Old Apr 28, 2013, 10:26 AM
DWA is offline
DWA
Find More Posts by DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
United States, CA, Mission Viejo
Joined Dec 2004
So yesterday I flew my F550 in some moderate wind in GPS mode and she was very wobbly. In calm wind she does great.
My gains are
Pitch 145% Roll% Yaw 130% Vertical !30% Attitude Gain Pitch 90% Roll 90%.
I know that gains a different for every set up but can anyone suggest a different set of gains to use for windy days.
Should the gains be adjusted up or down?
DWA is offline Find More Posts by DWA
Old Apr 28, 2013, 10:33 AM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
Also I am looking for some good landing gear for my F550 so I can use a wire isolator mount with a GoPro or use a camera gimbal (not sure which one to get yet) with a Sony rx100 camera or something like it.
Is there a set of lading gear that is good for switching out camera systems on the go at the field?
Old Apr 28, 2013, 10:55 AM
eirlink is offline
Find More Posts by eirlink
click HERE 2 C my BLOG
eirlink's Avatar
Ireland
Joined Mar 2013
Originally Posted by CG Photo View Post
Well my contribution would be that I delivered the wedding ring with a F550
http://www.youtube.com/watch?v=ai2bwOuLGAQ
A few weeks back I reconfigured my F550 to a Y6-550
Nice. How does it compare to the F and can you describe the build.
eirlink is offline Find More Posts by eirlink
Old Apr 28, 2013, 11:13 AM
The Quadder is offline
Find More Posts by The Quadder
Sweden, Västra Götaland County, Lysekil
Joined Apr 2013
Originally Posted by WiseDuck View Post
Jo, det har hänt en hel del. Speciellt på de senaste 2 åren faktiskt. Hursomhelst, kan ju vara för att du har för hög gain helt enkelt, prova att sänka ATTI gain samt pitch, roll och yaw något. Den verkar sitta och ändra motorhastighet lite hela tiden, vilket betyder att gains är något för höga. Vet inte varför den rycker till lite då och då, däremot... Jag tror min F550 gjorde så en gång då en propeller började att lossna, men sedan jag bytte till taggbrickor har jag aldrig sett det problemet igen.
Jag kom på en sak som jag inte har tänkt på. I början när jag fått quaden så flög jag med batteriet som följde med, det var 2.200mah och 65C. Sedan när jag köpte ett större så hade jag inte kläm på det här med olika C, och köpte ett 4.000mah med 20C. Jag har kollat igenom de filmsekvenser som jag tog med 65C batteriet och har inte hittat några dippar på dessa filmer. Skall så fort som vädret tillåter provflyga med gamla 65C batteriet. Kan det vara så att 20C inte klarar av att leverera. Jag flyger i och för sig väldigt försiktigt.
The Quadder is offline Find More Posts by The Quadder
Old Apr 28, 2013, 11:41 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Formulan för hur mycket ett batteri kan ge är kapacitet/1000 * C. Så 4 x 20 = 80A. Så batteriet bör funka, men prova gärna med det andra batteriet ändå. Den kanske går tungt med ett batteri på 4000mah? Jag har provat med ett sådant på min och det funkade, men den kändes lite slö. Nuförtiden kör jag med 4S lipo batterier på 2200mah. Så jag kör kort men intensivt.
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 28, 2013, 03:54 PM
Olivier_C is offline
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
My gains are
I often fly my F450 in windy conditions, hills/mountains, the 3 or 4 last videos HERE all had some serious wind. I was once with a friend with a F550 thats very similar to my F450, it was VERY wobbly, we tried to swap his DJI 1038 props for my Graupners 10", was a little bit better, but it was nowhere near the performance of the F450 in the wind, I'm afraid its just that an hexa is worse in wind than a quad
Or using smaller props, may help.
EDIT, forgot to say...
This is my F450 : http://www.rcgroups.com/forums/showthread.php?t=1879450
And this is the stuff I film : http://www.youtube.com/olivierc600
Olivier_C is offline Find More Posts by Olivier_C
Old Apr 28, 2013, 10:25 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
I guess I will try smaller props. I am also going to adjust my gains.
Old Apr 29, 2013, 02:52 PM
cruiser73 is offline
Find More Posts by cruiser73
cruiser73's Avatar
Singapore, Singapore
Joined Apr 2012
Am building a F450 right now. SimonK F20A ESCs, Sunnysky X2212 1250kv motors, KK2 FC, 8" or 9" props, orange RX R615, Turnigy 9XR with Orange module. This thread would be really useful or guys like me looking for tips. Any of you care to share your KK2 settings for F450? Thanks in advance guys.
cruiser73 is offline Find More Posts by cruiser73
Old Apr 29, 2013, 06:25 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
Here are some landing gear sets I have been looking at.
http://www.uavproducts.com/product.php?id_product=69
http://tppacks.com/store/index.php?r...&product_id=52
http://www.atlantahobby.com/store/pc...2&idcategory=0
http://www.quadframe.us/collections/landing-gear
http://www.aeroxcraft.com/index.php?...products_id=20
If you have different landing gear that you like please post them up.
Dave
Old Apr 29, 2013, 06:32 PM
eirlink is offline
eirlink's Avatar
Ireland
Joined Mar 2013
dave..my preference would be the aeroxcraft one. ive seen it in the flesh and its really well made. plus will be easy to find a brushless gimble for it. its the one ive ordered for my 550 build
Old Apr 29, 2013, 07:08 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If you're using a spektrum radio and r looking for programming help, you can find it here.
http://www.rcgroups.com/forums/showthread.php?t=1789552
freechip is offline Find More Posts by freechip
Old Apr 30, 2013, 09:27 PM
RDTague is offline
Find More Posts by RDTague
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
Kewl!
RDTague is offline Find More Posts by RDTague
Old Apr 30, 2013, 09:35 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
Since she's not "technically" a Phantom anymore, I guess I need to switch to the F450 thread.
Got her all together...Finally!
Specs:
Phantom board
NAZA-M
GPS
DJI Flamewheel F450 frame
DJI 30A opto ESC's
DJI Red motors
10" DJI plastic props
ATG Carbon Fiber Anti-Vib Landing gear
fpvpilot gimbal
Hero 3-in water-proof housing
ImmersionRC 600mW 5.8ghz fpv tx
Devo 10 Tx
AX1002 Rx
She fly's pretty good. With no camera or housing, in Atti mode, I'm getting about 5mins flight time out of a Ultra Pulse 2250mah 3S battery. A least that's when the red light starts blinking continuously. Not too happy with that, but I'll tinker with it. Right now she has 10" black DJI plastic props. Probably change props to Zingers or maybe (Maybe) CF's. I didn't like the black 8" DJI props or 9x5 Zingers. It seemed like I really had to pour the coal to her to get her off the ground with the black 8" and the Zinger just would NOT lift her.
I still need to do a little tweaking on the gains, but it's gusty windy here today. GPS mode is drifty. But in Atti, she fly's great. Need to do a little work on shielding the GPS better, too...I think! Right now, I have it sitting directly on top (centered). I put the stock phantom shielding material down 1st, then the GPS on top of that. I may need to put a piece of the top, too?!?!
Old Apr 30, 2013, 10:17 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
i have wondered if I have just been missing the 550 thread... so thanks for getting it going.
i have a question for you 550 flyers.
I am into Aerial video/photos. I want a gimbaled ship for a go pro and I would like also to have a gimbal for a sony rx100 but that can be swapped when manufacturers figure out they are missing a market with a lack of gimbal support for compact cameras heavier than 200grams.
Anyway, I will be using FPV for camera angles. As you can tell my Phantom has been outgrown already.
Soooo, the debate I have is:
Should I build a 550 type quad or one of the new Gimbal equipped FPV birds like the NEX or the UAV540?
Am I better with a hex?
thanks for your input.
kepople is offline Find More Posts by kepople
Old Apr 30, 2013, 10:39 PM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
I too was looking for the DJI F450 owners thread, I thought for sure someone would have made it. Glad you did, now I have a place to share. I got mine about 4 weeks ago and been having a blast with it ever since. I bought the DJI kit with motors and ESC, so
DJI F450 frame
DJI 30 amp opto ESC
DJI red motors
currently running DJI 1038 carbon props
Castle BEC
KK2 1.5 FC
Spectrum DX7
I have been using it for Acro, and for AP with a gopro2 and 3. Soon I will be doing FPV. Gimbal mount is next.
ACRO MOVES side loop (0 min 57 sec)
Hudson River NY (4 min 5 sec)
And some night flying:
learning to flip and night flying with the F450 DJI (7 min 54 sec)
antslake is offline Find More Posts by antslake
Latest blog entry: FAA registration
Discussion Dji Flame Wheel F450 Venom93corba Multirotor Talk 39 Jun 13, 2016 07:16 AM
Help! Flame Wheel F450 / F550 NAZA with Spektrum DX8 AR8000 setup assistance jasper7821 Multirotor Talk 18 Feb 10, 2015 04:23 PM
Sold Dji flame wheel f450 arf kit (w/motors, esc & props) Angry Bird Aircraft - Electric - Multirotor (FS/W) 2 Apr 01, 2013 06:30 PM
Sold DJI F550 Flame Wheel with DJI Motors & DJi 30amp ESCs & Props peaksview Aircraft - Electric - Multirotor (FS/W) 2 Jan 22, 2013 09:53 AM
Sold X468 XT Flame Gear Gimbal For DJI F450 or F550. Sale or trade for Naza GPS. vacahtu Aircraft - Electric - Multirotor (FS/W) 3 Nov 09, 2012 06:57 PM
