Old Sep 09, 2013, 10:33 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Originally Posted by represent View Post
Honestly, I think RDtague is probably right. As long as you are only adjusting the signal that your TX is sending the Naza (via trim), the Naza isn't going to know that is different from a TX that is already centered, if you get what I'm saying.
I think you can use the trim on your TX to center the controls in the assistant, but you don't want to use them to trim flight? Someone probably knows the answer to this...
Well ..my F450 will not do a thing in GPS or ATTI. when trim is applied..I switch to MM and it duplicates exactly what trim I put in. Really!! I'm not lying. I kept wondering why my rig was doing this?? Then I realized I had subtrims induced,
ZACATTACK is offline Find More Posts by ZACATTACK
Old Sep 09, 2013, 10:37 PM
valk_17 is offline
Find More Posts by valk_17
valk_17's Avatar
United States, GA, Woodstock
Joined Jun 2011
Originally Posted by RDTague View Post
Has anyone tried 12 x 4.5 full carbon fiber props on a standard wheelbase F450? They'll clear...not by much...but they'll clear. I'm thinking of trying 12's, but not sure on the pitch. 4.5 or 6.0...although I think 6.0 is too steep.
eCalc shows OK with 3S but over motor limit on 4S. However, I'm using the 2216-11 900KV T-motor in eCalc, rather than my SunnySky 2216-11 880KV motors...I believe they're close enough in specs, though!
Any thoughts?
I would think you would want a 3.8 pitch on a 12" prop for that frame.
valk_17 is offline Find More Posts by valk_17
Old Sep 09, 2013, 10:39 PM
ZACATTACK's Avatar
Joined May 2011
I thought 11" was MAX. on the 450 frame?? The stock motors will fry turning 12" props
Old Sep 09, 2013, 10:46 PM
valk_17 is offline
valk_17's Avatar
Joined Jun 2011
I've never used DJI motors, just have the 450 frame. He's not using stock motors either. I just can't imagine adding 2 inches to my 1045 props and keeping the same pitch. Assuming the motors handled it, it just seems like way too much prop unless you've got the heaviest F450 in existence. Hover would be at like 10% throttle otherwise.
Old Sep 09, 2013, 10:52 PM
ZACATTACK's Avatar
Joined May 2011
I just measured it and 12" props will fit with a 20mm gap left..They will fit but....not me. Im trying to order longer aluminum arms from RMRC but there's been no stock since they introduced this product. I will end up running 1238's most likely but need more room and less flex with the motors I'm applying.
Old Sep 09, 2013, 10:57 PM
RDTague is online now
Find More Posts by RDTague
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
Zac, I'm not using stock motors. SunnySky 2216-11 880KV II motors.
Valk...I think your right. 3.8's sound better. Before I asked, I went to where I normally get my props and all he had was 4.5 or 6.0's. After you suggested 3.8's, I checked horizon and they have 3.8 APC slow-fly's. I think I'll try them.
I'm just bored, is all. I'm going in Friday for shoulder surgery and I'm trying to get a few things to keep me occupied. Doc says I won't be able to lift a camera (my "real" job), so I don't have any shoots scheduled for a month. Trying new things. $20 here or there is not gonna break the bank. My tele temp will keep me in check with the motor temps. And I'll at least know if they work better, worse or the same than stock 1038's or Gemfan full CF 947's. Too much time on my hands!
RDTague is online now Find More Posts by RDTague
Old Sep 09, 2013, 10:58 PM
RDTague's Avatar
Joined Mar 2013
I thought about those arms...until I seen the $.
Old Sep 09, 2013, 11:03 PM
gnolivos is offline
Find More Posts by gnolivos
gnolivos's Avatar
United States, OH
Joined May 2008
Center to Center on a f450 frame is just over 12.5". So, you can indeed fit a 12" prop. I'm going to be using either a 11x4.7 or a 3-blade 10x6. They are almost identical in lift according to eCalc etc. Im using SunnySky 2216-900Kv
gnolivos is offline Find More Posts by gnolivos
Old Sep 09, 2013, 11:05 PM
Brainstorm is online now
Find More Posts by Brainstorm
Fly a LiPo a day...
Brainstorm's Avatar
Côte d'Ivoire
Joined Jun 2012
Please do report back on how this goes, RDTague, regardless of what pitch you end up with on those 12" props!
On the F330 I am building now, I plan to test 9047 (SF style) and 9050 (Graupner style) full-carbon props, in addition to the standard 8045 props. If I move up to the F450 at any point in the future, I would expect to go in the same direction and try to spin the largest possible props, i.e. 11" or 12".
My intuition matches valk_17's recommendation of reducing pitch to 3.8 when moving up from 10"x4.5 to a 12" prop. Unless, of course, the 1045 prop was too small and low-pitched for your motor/LiPo combination, and your system is screaming for that 4.5 or 6.0 pitch.
Now there's a thought! I imagine that hovering at 10% with 1260 props might translate into excellent autonomy. Definitely curious to hear how the 12" props go!
Brainstorm is online now Find More Posts by Brainstorm
Old Sep 09, 2013, 11:08 PM
ZACATTACK's Avatar
Joined May 2011
I know!! 125$$ for 4 arm??? But if your going to do an X8 or LRS-FPV...these arms aren't that bad really RDT?? I have been looking at frames like ( Sky Hero) & ( Carbon Core) lately...after I seen the prices of those frames ..these arms aren't that bad. I love that Sky Hero Spyder!!
Old Sep 09, 2013, 11:10 PM
RDTague's Avatar
Joined Mar 2013
I just measured it and 12" props will fit with a 20mm gap left..I just measured my 550 with 10" props and there is only 22mm between them. Same exact arms...1/2 again the AUW.They will fit but....not me. Im trying to order longer aluminum arms from RMRC but there's been no stock since they introduced this product. I will end up running 1238's most likely but need more room and less flex with the motors I'm applying.
I will. I just ordered 6 (2 spares) from Horizon. There only about 60 miles from me. They should be here by Wednesday or Thursday!?!?
See red above
Old Sep 09, 2013, 11:39 PM
DWA is offline
DWA
Find More Posts by DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
United States, CA, Mission Viejo
Joined Dec 2004
Originally Posted by T J Gilbert View Post
Spektrum/JR (my brand) has taken a good many hits about loss of communication from the Futaba crowd...
And there really have been fewer reports with Futaba.
+1 TJ
@ flboy286... this is also the reason I asked about if you were on Futaba.
I used to be on Futaba when I flew 72mHz but now I am on Spektrum.
I think Futaba and Spektrum are good brands.
DWA is offline Find More Posts by DWA
Old Sep 10, 2013, 12:37 AM
Olivier_C is offline
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
A 12" with a 2216-kind of motor may work (even under 4S) if the AUW is low, but the motors will run ridiculously low in their efficiency curve... my F450 naked is hovering at like 30% throttle with 2216 and 10x5, I cannot even imagine with 12"... worth a try for giggles
Also such big props will push against the frame, and it may do more harm than good.
Olivier_C is offline Find More Posts by Olivier_C
Old Sep 10, 2013, 12:49 AM
Witterings is offline
Find More Posts by Witterings
Beware Of The Shills !!!
Chichester Sussex
Joined Aug 2007
I keep reading about the Phantom having "Flyaway issues" does anyone know if the F450 suffers the same problems ????
Witterings is offline Find More Posts by Witterings
Old Sep 10, 2013, 01:16 AM
Wangta is offline
Find More Posts by Wangta
Wangta's Avatar
United States, CA, SF
Joined Mar 2012
Neither does.
Wangta is offline Find More Posts by Wangta
Discussion Dji Flame Wheel F450 Venom93corba Multirotor Talk 38 May 01, 2016 01:08 AM
Help! Flame Wheel F450 / F550 NAZA with Spektrum DX8 AR8000 setup assistance jasper7821 Multirotor Talk 18 Feb 10, 2015 04:23 PM
Sold Dji flame wheel f450 arf kit (w/motors, esc & props) Angry Bird Aircraft - Electric - Multirotor (FS/W) 2 Apr 01, 2013 06:30 PM
Sold DJI F550 Flame Wheel with DJI Motors & DJi 30amp ESCs & Props peaksview Aircraft - Electric - Multirotor (FS/W) 2 Jan 22, 2013 09:53 AM
Sold X468 XT Flame Gear Gimbal For DJI F450 or F550. Sale or trade for Naza GPS. vacahtu Aircraft - Electric - Multirotor (FS/W) 3 Nov 09, 2012 06:57 PM
