Skylark Tiny III OSD
The Tiny III provides essential in-flight data during an fpv mission.
Small and lightweight with just enough in-flight data.
The Tiny III from Skylark is an on-screen-display that provides essential flight data during an fpv mission. There are many advantages to using an on screen display, with the most important ones being battery pack voltage/milliamps used, distance from home, and a way-home arrow. When the plane is powered on and the Tiny III initializes, it begins hunting for satellites. When it locks onto enough, it will store its current location as home. As you fly, an arrow will always point to the direction that the Tiny III initialized. This feature is a great safety measure due to the high likelihood that you will get lost at some point during your fpv career.
The Tiny III installs quickly and doesn't require any special programming. You can, however, set the measurement units between metric and imperial, as well as customize your osd view from the minimalist all the way up to the heads-up-display style ladders on each side showing airspeed and altitude. All adjustments are done in the Skylark osd software, that is downloadable from their website. After the flight, it will display a summary of the flight's gps data stream.
The Skylark Tiny III pdf instructions can be found HERE
Link to manufacturers website
Specs:
  • 10Hz super sense GPS, with backup battery ,3D Fix led indicator.
  • PAL/NTSC compatible
  • 60A current sensor.
  • ultra-light : 22.5 gram
  • RSSI Auto detected.
  • Auto "Setting Home"
  • With barometer
OSD measures:
  • Speed | Altitude | Distance
  • Home navigation angle
  • GPS signal
  • Power battery voltage
  • Power battery current
  • mAh consumed
Old May 03, 2013, 05:20 AM
Strangely_Calm is offline
Find More Posts by Strangely_Calm
Eyes on the Prize
Strangely_Calm's Avatar
Australia, WA, Swan View
Joined Oct 2012
Is this one at all similar to this one: http://www.hobbyking.com/mobile/view...dparentcat=544
Strangely_Calm is offline Find More Posts by Strangely_Calm
Old May 03, 2013, 12:42 PM
pecanpatch is offline
Find More Posts by pecanpatch
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Wouldn't that Be ground speed instead of airspeed?
You do awesome reviews Mr Matt!
pecanpatch is offline Find More Posts by pecanpatch
Latest blog entry: 6th Annual South Eastern FPV...
Old May 03, 2013, 01:05 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
you are correct, sir!
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old May 03, 2013, 01:07 PM
safarirv is offline
Find More Posts by safarirv
United States, WA, Kennewick
Joined Jan 2013
Skylark tiny osd
I like the specs on these...does anyone know of a source in the USA?
I am not into 1-month deliveries from China.
safarirv is offline Find More Posts by safarirv
Old May 04, 2013, 05:59 PM
Horse feathers is offline
Find More Posts by Horse feathers
United States, NY, Buffalo
Joined Jul 2010
http://www.readymaderc.com/store/ind...roducts_id=725
Horse feathers is offline Find More Posts by Horse feathers
Old May 04, 2013, 06:22 PM
safarirv is offline
Joined Jan 2013
Thanks!...out of stock though...
Old May 04, 2013, 06:24 PM
Joined Jul 2010
Opps I missed that part sorrt lol
Old May 04, 2013, 07:29 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
I have a couple of these--have worked very well for me. Love how quickly the GPS locks on. I use the simple screen without the home icon and aircraft location. I do have a question. In the sample screen shouldn't the aircraft location be above the home icon?
1fullbird is offline Find More Posts by 1fullbird
Old May 04, 2013, 07:44 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
No, and that's the only thing I don't like about this unit.
The icon always has the top as north. So if you are standing at your groundstation and facing another direction, the OSD will still show your plane location relative to north above the center icon. Sound confusing? it is.
So in that picture I was facing south and launched. That put the plane icon below the center/home icon and represented it being south.
Administrator
Old May 04, 2013, 08:47 PM
1fullbird's Avatar
Joined Nov 2011
Your are right, it is confusing. As I said, I use it without those features. I do like the units. I just put another one on my brand new long range bird.
Old May 12, 2013, 06:52 PM
knobby1 is offline
Find More Posts by knobby1
Australia, NSW, Bradbury
Joined Dec 2007
Dual Battery setup.
Hey Guys,
I have the Tiny OSD III and it works fine, however, I use a separate battery for my FPV gear, is there a way I can wire up the Tiny OSD with the dual batteries and can I monitor both battery voltages??
Cheers,
Smithy.
knobby1 is offline Find More Posts by knobby1
Old Jun 17, 2013, 01:20 AM
Nightram is offline
Find More Posts by Nightram
Nightram's Avatar
Australia, SA, Craigmore
Joined Jun 2013
This is the hobbyking rebranded version. Exactly the same.
I am having issues connecting my Skylark one to update it. Anyone have this issue on Windows 8?
Nightram is offline Find More Posts by Nightram
Old Nov 16, 2013, 04:25 AM
ChamnanFPV is offline
Find More Posts by ChamnanFPV
Joined Sep 2013
Good OSD , I have been using this one for 1 year, I'm happy with it. but now i'm building a new quadcopter and will be using 6s battery I wonder if this OSD can read 22.2 volt? what will happen if I use 6s battery?
ChamnanFPV is offline Find More Posts by ChamnanFPV
Old Nov 16, 2013, 10:45 AM
rclab1 is online now
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
You'll smoke it (brown out) :-)
rclab1 is online now Find More Posts by rclab1
Wanted Skylark Tiny OSD III $100 nige838 FPV Equipment (FS/W) 2 Jun 17, 2013 01:22 AM
Sold Skylark Tiny OSD III - $105 Shipped rawlmark FPV Equipment (FS/W) 3 Apr 18, 2013 02:15 PM
Wanted Skylark Tiny OSD III nige838 FPV Equipment (FS/W) 1 Mar 29, 2013 09:46 AM
Sold Skylark Tiny OSD III snipeworm FPV Equipment (FS/W) 5 Mar 20, 2013 03:09 AM
Sold Skylark Tiny III OSD Kenny S FPV Equipment (FS/W) 4 Jan 28, 2013 12:26 PM
