Old Jan 11, 2004, 03:20 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Power Pod for 3 Meter Plane
Has anyone seen an electric power pod for a 3 Meter sailplane? My friend has a Bird of Time and is interested in a power pod.
I have seen the Great Planes models, like this one:
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ769&P=7
but they say they are for 2 meter planes.
aeajr is offline Find More Posts by aeajr
Old Jan 11, 2004, 08:05 PM
shaneyee is offline
Find More Posts by shaneyee
shaneyee's Avatar
Singapore
Joined Aug 2002
Not a great solution.... a big plane like the BOT needs a big prop so your power pod will be too tall and the thrustline will be way too high. That pod will take an 8" prop at most. If you really wanted to use it, you would have to put in a Mega brushless turning an 8x6 prop or a Magnetic Mayhem at least. Even then you would have marginally climb due to the small prop.
Better the surgically alter the nose and put the motor there. Then you have many more options....for instance, Endoplasma with MPJet 3.8:1 gearbox on 7 cells turning a 13x8 prop.
Shane
shaneyee is offline Find More Posts by shaneyee
Old Jan 11, 2004, 09:58 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Thanks! I am still optomistic that someone has come up with a working solution.
I want to be able to put it on and take it off when I wish. If I embed a motor in it, I can't take that weight out when I want to hi-start it or winch it.
Hope springs eternal!
Rec power system for 3 meter Eraser invicta Electric Sailplanes 12 Mar 01, 2004 08:48 AM
Speed 600 Power Looking for a Home…What Plane? HavingFun2002 Sport Planes 12 Jan 27, 2003 09:22 AM
Power jack for your slope plane stegre Slope 9 Jan 03, 2003 03:21 AM
looking for a 3 meter glider kaboom Electric Sailplanes 11 Oct 05, 2002 10:57 PM
Power Supply For 3-cell Lithium-Ion Polymer Charger nolasco Parkflyers 3 Jul 22, 2002 04:30 PM
