Old Aug 09, 2013, 01:21 PM
Pablo Fernandez is offline
Find More Posts by Pablo Fernandez
Joined Jul 2013
Originally Posted by aadamson View Post
And just make sure you check back here with any questions, etc... we'll help you as quickly as we can.
Alan
Nobody is helping me
Pablo Fernandez is offline Find More Posts by Pablo Fernandez
Old Aug 09, 2013, 02:37 PM
csgimbal is offline
Find More Posts by csgimbal
Joined Jul 2013
[QUOTE=AES256;25769130]I have been having similar problems to what csgimbal has been reporting. csgimbal: have you had any luck since your last post?
To AES256: unfortunately not. I the end, I tried to power the board and use it, but the motors had a strange behaviour for couple of seconds and all stopped working. I think the board had an issue (I've ordered an other board).
Is there any way to check if the motors are connected in the right order ?
csgimbal is offline Find More Posts by csgimbal
Old Aug 09, 2013, 02:58 PM
AES256 is offline
Find More Posts by AES256
Joined Jul 2013
What problems are you having currently?
I think i'm giving up on the EvvGC and moving on to SimpleBGC. Need to get my 3 gimbals working and I can't put more time into trying to get this setup working.
I would recommend using a proven solution if you need your gimbals working asap, and then work on your evvgc implementation on the side when you have time.
Hello evvaldis. Great job.
When will this be implemented for the pitch?
I can see that you have "YAW auto PAN" button in the GUI but not for PITCH
Just in case so I don't missunderstand... Is the AutoPan mode and the Follow mode the same thing???
As I understand it, autopan and follow mode are the same thing. I don't know if anyone has implemented an auto pitch follow mode on any open source (or even closed source) handheld gimbal yet. Although it's possible, it might require more advanced code to be useful. Most of the auto follow modes I've seen so far are pretty slow and not all that sophisticated.
AES256 is offline Find More Posts by AES256
Old Aug 09, 2013, 03:07 PM
AES256 is offline
Joined Jul 2013
Originally Posted by fr3style View Post
Just got my 3AXIS movi clone and EVVGC 1.2 board in the mail today.
So from what i Have read online. Im in for some major time consuming issues haha.
Just to spare me some time. Am I correct on this?
1. Flash board with latest FW using a USART USB programer and the cables to the PINOUTS on the board not using USB. any tips on where to get latest fw?
2. Fix so mosfest dont burn out
3. Have battery connected while flashing the board.
4. Make sure im on the right usb drivers.
any tips are welcomed AND I WILL SHARE MY PIDS once i have it setup. Sharing pids is nice!
I recently added some instructions to the wiki on git:
https://github.com/EvvGC/Firmware/wiki/Flashing
I actually can't find a link to a compiled version of the latest firmware (and haven't needed to compile a copy myself yet). Can anyone help out with that? Here's the newest version uploaded to this thread by evvaldis, though: http://www.rcgroups.com/forums/showpost.php?p=25606624
Old Aug 09, 2013, 03:36 PM
AES256 is offline
Joined Jul 2013
Here's a question for the experts among us....
Suppose I want to use an external ESC, bypass the FETs, and just sample PWM off the board. Where can I tap in to the PWM signal on the PCB?
Old Aug 09, 2013, 03:37 PM
aadamson is offline
Find More Posts by aadamson
United States, GA, Atlanta
Joined Dec 2010
Look in the git in the original souce. The hex is there
aadamson is offline Find More Posts by aadamson
Old Aug 09, 2013, 04:24 PM
FlyAzza is offline
Find More Posts by FlyAzza
Joined Aug 2013
Hello. Quite new to all of this. Is there a some form of step by step guide to how to get this up and running?
I have bought the EVVGC 1.2 board.
Many thanks
FlyAzza is offline Find More Posts by FlyAzza
Old Aug 09, 2013, 05:17 PM
fr3style is offline
Find More Posts by fr3style
United States, OH, Kinsman
Joined May 2013
I know its a NO NO but just want to know if its possible.
Read on a forum that AlexMos nulled will run on the EVVGC board.
Thing is as much as I would love to run the EVVGC board. its so damn complicated. Some one could do a youtube video showing how to flash and program that would be so cool. I had ADHD and am suffering to concentrate to read all this. Damn Test month with no weed or medication is killing my concentration hahahahahahah...
What I have so far is in this picture.
My biggest questions is off course. How to flash the board using my USBASP if its even possible. And if i need to have it at 3.3V or 5V
Any can tell me also about this voltage regulator or whatever that is how it works?
fr3style is offline Find More Posts by fr3style
Old Aug 09, 2013, 06:42 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
I haven't been able to get much past flashing the firmware onto this board. I can read and write settings when powering over UART4 only. Then I pull the UART off and power over lipo and the motors hold a position but stay locked in that position as i tilt the copter. Motors are getting very warm even with only 30% power settings. Not sure if there is an issue with my board or the software isnt there yet. Just dont think it is the software's fault of this is working for others.
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Aug 09, 2013, 07:03 PM
Samdamang is offline
Find More Posts by Samdamang
Joined Apr 2007
Been trying to find a way to do this as well. I even have esc's flashed with firmware to drive brushless gimbal motors (which work well controlled by a transmitter), just no way to communicate with them to actually make use of them with a controller...
Samdamang is offline Find More Posts by Samdamang
Old Aug 09, 2013, 07:11 PM
Joined Apr 2007
There was somebody posting about that on this thread, but he was just bs'ing.
As previously posted...
Old Aug 09, 2013, 07:12 PM
aadamson is offline
Joined Dec 2010
First, the alexmox board uses a totally different processor and 8bit one, so that code won't run on a 32 bit processor at all.
Second, you can't flash the EvvGC board with a USBASP, all that is needed is a usb/serial adapter as published in the first post of this thread - and it *MUST* be a 3v3 compliant version, not a 5V one as the processor is only a 3v3 version and putting 5V into it will kill it.
There was a whole number of pages of flashing instructions, search on my user id (aadamson) and you'll find them. it's not that hard, but you have to make sure you follow the #1 critical rule... DO NOT, under and circumstances put LIPO voltage on the board and the same time you flash it, it WILL blow up the FET's and most likely the processor.
basically, it's really not that complicated, just find the thread, get the right tools and do it, and you may have remove./bridge those 2 resistors on the back of the board as referenced on the first post.
Alan
Old Aug 09, 2013, 07:15 PM
acc007 is offline
Find More Posts by acc007
Poland
Joined Jul 2011
Alan, it's not 100% true. EvvGC accepts 5v RX & TX as these pins are 5v tollerant. This is the way I use my 5v FTDI usb converter However, what is true, you MUSTN'T power on the board with 5v - this will kill MCU.
acc007 is offline Find More Posts by acc007
Old Aug 09, 2013, 07:22 PM
Joined Apr 2007
From my experience with both versions of the board, the software works well enough to do the job with the smaller rigs for say the GoPro or such. Even the auotpan/follow mode works perfectly fine (with a potentiometer). The smaller RCTimer motors work well even up to the one's they call 5010's.
Where it falls short for me is trying to get into the DSLR range with 4110's or 5208's. I just can't seem to get enough power to the motors to completely hold, though they get pretty close. Still waiting for a 5 cell battery to show up for a final test, but this board isn't really designed to have to burn off so much voltage through the regulator so this wouldn't be the ideal scenario even if it did work.
The 2.0 board will take care of those issues for the bigger rigs whenever that gets underway. Probably won't be for a while though
Old Aug 09, 2013, 07:38 PM
Hovership
3rdeyepro's Avatar
Joined Aug 2010
Guess I will keep watching and waiting. Until then I got a $50 board that does nothing.
Discussion Open Source Brushless Gimbal edge0xc Multirotor Electronics 3073 Dec 11, 2015 03:16 PM
Idea Open Source Gopro Brushless Gimbal icais Multirotor Talk 16 Mar 28, 2014 12:07 PM
Discussion SkyLight SBG - GoPro 2 Version Released (+ GP3 Beta + 3 axis Alpha) !! ed_jza80 Multirotor Talk 494 Jan 03, 2014 10:09 AM
Sold open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 57 Mar 26, 2013 07:02 PM
Sold [closed] open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 16 Feb 26, 2013 09:19 AM
