Old Apr 25, 2013, 01:38 AM
kamoflarj is offline
Find More Posts by kamoflarj
kamoflarj's Avatar
Joined Jul 2012
1:1 scale cessna
kamoflarj is offline Find More Posts by kamoflarj
Old Apr 25, 2013, 01:44 AM
Depronicus is offline
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Originally Posted by kamoflarj View Post
Im wanting to build a 1:1 scale cessna out of epp that i can pilot myself in the actual cockpit...
Okay, gang, what do we do with this one?
*Heaves enormous sigh and goes to bed*
Depronicus is offline Find More Posts by Depronicus
Old Apr 25, 2013, 03:00 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
How much money do you have to waste?
Teddy Ong is offline Find More Posts by Teddy Ong
Old Apr 25, 2013, 03:58 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
The only thing available for a full scale plane are the Yuneec gear. It's been almost 4 years now and they haven't won FAA approval yet so there's that problem of them not being allowed to sell their stuff in the US (or pretty much anywhere outside of China). You can try contacting them though.
But seriously, a Cessna is a bit too big for the Yuneec motor. May be doable but would then be severely underpowered. A better bet is a modified ultralight design like Yuneec's own eSpyder: http://yuneeccouk.site.securepod.com/Espyder.html
If and when they get approval they offer their gear in 4 setups:
- 10000W motor + 300A ESC + 31000mAH 18S 5C Lipo
- 20000W motor + 350A ESC + either the 31000mAH Lipo or a 70000mAH 18S Lipo
- 40000W motor + 400A ESC + 100000mAH 36S 5C Lipo
- 60000W motor + ESC (still in development) + the same 100000mAH battery as the 40kW setup
If money is not an issue the big problem at the moment is, as I've said, the fact that they haven't gotten FAA approval. Technically it may be legal to fly their stuff in an ultralight but they can't export it to the US. If you want their gear your best bet is to get in touch with them.
Several other companies including Boeing are developing electirc planes but Yuneec was the first company to advertise their intention to sell electric gear for civil aviation. They're certainly the first to demonstrate a mass produced electric power system for full scale planes. Almost all the other electric planes are one-off experimental designs.
slebetman is offline Find More Posts by slebetman
Old Apr 25, 2013, 04:02 AM
slebetman's Avatar
Joined Jun 2009
Found this picture from Wired magazine of a typical Yuneec gear installation. Motor, ESC, Battery. Just like our smaller RC gear:
Old Apr 25, 2013, 04:05 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I thought of these -
http://www.qualitypedalcars.com/pedal_planes
They don't do a Cessna, but the Red Baron looks good.
eflightray is offline Find More Posts by eflightray
Old Apr 25, 2013, 04:08 AM
Loco1 is offline
Find More Posts by Loco1
Callington South Australia
Joined Mar 2006
Is it still the 1st of April ?
Loco1 is offline Find More Posts by Loco1
Old Apr 25, 2013, 04:45 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
To troll or not to troll ?, that is the questions, other threads include -
....1/3 scale Boeing 737....1:1 scale Spitfire....1:1 scale Vampire.
Old Apr 25, 2013, 08:20 AM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
Just go buy a full scale Cessna.
62pilot is offline Find More Posts by 62pilot
Old Apr 25, 2013, 08:48 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A second hand one would probably be cheaper than trying to build one, in just about any material. But EPP ?, crazy.
Old Apr 25, 2013, 08:57 AM
Steve 0 is offline
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
You could get some of the large Pink Dow Foam from Lowes or Home Depot, cut out all the parts from plans found on here and then HOT GLUE them to your body OR just use your favorite color Sharpie markers and draw one on yourself. Either option would probably be less than $50 bucks.
Run around your neighborhood with arms/wings outstretched.
Go - " brrrrrrrr........Buzzzzzzzz..........nyyaaaaooooww!" and other airplane like sound effects.
When FAA, NTSB, and or other Security Officials arrive......You can make radio communication ......like "MAYDAY! MAYDAY! MAYDAY!" ...."Houston, we have a problem!"....."Im going down!"
Don't forget your Call Letters drawn onto both legs IB1-NUT
Steve 0 is offline Find More Posts by Steve 0
Old Apr 25, 2013, 09:32 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
You can buy a ready to fly Cessna 150 for about $15,000.
http://www.barnstormers.com/listing_...560d0d898e77cf
There are a lot of people that have been experimenting with electric planes though. The guy that invented the Lazair back in the early 80's has converted one of his planes to electric using Hobbyking parts! He did the whole thing on here too -
http://www.rcgroups.com/forums/showthread.php?t=1412424
So, yes, it is possible. Batteries are the biggest issue right now. Getting a large enough storage capacity, with a low enough weight is part of it. But there is also the airframe. You need to design a plane with light weight as the key.
Cessna is probably the worst design to go with if you want to make it electric. The best would probably be one of those ultralight gliders with a nice big Brushless motor on the nose.
SGTalon is offline Find More Posts by SGTalon
Old Apr 25, 2013, 09:35 AM
slebetman's Avatar
Joined Jun 2009
I thought someone did build a 1:1 scale Spitfire out of foam. Not RC but cool nonetheless. Can't seem to find the video on youtube.. forgot the title.
Old Apr 25, 2013, 09:44 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You may be thinking of the one that was based on an Airfix plastic model, but scaled up to 1:1 -
James May's Toy Stories1:1 Airfix Spitfire
Old Apr 25, 2013, 09:49 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There was also an 80% homebuilt Spitfire -
Bob Mears Spitfire
That was powered by a Mazda Wankel engine.
Discussion Cessna 1.6m and RCGF 15cc solentlife Fuel Plane Talk 3 Apr 14, 2013 11:16 PM
Sold 86" Pica 1/5th Scale Cessna 182 R/C Model Airplane Kit LCS Aircraft - Fuel - Airplanes (FS/W) 2 Mar 27, 2013 05:26 AM
Sold Vintage NIB Kyosho Cessna 188 Agwagon 1/8 scale Kit - $150 edh13 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 18, 2013 06:14 PM
Sold Jack Stafford 1/4 scale Cessna 120 kit for sale Don 2416n Aircraft - Fuel - Airplanes (FS/W) 0 Feb 23, 2013 08:42 PM
Cessna 152/172/182 Plans 1/12th scale planeluv Scale Kit/Scratch Built 6 Sep 28, 2010 12:10 AM
