Old Jul 19, 2013, 01:50 AM
PaulPhill is offline
Find More Posts by PaulPhill
Joined Jun 2013
Having magnetic encoders gives us the advantage of being able to mount the IMU on the centre of mass of the platform. Movements can be counteracted for before they reach the camera platform.
This is of course just in theory and results would vary depending on different forms of dampening.
I would be interested in developing a Kalman filter of this platform and perhaps even fusing it with control inputs to give it some form of predictive control.
PaulPhill is offline Find More Posts by PaulPhill
Old Jul 19, 2013, 02:34 AM
evvaldis is offline
Find More Posts by evvaldis
evvaldis's Avatar
Lithuania
Joined Jan 2007
I still can't see any logical explanations why magnetic encoder + IMU is better than just one IMU on the camera.
If you put highend encoder to the axis and use external imu for horizon, you will get the same accuracy as with IMU on the camera. Because IMU gives you horizon!!
IMU on the camera is good because it gives ACTUAL position of the camera, not position of the copter or something like this. Also accelerometer gets less movements, therefore horizon becomes more accurate.
One more problem with magnetic sensor is that it can't see flexibility of the gimbal, it can't see actual angle between IMU and camera.
evvaldis is offline Find More Posts by evvaldis
Old Jul 19, 2013, 02:41 AM
andreas-aero is offline
Find More Posts by andreas-aero
bob the builder
france, near GENEVA
Joined May 2009
It permit to fix the magnetic field of the motor, in stead of getting "forward and then backward" loop as you get with the imu, even if its pretty fast.
continue Brainstorming, its becoming pretty interesting now
andreas-aero is offline Find More Posts by andreas-aero
Old Jul 19, 2013, 02:46 AM
evvaldis is offline
evvaldis's Avatar
Lithuania
Joined Jan 2007
I have tested different IMU placement and there was no difference at all (~+-20cm to all sides). One important rule is that IMU have to be placed tightly.
As I have said, IMU gets almost none movements, therefore it is easier to calculate horizon, also accelerometer gets less distortion while sitting on the camera.
P.S. I see that even movi uses IMU on the bottom of the camera, and it works without problems. I think this means something
Old Jul 19, 2013, 02:48 AM
acc007 is offline
Find More Posts by acc007
Poland
Joined Jul 2011
andreas-aero, this "pretty fast" is currently 500 Hz I believe. So, It's not "much forward and then backward", because every 2ms motors are corrected. So it's just a matter of movement during these 2ms - I believe this is a very very small movement your eye won't notice...
Perhaps we'll see it better in the future if we have some gfx charts on PC.
acc007 is offline Find More Posts by acc007
Old Jul 19, 2013, 02:49 AM
evvaldis is offline
evvaldis's Avatar
Lithuania
Joined Jan 2007
With magnetic sensor you will get loop between motor and sensor, so it is almost the same as imu-motor loop.
Old Jul 19, 2013, 03:43 AM
bob the builder
france, near GENEVA
Joined May 2009
Yup, "pretty fast" could be replaced by "fast enouth" :P
But i'm not sure you can read I2C bus at 500Hz ?
Anyway, a friend of mine who work in a drone making company is working on BLG concept, and he tried magnetic sansors WITHOUT ANY IMU and IMU alone under the camera.
He found it easier to tune with only magnetic sensors thant with a MPU 6090 ( not sure, the one with integreted compas)
Also, results are comparable from is point of view.
Any way, I think that mag sensor could be great for the autopan fonction, but probably not nescessary for the other axis.
Don't complicate it too much, cuz the frame will be harder to build if we have to integrate a magnetic sensor on each axis.
Also, many more cables, not pratical at all on little rigs ( don't care on dslr ones...)
Old Jul 19, 2013, 05:50 AM
natious is offline
Find More Posts by natious
Joined Apr 2013
Have you guys seen this? I believe he is using Alexmos boards or a variation of some sort.
http://www.kickstarter.com/projects/...liser?ref=live
natious is offline Find More Posts by natious
Old Jul 19, 2013, 06:01 AM
evvaldis is offline
evvaldis's Avatar
Lithuania
Joined Jan 2007
Now evvgc works on 500hz, I have tested 1000Hz and it works even better.
Maybe will post 1kHz code today or tomorrow.
Old Jul 19, 2013, 07:18 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by fr3style View Post
Hi Guys! Just bought this and one Contorller. any one know if this will work on a Canon T2i with light lens also on a Canon 7D with light lens
http://www.goodluckbuy.com/3-axis-ds...otography.html
Please keep us updated on this setup.
Sid3ways is offline Find More Posts by Sid3ways
Old Jul 19, 2013, 07:49 AM
Joined Jun 2013
Is there a way to setup the eclipse environment without the use of cygwin?
Old Jul 19, 2013, 08:26 AM
aadamson is offline
Find More Posts by aadamson
United States, GA, Atlanta
Joined Dec 2010
the only thing that cygwin is used for is *cs-make and cs-rm*.
If you can get another make on your system, you can use it, go to project->properties->c/c++ build and tell it to not use the built in make (cs-make). You may have to give a path to the other make if you do this.
Also, you can go copy your del.exe to cs-rm.exe that will fix the delete feature for clean, etc.
The other options are to use mingw or see if you can find a gcc tools for windows (which is pretty much what cygwin is).
Alan
aadamson is offline Find More Posts by aadamson
Old Jul 19, 2013, 09:24 AM
Bergeninc is offline
Find More Posts by Bergeninc
Joined May 2013
Ho ho.
Since people are working on eclipse version, I have modified few things in keil version.
Not much changed, I took 1.2 board from AirBot and tried ultrasonic operation. Changed PWM timers prescaler from 5 to 3 (now PWM is 18kHz), and it works pretty nice and SOUNDLESS.
Also changed "return from collision speed", and because of that PID configuring should be easier than before.
Inside ZIP you should find sources+HEX for reflashing.
Just Tested out your updated FW, it works great! Zero Noise!
My PiD settings need to be changed a little now, But overall it seems like the yaw and roll have a little more strength.
Bergeninc is offline Find More Posts by Bergeninc
Old Jul 19, 2013, 10:01 AM
hcmpromotion is offline
Find More Posts by hcmpromotion
Joined Jul 2013
A very interesting development is constantly ahead ... :-)
EvvGC - Testing infinite "Pitch", regardless of the "Roll" ... (2 min 23 sec)
hcmpromotion is offline Find More Posts by hcmpromotion
Old Jul 19, 2013, 10:20 AM
evvaldis is offline
evvaldis's Avatar
Lithuania
Joined Jan 2007
Thanks a lot for the feedback
This weekend I hope to test more 1000Hz loop speed, also to test AutoPan+AutoTilt feature, also will improve GUI.
Will post sources+hex here
Discussion Open Source Brushless Gimbal edge0xc Multirotor Electronics 3073 Dec 11, 2015 03:16 PM
Idea Open Source Gopro Brushless Gimbal icais Multirotor Talk 16 Mar 28, 2014 12:07 PM
Discussion SkyLight SBG - GoPro 2 Version Released (+ GP3 Beta + 3 axis Alpha) !! ed_jza80 Multirotor Talk 494 Jan 03, 2014 10:09 AM
Sold open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 57 Mar 26, 2013 07:02 PM
Sold [closed] open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 16 Feb 26, 2013 09:19 AM
