Old May 01, 2013, 08:28 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
DJI 450 Compass Configuration
Just need a little help please... I'm reading this Chinglish manual from DJI on the topic of my compass configuration and it is kind of fuzzy. I'm setting up a F450 with GPS and the X, Y & Z coordinates Where the top plate meets the arms are where most of the pilots are putting their GPS Compass, using the center of the Quad as your Center of Gravity and Assuming using -10 as a constant Z value, Would placing the GPS unit in either of these 4 corners using these coordinates be correct? Top right I figure is (1). X=3, Y=3, Z=-10... (2). Top Left X=-3, Y=3, Z=-10... (3). Bottom Right X=3, Y=-3, Z=-10...(4). Bottom Left X=-3, Y=-3, Z=-10...Any help is appreciated...I'm looking at these as points on a Cartesian Plane with 0,0 as my CG!! Thanks!
ZACATTACK is offline Find More Posts by ZACATTACK
Old May 01, 2013, 09:01 PM
RDTague is offline
Find More Posts by RDTague
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
Originally Posted by DWA View Post
Thanks I just placed an order. I will use this on my 450 and the aeroxcraft on my 550.
I do feel a bit concerned buying from a company called "goodluckbuy". Like I will be lucky if I get it, so we wish you good luck.
Dave
Dave, I felt the same exact way. In so fact, I done a ton...A TON of forum searching to see what their rep was. And I'd say 98% had NO problems at all...and the other 2% was slow shipping. However, their orders were in the middle of the Chinese New Year, in which every bodies order was slow.
I paid with Paypal, via a credit card, just in case problems did come up, I had 2 options to file complaints with. As it turns out, I will order from them again. ORder confirmation within 2 hrs...email with tracking # with 15hrs...follow up email 1 1/2 days later telling me to expect delivery within 24hrs. Heck, I can't get that from an Ebay seller 1 state away! I rec'd my order in less time than it takes for UPS or USPS to deliver 100 miles away...and GoodLuckBuy is on the other side of the freaking planet!
I did weigh mine. However, I did not take the 2 axis gimbal and fpv Tx off. The total weight was 395g.
RDTague is offline Find More Posts by RDTague
Old May 01, 2013, 09:42 PM
gspence is offline
Find More Posts by gspence
gspence's Avatar
United States, CA, Escondido
Joined Mar 2013
Hello! I have an F550 with DJI motors and ESC's that is only a few weeks old. I've had a problem with it from the very beginning. I've posted a video that shows the issue in flight. It sounds like a motor or ESC problem but I can't tell which one or how to troubleshoot the issue. I'm a pretty proficient solderer so I'm about 99% sure its not a cold solder joint. I've checked all the bullet connectors to see if any are loose as well. I'm using the Naza with GPS so I don't think its a config issue. The ESC's don't need to be calibrated (according to DJI) so I'm not sure what to try next. It could be a bad motor or ESC but I wanted to see if anyone else has experienced this.
Thanks!
DJI F550 + Naza GPS and Motor/ESC problem (0 min 0 sec)
gspence is offline Find More Posts by gspence
Old May 01, 2013, 10:46 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
Suggestions on props and battery for F450/phantom hybrid.
I don't have an exact weight of my rig...but best I can figure from piecing the individual weights (and going a little on the heavy side), she weighs about 1550g with stock 10" 1038's and a 3S 2250 pulse battery(170g) (photos are on the previous page of her all dressed up ready from Prom). With normal flying (no full throttle, tricks or anything) best I can get is 4:30-ish mins. And when the red light starts blinking...it's "get her down right now or BAD things are going to happen!!!")
Should I go with 2 - 3S 2250mah's or 1 - 3S 5500mah or 4S?
Suggestions on props, too, please!
Main use is video and photos.
Old May 02, 2013, 12:23 AM
peter_sd is offline
Find More Posts by peter_sd
Joined Apr 2013
Thanks!
http://www.youtube.com/watch?v=bEkmnqGotmI
Check these settings mine was surging untill i changed these
F550
Basic Gain
Pitch Roll Yaw Vertical
170 170 150 140
Attitude Gain
Pitch Roll
170 170
peter_sd is offline Find More Posts by peter_sd
Old May 02, 2013, 01:10 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Sheesh, electric motors shouldn't sound like that. Are you using the stock propellers? They're pretty awful, maybe vibrations are messing with the flight controller or something. I've only had to fight a quad once and that was due to vibrations.
WiseDuck is offline Find More Posts by WiseDuck
Old May 02, 2013, 01:36 AM
gspence is offline
gspence's Avatar
Joined Mar 2013
F550
Basic Gain
170 170 150 140
Attitude Gain
Pitch Roll
170 170
I'll give those settings a try and see if it makes any difference.
Old May 02, 2013, 01:37 AM
gspence is offline
gspence's Avatar
Joined Mar 2013
Yes, these are the stock DJI 10" props and I'm running a 3S battery as they suggested for that prop size.
Old May 02, 2013, 08:27 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Yep thats correct, X>0 is front, Y>0 is right side, and Z<0 is above.
But don't be too picky about the exact values, its not that critical, I made tests once with wrong values and it didn't change much...
Thanks!
Quite unstable for sure, I'd go with WiseDuck and would suspect a bad case of vibration.
If the NAZA firmly dual-taped to the frame ?
Are all props free of defects, visually ?
Is it flying the same without the GPS ?
Or if you doubt a motor or ESC, to troubleshoot on a x6 you can make it fly as a quad, you can unplug the right and left ESCs+motors (or front and rear if its a +6 layout), and it will fly just fine, and thus you can isolate a bad motor.
I'd go for 3S-4000mAh, up to 5000mAh, or 4S-3000mAh (the new DJI props 10x3.8 + DJI motor can fly under 4S).
Olivier_C is online now Find More Posts by Olivier_C
Old May 02, 2013, 11:25 AM
gspence is offline
gspence's Avatar
Joined Mar 2013
Yes the Naza is mounted securely and the props seem fine. In Attitude mode it did the same thing.
That's a great suggestion to fly it like a quad to try to isolate the motor. I'll have to try that this evening.
Old May 02, 2013, 12:30 PM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
By the way, do not forget to set it as a X4 quad, and for gains : 140/140/100/120 - 100/100
The current gains for a x6 are way too high.
And you'll have to reverse 2 motors, on a quad the opposite motors are spinning the same way.
Old May 02, 2013, 01:56 PM
DWA is offline
DWA
Find More Posts by DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
United States, CA, Mission Viejo
Joined Dec 2004
I just put my GPS compass on a copper plate. I have seen a couple of guys with DJI s800 doing this. It helps with RF noise.
Mine is very thin actually. It looks thick because it is an end cap for a pipe so you are just seeing the sides not the thickness.
DWA is offline Find More Posts by DWA
Old May 02, 2013, 02:31 PM
lacion is offline
Find More Posts by lacion
lacion's Avatar
Spain, Community of Madrid, San Sebastián de los Reyes
Joined Dec 2012
you can also use a copper cage to cover your electronics
http://www.twpinc.com/control/produc...6X016C0110W72T
it will absorb rf
https://en.wikipedia.org/wiki/Electromagnetic_shielding
also note that in the case of the NAZA where the compass and the gps are toguether do not cover the gps antenna.
lacion is offline Find More Posts by lacion
Old May 02, 2013, 05:13 PM
gspence is offline
gspence's Avatar
Joined Mar 2013
Thanks for the reminders! I'll post a video of the tests.
Old May 03, 2013, 04:00 AM
gspence is offline
gspence's Avatar
Joined Mar 2013
I just thought of something that might be causing the issue, but I'm not sure.
I remember reading something about disconnecting the read V+ wires from the motor outputs to the ESC's. I can't remember if that was related to my CC3D FC or the Naza, but I know I haven't done that. Apparently the LED module with the Naza acts as a switching BEC so its not necessary to use the BEC's build into the ESCs. But since all this hardware is DJI, I'd assume it would work without any special modifications.
Discussion Dji Flame Wheel F450 Venom93corba Multirotor Talk 39 Jun 13, 2016 07:16 AM
Help! Flame Wheel F450 / F550 NAZA with Spektrum DX8 AR8000 setup assistance jasper7821 Multirotor Talk 18 Feb 10, 2015 04:23 PM
Sold Dji flame wheel f450 arf kit (w/motors, esc & props) Angry Bird Aircraft - Electric - Multirotor (FS/W) 2 Apr 01, 2013 06:30 PM
Sold DJI F550 Flame Wheel with DJI Motors & DJi 30amp ESCs & Props peaksview Aircraft - Electric - Multirotor (FS/W) 2 Jan 22, 2013 09:53 AM
Sold X468 XT Flame Gear Gimbal For DJI F450 or F550. Sale or trade for Naza GPS. vacahtu Aircraft - Electric - Multirotor (FS/W) 3 Nov 09, 2012 06:57 PM
