Old Jul 11, 2013, 08:57 AM
fatbutcher is offline
Find More Posts by fatbutcher
Model Citizen
fatbutcher's Avatar
Northamptonshire, UK
Joined Sep 2004
Originally Posted by charliehorse View Post
Going to reduce all the gains to what DWA says, 100-120 and try again.
Olivier, I hear what you are saying about that cam.
Bought it for my glider and it would probably be better suited to that with far less vibration and stuff going on.
What do the gains do, is it something to do with volume of input from the MC to the motors??
So too much input equals too much correction equals unstableness. Less gain equals smoother flight. This is sort of how autopilots work on boats.
I think, and I'll let other correct me if I'm wrong, the gain is how hard the Flight Controller (e.g. Naza) tries to compensate for tilting, altitude, drifting etc. So if its drifting left, it will compensate by going right. The higher the gain, the more power it will put into compensating, to much gain and it is over reacting, and you go the other way, then back and forth. To little gain and it doesn't stop the drift completely, or only slowly.
I've only experimented with remote gains on Pitch and Roll so far, and didn't see much effect, as it remained stable, but maybe the conditions weren't right to show up where it could be fine tuned.
fatbutcher is offline Find More Posts by fatbutcher
Old Jul 11, 2013, 09:05 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Originally Posted by OzBlueDragon View Post
Oli... I gotta say mate I love your Pilot! I was in stitches watching him flying your F450 and I had to show my wife and even she was in stitches...
Speaking of stiches, my wife saw me editing the video and th quad passing so close above me I had to duck and she slapped the back of my head and said something that could be translated into "you stupid moronic ass"
The basics gains thats how "aggressive" the FC responds to unblances, if too high the FC will over react and oscillate, if too low it will tend to drift.
Usually we set the roll and pitch the same, between 100 and 150 for a F450, the yaw its better to keep it low, like 100, and the aLtitude its often between 100 and 140, can tweak this one by making hard 180 banks and see for wich value it keeps the height the best.
The attitude gains thats more like a dual-rate, I guess in the software that's a multiplier for the stick inputs, and a damper when you release these. Frequent values are often between 80 and 120, depending of taste, and how you like your copter, alive or smooth.
Now in the latest DJI software there's an "advanced" mode with different fields and I think so far only DJI knows what's going there...
Originally Posted by fatbutcher View Post
In the mean time, I've cobbled together a cheap make-shift gimbal by just sticking a few servos together and running it off the Naza. Considering the cost (ie, zero, just a couple of spare servos) I'm pretty happy with the results.
https://vimeo.com/69944033
I like this design, with rubbers and servos, old school !
And hurray for kites, we got kites too, deltas, foils, etc, can attach Gopros there aswell, short bit of video from last summer :
Kites - A spanish beach from the sky (0 min 51 sec)
Olivier_C is online now Find More Posts by Olivier_C
Old Jul 11, 2013, 09:23 AM
Model Citizen
fatbutcher's Avatar
Joined Sep 2004
Better explained than my effort, but the same understanding.
Love the kite mounted video, something I've been meaning to try, along with about a hundred other ideas!
Old Jul 11, 2013, 09:30 AM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
/QUOTE=fatbutcher;25542200]Better explained than my effort, but the same understanding.
Love the kite mounted video, something I've been meaning to try, along with about a hundred other ideas![/QUOTE]
140/140/140/130 90/90 Seems to be the sweet spot for me. There is an Excel Sheet with alot of gains/ weights/engines used/ ESC used/ Lipo in here I'll dig out and post. Gains= Personal Preference.
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jul 11, 2013, 09:39 AM
ZACATTACK's Avatar
Joined May 2011
Gain Setting Chart
Found it !!
https://docs.google.com/spreadsheet/...3c&pli=1#gid=0
Old Jul 11, 2013, 10:09 AM
charliehorse is offline
Find More Posts by charliehorse
charliehorse's Avatar
Ireland, Galway, Galway City
Joined May 2013
Excellent guys, at least now I know what the gain settings are doing and almost certainly they are the cause of my instability (in the 550 that is )
Looks like my settings are way too high. Just upgrades to 2:14 so will adjust and check everything while connected. Zac, that spreadsheet has a lot of info, thanks.
Looks like that Go Pro Black I was eyeing will have to Come to Daddy soon
charliehorse is offline Find More Posts by charliehorse
Old Jul 11, 2013, 10:45 AM
DWA is offline
DWA
Find More Posts by DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
United States, CA, Mission Viejo
Joined Dec 2004
Originally Posted by ZACATTACK View Post
That is great! Thanks for finding it.
Dave
DWA is offline Find More Posts by DWA
Old Jul 11, 2013, 10:47 AM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
My gains are low because of the T-motor props. They require low gains,
Old Jul 11, 2013, 11:01 AM
Joined May 2013
Gonna use 120 for a start with the 550. Will bring out laptop to adjust in the field.
Old Jul 11, 2013, 11:06 AM
eirlink is offline
Find More Posts by eirlink
click HERE 2 C my BLOG
eirlink's Avatar
Ireland
Joined Mar 2013
Charlie
What radio did you get from mhs, to control the 550?
I've a spectrum and I can set up the radio so you can adjust the gains in flight.
eirlink is offline Find More Posts by eirlink
Old Jul 11, 2013, 11:09 AM
W5HYN is offline
Find More Posts by W5HYN
United States, TX, Houston
Joined Feb 2006
It's not always possible but, adjusting, balancing and setting up your multi-copter in Manual Mode gives you "real-time" parameters to deal with and adjust. IMHO it is a great way to set-up the Drone, there's no lying in manual mode, nothing is getting masked with the auto pilot settings, adjust each of your gains until oscillation occurs and back-off a few notches. Switch to GPS and fine tune your gains to your preference. I found this works the best, Lots of people switch to manual mode and their Drone tilts, drops, rises, flips over because electronics were slapped on it, battery was placed wherever there was room, etc, etc, and the gains were set up until the auto pilot compensates for these impetuous actions. Be careful and fly safe. Set Up is everything.
I'm a real newbie at this but I have always wondered about doing setup in manual mode (but never had the courage to try). It certainly makes sense since problems with CG and motor problems, etc. would be easier to see. The question I have is: Are the gain settings active in manual mode? I always assumed that manual mode was TOTALLY manual - not even active gyros. That is why I have avoided manual mode.
W5HYN is offline Find More Posts by W5HYN
Old Jul 11, 2013, 11:19 AM
ariZedA is offline
Find More Posts by ariZedA
Joined Jul 2013
Originally Posted by KyleG View Post
I seem to have worked out all the problems with the original design.
Here's my first full set:
Printed in black and glow in the dark.
I'll take a set of four black too?
ariZedA is offline Find More Posts by ariZedA
Old Jul 11, 2013, 11:30 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Manual FM & Gains
http://www.rcgroups.com/forums/showp...15&postcount=1
This is an entry over on my blog...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jul 11, 2013, 11:46 AM
scsurfer is offline
Find More Posts by scsurfer
Joined Apr 2013
Just wondering what kind of fly times you are getting and what battery you are using?
thanks
Originally Posted by photoboi View Post
Well I just finished redoing my landing gear with the new LG and also use some parts of the old LG for the gimbal support. The new H3-2D gimbal seem to be working flawlessly it does make a weird sound like rushing air is that Normal? Beats that high pitch sound the arris made..... Here are a few pics from my phone too lazy to get the big camera out..LOL Tomorrow Ill take her out to fly and see what this gimbal will do....
https://vimeo.com/70091617
scsurfer is offline Find More Posts by scsurfer
Old Jul 11, 2013, 11:47 AM
W5HYN is offline
Joined Feb 2006
Thanks. This helps a lot - excellent analysis of gains. Now I will not be afraid to try manual mode. From reading all the info in your link(s) I gather that stabilization (gyros, accelerometers) is fully active in manual mode but auto leveling is not. Also ATT gains are not active in manual mode.
Discussion Dji Flame Wheel F450 Venom93corba Multirotor Talk 39 Jun 13, 2016 07:16 AM
Help! Flame Wheel F450 / F550 NAZA with Spektrum DX8 AR8000 setup assistance jasper7821 Multirotor Talk 18 Feb 10, 2015 04:23 PM
Sold Dji flame wheel f450 arf kit (w/motors, esc & props) Angry Bird Aircraft - Electric - Multirotor (FS/W) 2 Apr 01, 2013 06:30 PM
Sold DJI F550 Flame Wheel with DJI Motors & DJi 30amp ESCs & Props peaksview Aircraft - Electric - Multirotor (FS/W) 2 Jan 22, 2013 09:53 AM
Sold X468 XT Flame Gear Gimbal For DJI F450 or F550. Sale or trade for Naza GPS. vacahtu Aircraft - Electric - Multirotor (FS/W) 3 Nov 09, 2012 06:57 PM
