Old Apr 24, 2013, 10:37 AM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
Build Log
Flyzone Calypso by rip
My 5 y/o son wanted to fly. I cannot let him fly my Kadet. So I had to get "him" this Calypso.
Kadet out of commission,Spirit Glider still in the bench, Civil Air Patrol activity in our club requiring training aircraft.
ALES Glider 1
My Other Planes
ripacheco is offline Find More Posts by ripacheco
Old Apr 24, 2013, 11:06 AM
rip
ripacheco's Avatar
Joined Jan 2013
No Flaps
Because I forgot to order the $3.00 flap linkage kit and lack of a small-enough servos, I will assemble this glider without the optional flaps.
I'll program the radio with flap/ailerons . Hopefully that will be enough to slow it down for easy landings until I get the parts to put real ailerons.
Old Apr 25, 2013, 08:37 AM
rip
ripacheco's Avatar
Joined Jan 2013
Broke down and got a "generic" LIPO :
https://www.bphobbies.com/view.asp?i...9&pid=F3293878
It will be part of the 3-battery rotation set that I will use on the Calypso right next to the ThunderPower batteries.
In a few months we will know exactly how it holds up as I log every cycle on my LIPOs
Old Apr 26, 2013, 12:36 AM
rip
ripacheco's Avatar
Joined Jan 2013
Had to put the ESC/Battery/Receiver all the way to the front to balance the model on the "recomended' CG Spot.
Old Apr 27, 2013, 05:40 PM
rip
ripacheco's Avatar
Joined Jan 2013
Maiden flight and more
Maidened my calypso
Awesome.
Warning: NOT A BEGINNER plane.
The recommended throws are too much for a beginner.
Needed significant trim up with the motor off.
13 min flights using 50% of battery without even trying hard.
Hard to handle on 12+ MPH wind
Lots of fun for INTERMEDIATE pilot.
I'm glad I got this.
Spent weekend training beginners none could handle plane without a lot of help.
On the other hand the ones on the Bixler had less issues.
Old Apr 29, 2013, 09:49 AM
rip
ripacheco's Avatar
Joined Jan 2013
I think i'm going to forgo installing ailerons on this bird. The flaperons work very well.
One thing about flaperons is that you get less and less flap authority the more ailerons you deploy. I use the rudder to steer near the ground.
Old May 05, 2013, 04:45 PM
justinlee1 is offline
Find More Posts by justinlee1
justinlee1's Avatar
United States, GA, Atlanta
Joined Sep 2012
Love my Calypso. Tracks well under power with full throws as a fun warmliner but needs a bit of up elevator when gliding. Found my first thermal with it last week and am having a lot of fun with it.
justinlee1 is offline Find More Posts by justinlee1
Old May 05, 2013, 04:55 PM
rip
ripacheco's Avatar
Joined Jan 2013
Yes it does need a good deal of trim on the glide. There has been some suggestions to change the incidences of the horiz stab to correct this.
Old May 06, 2013, 12:42 AM
HEMICUDA is offline
Find More Posts by HEMICUDA
HEMICUDA's Avatar
Greensboro Pa USA
Joined Apr 2008
The guys from the big brown truck that delivers toys to good girls and boys is supposed to bring my calypso today. What exactly do you mean by shimming the tail and how? And i am not a builder so dummy it down for me.
Hemicuda
HEMICUDA is offline Find More Posts by HEMICUDA
Old May 06, 2013, 02:18 AM
rip
ripacheco's Avatar
Joined Jan 2013
Hemicuda
When you cut the power, some Calypsos will need a lot of trim up to keep a gentle glide angle. Otherwise it will have an excessive nose down attitude.
You can certainly correct this with trim it will not crash the airplane.
You can afterwards turn the elevator clevis so that the elevator is slightly up while your trim is back to neutral. That is the easy solution.
Some people would argue that having the elevator trimmed up like that is "bad".
So it's been suggested that when you install the elevator you put something (little ice of cardboard) on the BACK part of elevator fitting ( where it meets the fuselage). The idea is to have the BACK of the elevator to be 1/8 " higher than the back. This will accomplish the same as having the trim up.
WARNING: there is a version 2 of the calypso fuselage that is supposed to fix this issue.
My suggestion is to first fly the plane and make sure it needs this fix.
Also when you put the tail together, make sure that long screw is tight. Make sure that the tail fits correctly with the horizontal stab.
Here there are pictures of the V2. U need to accomplish the same:
http://www.rcgroups.com/forums/showp...&postcount=711
I rather just trim it up and then neutralize the trim by turning the clevis a few turns.
This is the full thread:
http://www.rcgroups.com/forums/showthread.php?t=1678070
Old May 07, 2013, 05:45 AM
justinlee1's Avatar
Joined Sep 2012
I don't disagree with your suggestion but would consider setting it up according to the manual first before trying any elevator compensation.
The reason I suggest this is that while the plane (mine at least) requires a fair amount of up elevator for gliding, it tracks straight as an arrow when under throttle. I think perhaps this might be part of the design. My plan is to create a throttle to elevator mix in my radio that gives neutral elevator under full throttle and some up elevator with no throttle.
I think either method would work, but I personally haven't seen the need to make the shim adjustment, though I'm sure that it would work well.
Old May 07, 2013, 06:29 AM
rip
ripacheco's Avatar
Joined Jan 2013
Correct. I believe there was a compromise there. If you are going to fly under power constantly. The default setting will work fine.
Now. That said. After trimming the aircraft for a gentle glide. When you apply full power the glider will pitch up a lot. However this sucker will climb at 50-70 degrees! Which is excellent for me! My flying style consists of full power climbs then glide.
Old May 09, 2013, 02:08 AM
rip
ripacheco's Avatar
Joined Jan 2013
Calypso Version 2
Tower Hobbies is now distributing the V2 version of the Calypso
this fixes the problems with the "dive when gliding"
http://www.rcgroups.com/forums/showp...&postcount=744
Old Jun 24, 2013, 02:39 PM
rip
ripacheco's Avatar
Joined Jan 2013
My Calypso is loosing its Scorpion ESC...
... the stock ESC will have to do the honors
Grrr....
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 107 Jul 24, 2016 03:18 AM
Article Flyzone 73" Calypso EP Glider Review 78dave Electric Sailplanes 2180 Jul 19, 2016 04:18 AM
For Sale NIB FlyZone Calypso RTF Version DesmoHead Aircraft - Sailplanes (FS/W) 0 Jan 28, 2013 09:09 PM
Sold NIB FlyZone Calypso RTF Version DesmoHead Aircraft - Electric - Airplanes (FS/W) 1 Jan 27, 2013 10:00 PM
