Old May 26, 2013, 07:39 AM
MOFO64 is offline
Find More Posts by MOFO64
QUAD-A-HOLIC
MOFO64's Avatar
United Kingdom, Scotland, Glenrothes
Joined Mar 2013
I tried the motors EOD lists in his opening post with 10amp esc's and they refuse to run with 15" props installed. The page listing states these motors work with 2S-6S and 10amp esc
http://www.rctimer.com/index.php?gOo...wt&goodsid=575
MOFO64 is offline Find More Posts by MOFO64
Old May 26, 2013, 08:22 AM
chuenwe is offline
Find More Posts by chuenwe
chuenwe's Avatar
United States, NY, Huntington Station
Joined May 2012
Originally Posted by catamar View Post
This week I made a flight of 66 minutes and 30 seconds using this batteries. But my Idea is a little different. I want to flight long time to make FPV. So I have use a complitely functional QUAD. The TAROT quad. I made a battery using 24 of this 3,4volts Li-Ion batteries. Following the instructions of End_of_days. So I have a pack of 20 Amps, with a weight of 1240 grams. I can go to 40 Amps maximun of consuption (2c) in case I find strong winds during flight. But I can flight with 17-21 Amps including 200 grams of FPV ( the 66,5 min were without the FPV). My quad weight is 1350 grams, without the battery and the FPV.
I am using a 18 carbon fiber propellers, and Multistar 4822 490RPM motor.
Nice! Get a normal quad to fly that long is amazing. Which TAROT quad did you use?
chuenwe is offline Find More Posts by chuenwe
Old May 26, 2013, 08:25 AM
catamar is offline
Find More Posts by catamar
Alicante, España
Joined Jun 2010
They only have one:
http://www.foxtechfpv.com/tarot-fy65...ter-p-896.html
catamar is offline Find More Posts by catamar
Old May 26, 2013, 08:27 AM
catamar is offline
Alicante, España
Joined Jun 2010
Only a few ESC are compatible with this motors. I had the same problem first, with DJI ESC's
Old May 26, 2013, 08:38 AM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
Nice! That's a heavy quad too! 1.1kg!!
I thought you somehow make their small quad bigger to handle 18" prop. lol
http://tarot-rc-heli.com/Tarot-SK450-Quad-Copter
Old May 26, 2013, 08:40 AM
MOFO64 is offline
QUAD-A-HOLIC
MOFO64's Avatar
Joined Mar 2013
Do you happen to know which ESCs are compatible? Thanks.
Old May 26, 2013, 11:12 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
Here a pic of my FPV-Module added to the quad:
@MOFO64
Hobbywing escs are compatible, as far as I tried, I could not get any ESC with simonk to run with these motors, big props and 4S. 66min is a great endurance, keep on pushing!
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old May 26, 2013, 01:22 PM
MOFO64 is offline
QUAD-A-HOLIC
MOFO64's Avatar
Joined Mar 2013
Could you link the ones you used as a reference please?
Thanks in advance.
Old May 26, 2013, 01:58 PM
EndOfDays's Avatar
Joined Jan 2010
These:
http://www.foxtechfpv.com/hobbywing-30a-esc-p-440.html
Old May 26, 2013, 04:29 PM
catamar is offline
Alicante, España
Joined Jun 2010
Also hobbyking multistar
Old May 27, 2013, 05:10 AM
Aussie Pete is offline
Find More Posts by Aussie Pete
Aussie Pete's Avatar
Australia, SA, Adelaide
Joined May 2009
Hi EOD
subscibed..................Pete
Aussie Pete is offline Find More Posts by Aussie Pete
Old May 27, 2013, 06:25 PM
catamar is offline
Alicante, España
Joined Jun 2010
Thank you, a little improve today, 73 minutes, with 33amps!!!!
@MOFO64
best regards
Ferdinand
Old May 27, 2013, 07:32 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
@MOFO64
The latest version of simonK should have no problems with the rctimer 5010-14 360kv motors. I had some on my hex for awhile using flashed HK 40amp blue series.
You may want to find some better bearings for the 5010-14 from rctimer. I had 3 bearings go bad out of my 6 motors after about 10hrs of flight time. One bearing seized up so bad it smoked an ESC. Maybe I was just unlucky too. =/
Dolby is offline Find More Posts by Dolby
Old May 27, 2013, 07:46 PM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
It does not matter what ESCs you use with the RCtimer 5010-14 360KV motors they only produce max 150watts which is useless to lift anything heavy...
skizziks is offline Find More Posts by skizziks
Old May 27, 2013, 08:00 PM
rnelias is offline
Find More Posts by rnelias
United States, NV, Minden
Joined Apr 2011
I'd be glad if I could build my Spidex for flying FPV 20-25 mins...
I'm still buying the eletronics and deciding about motors, esc and battery.
Subscribed!
rnelias is offline Find More Posts by rnelias
Question Anyone fly with a Hacker A10-15s and a Glavak prop? r/cmark Indoor Pattern/F3P 6 Apr 10, 2013 09:45 PM
Discussion LiPo Battery Flighttime with MultiWii Jessestr Multirotor Talk 3 Jan 15, 2012 04:30 AM
Discussion Shorter flighttime with a 3s Lipo, than a 2s Lipo ? SpookiePower Batteries and Chargers 12 Oct 28, 2009 02:19 PM
Discussion E550 with 15S A123 genexis Electric Heli Talk 10 Dec 17, 2006 12:05 PM
FS: Hacker B50 15S with 1/8" shaft and MEC Superbox smsgill Aircraft - Electric - Airplanes (FS/W) 7 Sep 05, 2003 10:57 AM
