Old Apr 26, 2013, 09:57 AM
shaneperch is offline
Find More Posts by shaneperch
Joined Jul 2004
SB-1 Battery
I have been so busy the past year. I didn't do much with my subs the past 9 months. I decided it was time to charge all three. I turned them on two run great you can hear the ballast pump run. My original first one nothing. I turn on the switch and the lights on the control board come on but dimly. I hooked up my charger and the light won't come on. I had it on all night and still no charge. so I open up the sub, hook up an external 12 battery to the supply wires and it works great. I hook the charger directly to the battery terminals and no charge. I would think I have a bad battery. Has this happened to anyone? Where can I get a replacement battery the same exact size? I wonder if Mike's Subworks would have one. If not who? Thanks
shaneperch is offline Find More Posts by shaneperch
Old Apr 26, 2013, 10:49 AM
GSPI is offline
Find More Posts by GSPI
United States, OH, Cleveland
Joined May 2012
Tower has them here:
http://www3.towerhobbies.com/cgi-bin...?&I=LXASZH&P=Z
Replacement parts list here:
http://www3.towerhobbies.com/cgi-bin...I=TTRB5220&P=Z
GSPI is offline Find More Posts by GSPI
Old May 03, 2013, 01:38 PM
Joined Jul 2004
I am bothered by this. Is it normal to have a battery fail,, when stored so long to where it will not accept a charge? I tried to charge it with several chargers even the stock charger overnight and nothing. The other two SB-1s take a charge and I got them both charged up. I hooked up a 12v alarm battery lead acid and the systems come on and the pump does it's thing. I then tried to charge the battery directly with alligator clips, right on the disconnected battery and won't accept the charge. So I ruled out the board, I hope. SI this possible or am I the only lucky one.
Old May 03, 2013, 01:46 PM
GSPI is offline
Joined May 2012
lead acid batteries in general can lose their ability to charge if not cycled regularly.
Old May 03, 2013, 05:16 PM
Joined Jul 2004
right. well I got to order one. at least the sub still works.
Cool My SB-1 Arrived Today ! BieneFlyer Submarines 17 May 08, 2013 07:38 PM
Yippee! SB-1 Flawless BieneFlyer Submarines 20 May 05, 2013 12:20 PM
Question Adjusting trim weights on SB-1 ? BieneFlyer Submarines 1 Apr 17, 2013 02:32 AM
Sold Hacker X-70-SB-pro ESC with Buffer Battery JimG_AZ Aircraft - Electric - Power Systems (FS/W) 4 Apr 05, 2013 01:07 PM
Sold Hacker X-70-SB-pro ESC with Buffer Battery JimG_AZ Aircraft - Electric - Power Systems (FS/W) 0 Jan 27, 2013 05:23 PM
