Old Jan 11, 2004, 07:49 AM
BAR-STOOL is offline
Find More Posts by BAR-STOOL
BAR-STOOL's Avatar
Lakeville Minnesota USA
Joined Jul 2002
New Camera Mounting System
I was on the BAR-STOOL thinking of a better way to mount a camera that you could point it anywhere. I got to looking around the shop and found the plastic coolent hose. The hose comes in two sizes and I used the smaler size. I had this camera laying around so I made a mount for it to see if it would work. Looks like it will work great.
Roger
BAR-STOOL
BAR-STOOL is offline Find More Posts by BAR-STOOL
Old Jan 11, 2004, 07:50 AM
BAR-STOOL's Avatar
Joined Jul 2002
PIC 2
BAR-STOOL
Old Jan 11, 2004, 07:51 AM
BAR-STOOL's Avatar
Joined Jul 2002
PIC 3 Out the front just under the prop for pictures or streaming video.
BAR-STOOL
Old Jan 11, 2004, 07:52 AM
BAR-STOOL's Avatar
Joined Jul 2002
PIC 4 Out the rear.
BAR-STOOL
Old Jan 11, 2004, 08:44 AM
fdisk is offline
Find More Posts by fdisk
Vermont
Joined Mar 2002
Neat use of shop fodder. Is that really strong enough to hold position?
Pic 4 looks like SERIOUS drag.
fdisk is offline Find More Posts by fdisk
Old Jan 11, 2004, 10:40 AM
BAR-STOOL's Avatar
Joined Jul 2002
WELL I took it up to try this system to see if it will work.
Camera El cheep-o Sipix Blink $19.95 with a cheep CMOS sensor. It did work and it dId not move. I had the camera pointing stright our the front and tilted down 20 degrees.
BAR-STOOL
Old Jan 11, 2004, 10:41 AM
BAR-STOOL's Avatar
Joined Jul 2002
2 PIC
Old Jan 11, 2004, 10:44 AM
Karl Bē is offline
Find More Posts by Karl Bē
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
Are the adjustable segments simply a friction fit, or is there some sort of internal cinching mechanism?
Karl Bē is offline Find More Posts by Karl Bē
Old Jan 11, 2004, 10:48 AM
Ironsides is offline
Find More Posts by Ironsides
Ironsides's Avatar
Toronto, Canada
Joined Jan 2003
Roger:
I have to give you full marks for ingenuity. Well done.
David
Ironsides is offline Find More Posts by Ironsides
Old Jan 11, 2004, 10:50 AM
BAR-STOOL's Avatar
Joined Jul 2002
Thay are a friction fit and you can add or subtract as many as you want.
BAR-STOOL
Old Jan 11, 2004, 11:07 AM
BAR-STOOL's Avatar
Joined Jul 2002
The small is 5/8 od & the large is 1" od
BAR-STOOL
Sold For Sale: New Sea Commander Floats + mounting system gouda Aircraft - Fuel - Airplanes (FS/W) 8 Nov 28, 2005 07:00 AM
"who needs new askmanAP SS camera mounting kit" vote askman Aerial Photography 5 Nov 09, 2005 01:57 AM
The best camera mounting system with movie BAR-STOOL Aerial Photography 3 Apr 20, 2004 10:01 AM
Help with Radical NEW Aerodynamic propulsion System JonB Power Systems 4 Dec 09, 2001 12:27 PM
Need advice on new Aveox motor system D.W. Schmidt Sport Planes 25 Apr 24, 2001 12:57 AM
