Old Jan 14, 2004, 06:33 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
I disassembled a Nokia vibramotor (5mm diameter, 0.8g).
The good: seems that the bearings (bushings) are located in the magnet, so easy to convert it to outrunner.
The bad: it has a 5 segments collector
My plan to use such a motor as a 3 phase stepper, so 5 segments obviously unusable (using 5 phases to control it is a waste of components, 2 more controller pins, 4 more fets...)
All of the similar motors have 5 segments, or are there 3 segments types too?
mmormota is offline Find More Posts by mmormota
Old Jan 14, 2004, 07:00 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Mmormota,
I'll check the ones I have taken apart, which is only a few out of all the many diffferent pagers I have. But I think you are correct.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jan 14, 2004, 07:56 AM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
mmormota,
There are 3 pole windings in most of the cheaper 6mm pagers. The radio shack variety is 5 pole but most of the bit clone motors I've taken apart are 3 pole.
You could definatly use these as a stepper motor but you may need to change the winding.
mcross is offline Find More Posts by mcross
Old Jan 14, 2004, 09:34 AM
Boston, Mass
Joined May 2001
Thanks Mike. You've obviously taken apart more of them than I have.
Gordon
Old Jul 03, 2006, 04:05 PM
jonathan8388 is offline
Find More Posts by jonathan8388
Elmwood Park,NJ, United States
Joined Nov 2004
Hey Guys, a few days ago, I made my first attempt of taking the casing off of a 4mm motor, and making another, lighter one for it. This step turned out okay. I made a nice mount out of 1/64" aircraft plywood, and shaved off .2 grams from the entire motor. The ONLY problem that I had was putting the communicator back in between the brushes without destroying them. The brushes are so close together, that i really cant squeeze the communicator in without spacing the brushes too far apart, or crushing them. this is a strange question, but what do you guys do to get the communicator back in between the brushes without destroying them?
jonathan8388 is offline Find More Posts by jonathan8388
Old Jul 03, 2006, 05:27 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
<Off topic:>
Hey, Tim!
Have you started posting again on MicroRCcenter again? I'd like to see an improved hovercraft!
</off topic.>
Sweet mod. If only I actually knew how to fly a plane to put it in.
Cheesehead is offline Find More Posts by Cheesehead
How to build a good looking pager motor plane! gbarc Scratchbuilt Indoor and Micro Models 9 Jul 04, 2004 06:09 PM
4mm pager motor actuator? LenBFP Scratchbuilt Indoor and Micro Models 16 Jun 26, 2004 06:14 AM
efficient 4mm pager motor ? bmaaa Scratchbuilt Indoor and Micro Models 23 May 03, 2004 11:52 AM
My First Home Made Prop For bitG Rudder Steering 4mm Pager Motor jas_Qfix Scratchbuilt Indoor and Micro Models 11 Jul 27, 2003 07:20 PM
RFFS100 & 4mm pager motor Andycart Scratchbuilt Indoor and Micro Models 6 May 13, 2003 04:49 AM
