Old May 06, 2013, 03:52 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by catamar View Post
Hello,
How is the connection of the balancing cables?. Where do I have to connect them to make a balancing connection, like the one seen in the pictures?
4s4p, this say everything.
Four clusters in series, each of them being four cells in parallel.
Think each four parallel cluster as a single bigger element. The balance wires are the intermediate plus-to-minus connections, as in a 4s lipo.
renatoa is online now Find More Posts by renatoa
Old May 06, 2013, 04:38 PM
catamar is offline
Find More Posts by catamar
Alicante, Espa˝a
Joined Jun 2010
Thank you Renatoa. Understood.
catamar is offline Find More Posts by catamar
Old May 07, 2013, 05:31 PM
MOFO64 is offline
Find More Posts by MOFO64
QUAD-A-HOLIC
MOFO64's Avatar
United Kingdom, Scotland, Glenrothes
Joined Mar 2013
So....
4x3400mah cells in parallel = 1 cluster = 1x1S (3.7v) = 13600mah @ 200g
4x1cluster in series = 1x4S (14.8v) = 4x3400mah = 13600mah @ 800g?
Thanks.
MOFO64 is offline Find More Posts by MOFO64
Old May 08, 2013, 10:12 AM
Joined Sep 2007
Close, he wrote his cells have 48 grams. So 32 grams less.
Old May 12, 2013, 04:34 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Nieder÷sterr., Eggenburg
Joined Jan 2010
Here a video of 57min FPV with this quad. I could have done more than 60min, but I made a small flight before (with the same battery) to get some shots of the quad for the video:
12mm Frame Quad big FPV endurance test 57min (7 min 2 sec)
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old May 12, 2013, 05:26 PM
uniquewon is offline
Find More Posts by uniquewon
uniquewon's Avatar
Minneapolis
Joined Jun 2002
Originally Posted by EndOfDays View Post
@catamar
These cells are 100gr, the Panasonic is 50gr
@ed_jza80
These Lipos have good specs, but your numbers are 3S the numbers you cited are 4S.
best regards
Ferdinand
Funny, I've been using the same battery for years in electric RC. We got them from older cell phone packs. I have a 3 cell pack in my 9CFutaba and even a special charger for them.
Great work flying that long, you know your stuff for sure.
uniquewon is offline Find More Posts by uniquewon
Old May 12, 2013, 06:39 PM
irun4fundotca is offline
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
Wow!!! and I was happy with 18 minutes lol
good job!
irun4fundotca is offline Find More Posts by irun4fundotca
Old May 12, 2013, 06:58 PM
MOFO64 is offline
QUAD-A-HOLIC
MOFO64's Avatar
Joined Mar 2013
https://vimeo.com/66010657
best regards
Ferdinand
That's fantastic!
Old May 12, 2013, 08:14 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Ferdinand with all the super low kv motors out now perhaps one of the 120 turn gimbal motors would be enough rpm on 4s
pug398 is offline Find More Posts by pug398
Old May 13, 2013, 07:34 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
This is awesome!
I may have to build a pack for my flying wing... Its peak Amp Draw is around 10A so a 3s3p should give around 15A Peak?
at that I would get a 10.2Ah pack for only around 440g! Right now I can fly for 45 minutes on 2200mah that is 190g and some dead nose weight... I could easily add this pack in.
Does anyone know the lifespan of the cells?
chanyote66 is offline Find More Posts by chanyote66
Old May 13, 2013, 08:05 AM
Joined Sep 2007
They are the same as used in laptops, so some years, hundreds cycles.
Old May 13, 2013, 08:46 AM
chanyote66's Avatar
Joined Dec 2011
nice! gonna order some friday!
Old May 13, 2013, 08:59 AM
HuttonIt is offline
Find More Posts by HuttonIt
CrashMaster
HuttonIt's Avatar
United Kingdom, Brentwood
Joined Dec 2012
How about taking cells out of something like the Lenovo Slice:- http://shop.lenovo.com/us/itemdetail...47BFB52CC4F8E9
That would give 64Wh 19v and the weight, even in the casing, only 370g.
A little expensive but may be well worth the trouble and expense if someone knows how to do it and configure the cells contained in the casing and hook up suitable motors and props.
HuttonIt is offline Find More Posts by HuttonIt
Old May 13, 2013, 09:08 AM
chanyote66's Avatar
Joined Dec 2011
370 is the width... the weight is 940g
Old May 13, 2013, 09:20 AM
Joined Sep 2007
lol, he already seen himself in the sky for hours
Actually 64Wh 340 grams is not terrible, this means close to 200W per kg, which is the energy density of MaxAmps.
Question Anyone fly with a Hacker A10-15s and a Glavak prop? r/cmark Indoor Pattern/F3P 6 Apr 10, 2013 10:45 PM
Discussion LiPo Battery Flighttime with MultiWii Jessestr Multirotor Talk 3 Jan 15, 2012 05:30 AM
Discussion Shorter flighttime with a 3s Lipo, than a 2s Lipo ? SpookiePower Batteries and Chargers 12 Oct 28, 2009 03:19 PM
Discussion E550 with 15S A123 genexis Electric Heli Talk 10 Dec 17, 2006 01:05 PM
FS: Hacker B50 15S with 1/8" shaft and MEC Superbox smsgill Aircraft - Electric - Airplanes (FS/W) 7 Sep 05, 2003 11:57 AM
