This thread is privately moderated by Cardfan369, who may elect to delete unwanted replies.
Old Apr 21, 2013, 02:20 PM
Cardfan369 is online now
Find More Posts by Cardfan369
Trader Rating: 98
United States, AR, Hot Springs
Joined Nov 2008
Trader Rating: 98
Sold
SAITO Model 115 Four(4) Stroker
I purchased this engine towards the begining of last flying season to power a GOLDBERG Ultimate I planned to build. With the lighter weight of the 90 size case but more power than a SAITO "100" I thought it would be the ideal combination. Never built the Ultimate and now have the engine in a large Ugly Stik. Great engine, lots of power, "ogules" of compression and spins the 15x8 Zinger you see on it nicely. The engine came with a number of spare parts(NIB) when I got it and I purchased a set of bearings(just in case). Parts are as follows:
Muffler Nut (SAI 8080A) - 2 sets
Throttle Lever (SAI 5088B)
Crankcase Screw Set (SAI 5031)
Push-rod Cover/Seal (SAI 11540) - Contains Intake/Exhaust
Carb Gasket set (SAI 125a91)
Cylinder/Camshaft gaskets (one each)
SKF Stainless bearings(Frt/rear)
Valve Adjusting/Timing Tools
Engine, muffler, prop nut and parts only. $195.00 INCLUDING S&H in the CONUS
Questions just pm/ask.
Cardfan369 is online now Find More Posts by Cardfan369
Old Apr 21, 2013, 10:46 PM
roknhs is offline
Find More Posts by roknhs
Trader Rating: 13
United States, ID
Joined Apr 2007
Trader Rating: 13
Tell me if I have this correct, I believe you are telling us you bought the engine used? When you bought it, it came with the extra parts you have listed? Do I have that correct?
Can you tell me how much total time/gallons of fuel/use, the engine has had?
Ever use after run oil?
What is the nitro and oil content of the fuel you use?
In short, is it a low time or high time engine and has it had good care?
roknhs is offline Find More Posts by roknhs
Old Apr 22, 2013, 06:16 AM
Trader Rating: 98
Joined Nov 2008
Trader Rating: 98
You have it correct; bought used and the parts were supplied except for the bearings which I recently purchased. The engine was described as low time and I believe that. I have used it for less than a gallon this season only. It was stored with after run oil after receipt last year(Marvel Mystery Oil). I use COOL POWER 15% nitro four stroke fuel(green color) and would describe the engine as a typical SAITO. Just getting out of glow otherwise I would keep it and build the Ultimate.
Old Apr 23, 2013, 10:28 PM
Trader Rating: 98
Joined Nov 2008
Trader Rating: 98
SOLD pending payment.
Sold One Run Saito 62a Golden Knight Four Stroke Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 16, 2013 07:58 PM
Sold YS F 1.20 four-stroke motor for parts or repair $115 Shipped !!! hobbyfun100 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 15, 2013 07:10 PM
Sold Used Saito 100 4 Stroke Model Airplane Engine moxjett Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 07, 2013 02:05 PM
Sold New Saito 100. 4 stroker cryhavoc38 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 02, 2007 06:36 AM
For Sale YS 63 4 stroker and YS 91 ACH 4 stroker mongo Aircraft - Fuel - Engines and Accessories (FS/W) 8 Aug 13, 2006 07:26 PM
