Old Nov 27, 2001, 10:19 PM
Daveairway is online now
Find More Posts by Daveairway
Santa Rosa, Northern CA, USA
Joined Oct 1999
Tiger Moth Wing Joining ?
Well, I have read at least 100 post on the TM, but I just started my kit..
I used a small amout of epoxy to set the dihederal in the lower wing.
(I blocked up one tip, at the tip, 80 mm, let the glue dry, pulled the block, and then presto the wing went way flatter. Oops, need to block by the joint next time, and measure at the tip. I hope I am not the first..)
Here is my question. Are you all using that plastic cover "item" on the bottom wing with the double sided tape? Seems pretty low tech, but maybe that is the way to go?
Should I forget the tape and use some glue with the plastic?
Should I forget the plastic and do something else?
Dave
PS: Wonder why I just don't follow the directions?
Any hints on the top wing would be welcome..... guess the yellow tape is for it.
Daveairway is online now Find More Posts by Daveairway
Old Nov 28, 2001, 12:50 AM
Dave Bowles is offline
Find More Posts by Dave Bowles
Leavenworth Ks
Joined Nov 2001
wing joints
I used the plastic joiner with the supplied tape, worked fine and helps keep the wing solid for the rubber bands . On the top wing I had weights on the center peace and blocked the wing tips , I used epoxy vs the tape supplied to hold it then used the supplied yellow tape to cover the glue.
Dave Bowles is offline Find More Posts by Dave Bowles
Old Nov 28, 2001, 07:57 AM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
I just started mine lastnight, and they didnt include the DAMN TAPE FOR THE TOP WING!!!! I had to use some lexan tape to hold the wing together on top, but it is much stronger than anything they could have given me.
Slope Nut is offline Find More Posts by Slope Nut
Old Nov 28, 2001, 08:03 AM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Don't use the double stick tape. The plastic piece works great, just epoxy it to the wing. That's all you need to hold the dihedral.
I messed up my top wing by using the ds tape and re-did it using baking soda and Odorless CA. The yellow tape was so mangled I covered the whole thing with packing tape and painted it.
A better solution that was posted later is to use epoxy and instead of the tape glue thin plastic strips on.
BC
Basketcase is offline Find More Posts by Basketcase
Old Nov 28, 2001, 08:22 PM
Joined Oct 1999
Thanks guys for the help.
Nut, my top wing tape was painted yellow and in with the wing struts. Did you look there?
Sounds like I will epoxy the plastic lower wing joiner on and epoxy the top wing with some light plastic strips.
Boy this little plane is too cute !!
Thanks Again,
Dave
Old Nov 28, 2001, 08:56 PM
marauder is offline
Find More Posts by marauder
Central Texas
Joined Nov 2001
Daveairway,
I use Pro-bond for the top and bottom wing joints as well as to apply the dihedral plate. It holds as good as epoxy but as it dries it makes a foam that fills the joint gap and is easy to sand.
That makes it a lot easier to get the tape flat when you apply it to the top wing joints.
Hope this helps
Lynn
marauder is offline Find More Posts by marauder
Old Nov 28, 2001, 10:17 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
All stock works fine. Even after several crashes...
Danal Estes is offline Find More Posts by Danal Estes
Old Nov 28, 2001, 11:15 PM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Nada on the wing tape. I searched through everything four times (including taking the box apart thinking it may have gotten loose and lodged in a folded corner!). Its pretty durn stiff, and my plane is nearly done after about three hours.
Greg
Old Nov 30, 2001, 11:13 PM
Joined Oct 1999
Quick update
Well,
After trial fitting the plastic joiner to the lower wing and trying to figure out how to hold it smooth with no gaps while the glue dried.... I gave up.
I wound up using the double sided tape, stuck the plastic joiner to the wing, and was done. Boy that was easy !! Seems to have worked just fine too
Here is a neat trick to join the fuse. Put a real thin layer of tightbond glue to each side. (Wipe exess off with fingers) Let this just get tacky, then join the sides. I then used about 15 dental rubber bands to hold the sides together. Worked great with no paint lost, as often happens with the tape method.
Dave
PS: Greg, so you did the major hunt aye? Been there too. Alot like dropping that last (only one I own) servo horn screw and hearing a little "ting" as it hides somewhere on the floor....
Wonder why my kit had two sets of the tape?
Old Nov 30, 2001, 11:32 PM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
I have heard that "pling", and then spend an hour looking for the damn screw. I finally just decided to keep an old 400 can motor laying around to use as a magnet to pick up pesky little creatures like that
My moth is done, just have to fit the rx, speed control and battery, trim and fly it
Now, back to the B-25
Greg
Old Dec 01, 2001, 08:00 AM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Just a quick question. I've seen numerous posts mentioning Pro-Bond. What is it and where do you get it? My LHS never heard of it. Sounds like the ticket. Thanks, BC
Old Dec 01, 2001, 09:01 AM
T6Junkie is offline
Find More Posts by T6Junkie
T6Junkie's Avatar
Homer Glen, Illinois, United States
Joined Sep 2001
Pro-Bond
Basketcase,
Pro-Bond is available at your local hardware store. I get mine at Ace Hardware. I believe it is made by either Bordens or Elmers. It is a polyurathane glue. I use it all the time to sheet my foam wings. Make you use it very sparingly.
Pete
T6Junkie is offline Find More Posts by T6Junkie
Old Dec 01, 2001, 10:02 AM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Basketcase
Probond is great stuff, however, I would suggest that you experiment a little with it before you use it anywhere that will show. It sets up very slow and expands a lot. Epoxy is quicker and has a better finshed look but probond seems to be a little more flexable. On foam Probond seems to work it's way down into the little cracks and crevices and make a stronger joint.
Kern
KLH is offline Find More Posts by KLH
Old Dec 01, 2001, 10:11 AM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Thanks for the info guys.
BC
Help! Does anyone know how to get twist out of Tiger Moth wing? I'm stumped. Chuck Parkflyers 19 Jan 19, 2002 12:15 AM
Broken Tiger Moth Wing AussieParkflyer Parkflyers 15 Jan 10, 2002 01:37 PM
Tiger Moth Wing Stuts chiozza Parkflyers 4 Nov 25, 2001 02:46 PM
Tiger Moth Wing Hold Down Mods Ben Lanterman Parkflyers 11 Oct 01, 2001 09:49 PM
tiger moth wing struts Beige Parkflyers 10 Sep 27, 2001 12:15 PM
