Old May 03, 2013, 04:40 AM
Olivier_C is offline
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Since DJI ESCs are Optos with no BECs, you leave it all plugged, no need to remove the V+.
Olivier_C is offline Find More Posts by Olivier_C
Old May 05, 2013, 02:55 AM
DWA is offline
DWA
Find More Posts by DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
United States, CA, Mission Viejo
Joined Dec 2004
Some amazing aerial videos here.
http://www.dji-innovations.com/showcase/
Dave
DWA is offline Find More Posts by DWA
Old May 05, 2013, 08:10 AM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Originally Posted by gspence View Post
Hello! I have an F550 with DJI motors and ESC's that is only a few weeks old. I've had a problem with it from the very beginning. I've posted a video that shows the issue in flight. It sounds like a motor or ESC problem but I can't tell which one or how to troubleshoot the issue. I'm a pretty proficient solderer so I'm about 99% sure its not a cold solder joint. I've checked all the bullet connectors to see if any are loose as well. I'm using the Naza with GPS so I don't think its a config issue. The ESC's don't need to be calibrated (according to DJI) so I'm not sure what to try next. It could be a bad motor or ESC but I wanted to see if anyone else has experienced this.
Thanks!
http://www.youtube.com/watch?v=bEkmnqGotmI
That sounds like a broken arm, or a bad motor to me. The noise you hear could be from a vibrating crack in an arm, or a couple motors fighting each other and causing rpm differential noise. Flex your arms a little and look for cracks. Take the motor, and try to wiggle the outer casing separate from the inner and see if there is any play. Double check all your screws. That vibration you are hearing is driving the FC mad.
I had a bad motor from DJI, when I grabbed the outer part of the motor and wiggled it, it would make a clicking sound. Putting replacement bearings in did not help. I had to swap the motor, then my quad flew 100 times better.
antslake is offline Find More Posts by antslake
Latest blog entry: FAA registration
Old May 05, 2013, 11:06 PM
gspence is offline
Find More Posts by gspence
gspence's Avatar
United States, CA, Escondido
Joined Mar 2013
I think you may have pinpointed the problem. The arms are brand new and I've never had a hard landing or crash, so I'm about 99% sure its not a cracked arm. However, when you mentioned a clicking sound from a motor when you wiggled it, that jogged something in my brain that I remembered that happening. So I went back and wiggled all my motors and found one that had a small click to it like the outer case moved a bit when wiggling. The other 5 motors had no play in them at all. So perhaps this tiny thing is whats causing it.
I talked to the store today where I bought it and they said they'd be happy to look at it and help me troubleshoot it if I can come in on Tuesday when their 'quad guy' is there.
Hopefully this will resolve it because I really want to get this thing flying!
gspence is offline Find More Posts by gspence
Old May 05, 2013, 11:10 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
What did you remember? LOL.
If you have a watt meter, you can disconnect all the motors by unplugging them from the ECS, and test one at a time with a prop and see what amps it is drawing. If the one making the clicking sound is significantly higher than the others, that would be it. Even still, that motor could have magnets rubbing inside causing interference.
Old May 05, 2013, 11:46 PM
scsurfer is offline
Find More Posts by scsurfer
Joined Apr 2013
Yes, these are the stock DJI 10" props and I'm running a 3S battery as they suggested for that prop size.
The props could be out of balance. Even if new. You can get a balancer for $25
And use tape on the under side of the prop. Mine where all out of wack and fixed the problem.
scsurfer is offline Find More Posts by scsurfer
Old May 06, 2013, 12:16 AM
gspence is offline
gspence's Avatar
Joined Mar 2013
What did you remember? LOL..
I remembered a few days back when I was messing with the motors that one of them had a slight little click when I wiggled it. At the time I didn't think that would be a big enough deal to cause the problem.
Old May 06, 2013, 02:35 AM
Ombra is offline
Find More Posts by Ombra
Canada, BC, Vancouver
Joined Apr 2013
I know this is an owners thread, and hopefully I'll be an owner of one as well but...
What is the cheapest price that one can find a legit dji flamewheel? I stumbled upon this when I was on my phone, but hate making mobile payments and by the time I was home they were all sold. Are prices like this common, or should I just settle for one in the 350-400$ price range?
http://www.ebay.ca/itm/151034607530?...ht_2246wt_1393
Ombra is offline Find More Posts by Ombra
Old May 06, 2013, 04:25 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
$238 for the full kit. That is a low price. I payed $322 at my LHS.
Old May 06, 2013, 05:05 PM
Ombra is offline
Joined Apr 2013
So I shouldn't hold my breath to find another one that low?
Old May 06, 2013, 10:37 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
I would say no, I wouldn't. I would even be a little nervous buying it from someone at that low of a price, wondering if it is legitimate.
Dave
Old May 07, 2013, 12:00 AM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Did you call the guys I sent you a pm about? Not sure what the 550 goes for but I paid $170 in store for my 450. Power hobby. One arm more cant cost that much.
Old May 07, 2013, 12:45 AM
Ombra is offline
Joined Apr 2013
Checking their website it looks like they only sell the frame for the f550, though I may have to just settle for a f450 to begin with and splurge on a better tx or other accessories that I save by getting a cheaper frame. I'll give them a call in the morning and see what they have to say.
Old May 07, 2013, 01:06 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
I have a 450 and a 550 and I think the 450 is more fun to fly. The 550 can lift more weight though. It is more of a work horse for me. However I have seen videos of guys flying a 550 like a acrobat in manual mode.
I think you would be happy with either.
Dave
Old May 07, 2013, 02:16 PM
toxotis70 is offline
Find More Posts by toxotis70
Joined Mar 2008
i just tried to balance my 10x38 props (DJI) with durbo balancer…. but there is a problem!
The holes in dji props (10x45 and 8x45 also) are not circular on both sides…. so its not a perfect match in the durbo stick… so how can anyone balance dji props ?
toxotis70 is offline Find More Posts by toxotis70
Discussion Dji Flame Wheel F450 Venom93corba Multirotor Talk 39 Jun 13, 2016 07:16 AM
Help! Flame Wheel F450 / F550 NAZA with Spektrum DX8 AR8000 setup assistance jasper7821 Multirotor Talk 18 Feb 10, 2015 04:23 PM
Sold Dji flame wheel f450 arf kit (w/motors, esc & props) Angry Bird Aircraft - Electric - Multirotor (FS/W) 2 Apr 01, 2013 06:30 PM
Sold DJI F550 Flame Wheel with DJI Motors & DJi 30amp ESCs & Props peaksview Aircraft - Electric - Multirotor (FS/W) 2 Jan 22, 2013 09:53 AM
Sold X468 XT Flame Gear Gimbal For DJI F450 or F550. Sale or trade for Naza GPS. vacahtu Aircraft - Electric - Multirotor (FS/W) 3 Nov 09, 2012 06:57 PM
