May 11, 2013, 04:27 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
If you hit something, incl the ground hard enough to damage a servo shaft that will probably be the least of your concerns
I had a 0420 sitting on those $3 servos for many flights, even had some abrupt stops with no issues
picard10th is offline Find More Posts by picard10th
Old May 11, 2013, 06:47 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Agreed. With this unit, I think that's a non issue...
Administrator
Old Jun 14, 2013, 04:39 AM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
I just received my Micro PnT... Design is perfect, nice and compact, only a little heavier than it may be. Camera (KX2) is not that good, worst are those black margins in corners, but still it's usable (any idea for replacement lenses?). But man, what is killing this are those servos. Camera movement is very jumpy, movement with headtracker is unnatural, you can almost count those movement steps - ek-ek-ek-ek...
And don't be fooled by "120 degrees" description on RVOSD website - they are standard 90 degree servos, which range can be extended on receiver to 120 degree.
I'm quite dissapointed, without replacing servos is this PnT useless... Can anyone recommend better ones which will fit?
Rastislavko is online now Find More Posts by Rastislavko
Old Jun 14, 2013, 08:11 AM
Joined Mar 2011
I'm assuming they are analog servos?
If so, just get a similar torque rating and physical size digital. Should at least double the resolution and fidelity of movement
Old Jun 15, 2013, 02:20 PM
Joined Jun 2006
There are absolutely no marking on them, but yes, they don't sound like digital. I'll try to find some..
Old Jan 24, 2014, 05:35 AM
Dionysos is offline
Find More Posts by Dionysos
Singapore, Singapore
Joined Apr 2012
Thumbs up boopidoo.
I love it. Will get one for my new glider in combination with the kx6 and a fatshark trinity tracker.
Real nice design.
I m just curious about the play...
Dio
Dionysos is offline Find More Posts by Dionysos
New Product RVJET RangeVideo Flying Wing boopidoo FPV Aircraft 3528 May 26, 2016 03:46 PM
News RangeVideo RVJET Flying Wing awagar FPV Talk 0 Mar 08, 2013 09:50 AM
Sold RangeVideo 1.3 800mw FPV System Camelboy FPV Equipment (FS/W) 4 Feb 07, 2013 08:24 PM
Sold RANGEVIDEO 5.8 400MW FPV almost new! Camelboy FPV Equipment (FS/W) 2 Feb 06, 2013 08:16 PM
For Sale NIB DPCAV 900Mhz Rx and Slightly used Rangevideo 900Mhz Rx ek123 FPV Equipment (FS/W) 0 Jan 20, 2013 06:39 PM
