Old Jan 09, 2004, 07:58 PM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
is it better to up size or downsize your prop when picking gearboxes
ok i'm having a hard time deciding on my gearbox, i have found two that are garanteed to be crash proof, which is what i need, one is 2.8 gearing which means that i have to go with an 8 inch prop and the other is a 4.1 gearing which i would have to run with the 12 inch prop. they both give me about the same power and amps. it is going on a gws pt-17 with a mega 16/7/7. don't know if bigger is better or not. i know that my idea gearbox is a 3.1 but i haven't found any that would survive a hard impact without cracking or bending ect... ect... so if someone does know of a 3.1 gearbox that can take a hard hit please let me know.
jeff262 is offline Find More Posts by jeff262
Old Jan 09, 2004, 08:12 PM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Guaranteed crash proof???
Which two?
Larry
Edit: As to your question on prop size - it depends on how you want to fly. The larger prop on higher gearing will have more thrust and lower speed (assuming the same aprox total power input). I don't know the plane you have so can't comment on it.
Larry3215 is offline Find More Posts by Larry3215
Old Jan 09, 2004, 09:08 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Crash proof 3:1
Does the Mega have mounting hole spacing the same as a Speed 400? If it does, what you need is the ACC347 all metal gearbox for Speed 400's (comes with 3 pinions so you can go 2:1, 2.5:1 or 3:1) - Kirk Massey at www.newcreations-rc has them listed for $19.90:Maxx Products has them as ACC347 for $21.95:Hobby-Lobby has them, as MPY345, for $21.90.
They are very versatile, very strong, and not too heavy [22g] and I've used them on Speed 400's and my MiniAC 1215/20.
Here's a photo of one on the Mini AC.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 10, 2004, 07:32 AM
jeff262 is offline
farmington, mn
Joined Sep 2003
that does look like tough gearbox but the pinions are 2.3mm and i have a 3.2mm shaft. how many teeth are in a 3.1 and 4.1 pinion?
Old Jan 10, 2004, 09:17 AM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Maxx Products has that same gearbox with a pinion for a 3.2 mm shaft part no. ACC387 $21.95, but it only comes with 2 pinions, 2:1 and 2.5:1.
Didn't check Kirk's site , but I'm sure he also has it, he's got to have one of the largest/diverse inventories in the business.
Kern
KLH is offline Find More Posts by KLH
Old Jan 10, 2004, 10:18 AM
jeff262 is offline
farmington, mn
Joined Sep 2003
thanks i will look for that but i think i may have to just order a different pinion thats why i need to know how many teeth the 3.1 has
Old Jan 10, 2004, 10:59 AM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
You could probably drill out the 3-1 pinion too. I have a GB that looks just like that I bought from Dymond Modelsports with a long can 480. I flew a 2 meter glider on 10 cells with it. I would say: 1: put it together with loctite, 2; I found a 2-1 ratio 3.2 pinion that was originally from a Master Airscrew speed 600 reduction drive that worked with the big gear (on my gb this was aluminum) 3; you need to set the gear lash on this type of GB. www.aircraft-world.com also sells an open frame speed 400 gearbox that fits a speed 400 so should fit the ac16-15 series, as well as the MPJET series oif palnetary or other wise, although the planetary aluminum ones are a little heavy.
Finally, why don't you just get a little outrunner??. MPJET also has a 2520 series with a gb that should work poifict on that plane and is only $60. look ay Hobby Lobby site for the ittle outrunners or this MPJEt motor.
BEA flyer is offline Find More Posts by BEA flyer
Old Jan 11, 2004, 01:18 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Re: is it better to up size or downsize your prop when picking gearboxes
A deep ratio box on that motor will probably give you very good thrust but little pitch speed.
Fine for a glider, useless for a sport plane.
Use the lower ratio - 2.8:1 - its near enough the 3 that you want.
Cool Setting up or selecting your first plane - what about range? aeajr Beginner Training Area (Aircraft-Electric) 18 Dec 09, 2014 12:01 PM
Question DD fiego Prop size or duals? spudandretti Micro Helis 1 Nov 01, 2004 09:03 PM
When to use a geared or a direct drive prop? nanoflite Scratchbuilt Indoor and Micro Models 7 Sep 27, 2004 10:47 PM
NESAIL - When or Where is your new web page ? (NT) MDM Vendor Talk 2 Nov 10, 2003 06:11 PM
