Old Apr 27, 2013, 11:31 PM
HECTOR2369 is offline
Find More Posts by HECTOR2369
México, SLP, San Luis Potosí
Joined Mar 2011
Help!
Smoke unit
tankers hello, I have a problem with the smoke unit in my Tiger 1, if I turn on the switch begins to work alone without activating the transmitter engine start, when I start the engine the smoke unit works with more intensity, if I turn off the transmitter button of the engine the smoke unit continue working, any idea what it might be?
Thank you so much.
HECTOR2369 is offline Find More Posts by HECTOR2369
Old Apr 28, 2013, 02:51 AM
willbody1 is offline
Find More Posts by willbody1
willbody1
United States, OK, Oklahoma City
Joined Nov 2011
Thank you so much.
Sounds like since the smoke unit is working i would start with the switch
willbody1 is offline Find More Posts by willbody1
Old Apr 28, 2013, 02:58 PM
Joined Mar 2011
Thank you for your answer..I will check te switch maybe something is not good there.
Idea Using train smoke system for smoke system in an edf, possible? Mike20 Electric Ducted Fan Jet Talk 24 Apr 03, 2013 09:52 AM
Help! How to power a small smoke unit ? rolex0071 Scale Boats 5 Feb 26, 2013 03:03 PM
Discussion hows does the Smoke unit actually produce the smoke ltjimster RC Tanks 4 Oct 29, 2009 04:46 PM
Question Where to get a cheapish smoke and sound unit to run on a plastic kit? Jonjoe Scale Boats 1 Jun 05, 2007 11:20 AM
Help! Train smoke unit tomi DIY Electronics 6 Mar 17, 2006 05:45 PM
