Old Apr 13, 2013, 10:21 PM
computerman021 is offline
Find More Posts by computerman021
Joined Feb 2008
Wing Construction
Hello Everyone,
I am need of some help on designing a 8ft wing. I have the bottom section of the wing cut out already out of 3/4" blue foam. Im stuck on how to construct the airfoil. Not sure if gluing multiple sheets together will work and use a hot wire cutter to cut out airfoil will be better or to create a rib & spar method wing. Its going on a cub, however I would like to have the wing as tough as possible but also as light as possible (I know you can get both but looking for a happy medium). Also if I do the rib & spar method what is best to cover the wing with?
ANY help will be greatly appreciated as I already have rest of plane cut out.
computerman021 is offline Find More Posts by computerman021
Old Apr 14, 2013, 02:36 AM
micka80ella is offline
Find More Posts by micka80ella
micka80ella's Avatar
Australia, QLD
Joined Apr 2012
Have you considered using strips of foam/spars along the span like the armin wing and glueing the top panels on to get a rough shape then cut/sand to finish it. You could have the strength and being somewhat hollow run your servo wires inside it. You should have the strength span wise but it wont be as strong chord wise as a laminated wing. If doing it that way i would only make the wing that way and laminate you ailerons/flaps to match the profile of the wing.
micka80ella is offline Find More Posts by micka80ella
Old Apr 14, 2013, 08:57 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
How about some more information, such as what type of wing, what sort of stresses is it likely to get, (gentle cruising - full aerobatics). ?
What wing section do you require, just a flat bottomed, curved top, or a genuine named airfoil. ?
What other foam do you have/want to use for the top ?
What sort of spar material are you using ?
Do you want to hot-wire cut an airfoil, or just build up a basic shape ?
The more information the easier it is to give some suggestions.
eflightray is offline Find More Posts by eflightray
Old Apr 14, 2013, 09:06 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Ah!, I just spotted this thread -
8ft Wing for a cub
You could have added another post.
You want to build a near 1/4 scale Cub and not sure how to build the wing.
Old Apr 14, 2013, 11:34 AM
Joined Feb 2008
Thanks for the reply. I'm thinking of something more gentle maybe at most a loop or roll. As far as a wing section only thing I have done is the bottom section of wing. I'm am open to any ideas on whatever you guys think is best. Your right this is my first "giant" scale build. I took the measurements from the HZ Super Cub and doubled them. I would like to keep the weight and price down as much as possible. I think it would be nice to have the wing be mostly self supported with out the use of struts however I will have them but don't wont wing dependent on them. As far as foam I have access to all types but really prefer blue foam or $1 foam. FFF won't be bad but its pretty expensive. However I do know it has the words aviation and hobby in it so its to be expected.
So to sum it up I'm open to anything that y'all suggest.
Old Apr 14, 2013, 07:47 PM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
Easiest Way
I'd say just scale up a KF wing plan.
Quick, Easy, Efficient and comments about this style wing are nothing but good
pcaffeldt is offline Find More Posts by pcaffeldt
Old Apr 14, 2013, 09:50 PM
Joined Feb 2008
But would the wing be strong enough to almost self supporting? When you deal with something so long there is alot more stress (is that correct)? I guess it depends on how you do the wing loading? But having such a long wing it has more leverage to bend and bow.
But if you think it would work then I am all for it!
Old Apr 15, 2013, 01:44 AM
Arizona Rim Country
Joined Nov 2001
Wing Strength
Whether you hot wire a wing or build it KF style the strength will be in the wing spar not the foam that creates the wing. Maybe look at the Giant Electric Forum here in RC Groups to see how they make wings in the size you are considering.
Old Apr 15, 2013, 02:39 AM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
However you make it the spars and joiners are going to be critical.Have a look at Joels method-
http://www.rcgroups.com/forums/showt...1853555&page=3
Ok I know it's a bird,same principles apply.Maybe a 3 section with a longer centre?.
I've read of guys using Walmart telescopic fishing poles,should keep your costs down.
Jon Snow is offline Find More Posts by Jon Snow
Build Log KA4 Construction begins . . philkiteflyer Scale Sailplanes 31 Sep 07, 2015 05:02 PM
Discussion Lockheed F-104 Starfighter in Tetris Bukvorez style construction 4stripes Electric Ducted Fan Jet Talk 30 Jul 14, 2013 11:14 PM
Discussion Difference in construction on 1555 propellers tormodnt Multirotor Talk 3 Apr 04, 2013 01:32 PM
Discussion Good ARTF fiberglass and wood construction to buy for around 70 - 80($115) tunde20 Slope 4 Jan 04, 2013 07:32 PM
Discussion West Wings Toucan - Wing construction sbaker1978 The Builders Workshop 2 Feb 12, 2009 04:06 PM
