Old Apr 10, 2013, 07:32 PM
rcairboater is offline
Find More Posts by rcairboater
east central ohio
Joined Jan 2009
Os 46 la
I was reading information on the OS 46 LA and this is what it say's about the fuel recommendations...
REQUIRES Fuel with 5% - 15% Nitromethane and 18% (minimum) oil content
(Most of the 5%-15% fuels we carry meet these requirements)
Can I run Methanol and Castor Oil without Nitro Methane in these engines?
-Gary
rcairboater is offline Find More Posts by rcairboater
Old Apr 11, 2013, 01:10 AM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
Of course. A little nitro helps with the idle but they run OK on FAI fuel.
datsunguy is offline Find More Posts by datsunguy
Old Apr 11, 2013, 09:27 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Gary,
This engine, according to OS, requires a hotter glow-plug than its displacement suggests.
If you do (OS #6/A3, or the better fitting OS LC3), everything will be OK with FAI fuel.
But do make sure there's plenty of castor oil in it for this bushing bearing engine (all synth is bad!).
DarZeelon is offline Find More Posts by DarZeelon
Old Apr 11, 2013, 09:32 AM
east central ohio
Joined Jan 2009
What about idle? I don't want the engine to be a pain from stalling constantly.
Thought's?
Old Apr 11, 2013, 09:35 AM
east central ohio
Joined Jan 2009
Originally Posted by DarZeelon View Post
Gary,
The lc3 plug?
From tower hobbies web page...
This is the O.S. Max LC3 Hot Long Reach Glow Plug.
Designed for use in .12-.15 and .18 size engines used in monster trucks
such as the original and newer 2.5 Traxxas T-Maxx.
Old Apr 11, 2013, 10:31 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
The engine will run just fine on the all alcohol fuel. The nitro would allow it to idle at a lower RPM. The engine uses a base bleed carb where there is a tiny hole in the front of the carb. This allows air into the carb to idle with the barrel fully closed. Its opening regulates the amount of air. It is generally present to about half way across the hole with the set screw off to the side of the carb. I would not fool with it, the preset works just fine.
Since it is plain bearing engine, that is it does not have ball bearings, it uses a sleeve bearing (also known as a bushing). The oil in the fuel creates a film coating inside the bearing between it and the crankshaft. So the crankshaft literally rides on that coating.
Nothing wrong with a plain bearing engines. All our early engines used sleeve bearings. And even our modern automobile engines use bushings on the connection rods. So the technology while simple is just fine. The only big difference is that when the bushing wears out and that could take years you can not replace it. Ball bearings can be replace pretty easily.
Chip01 is offline Find More Posts by Chip01
Old Apr 11, 2013, 10:38 AM
jeffie8696 is online now
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
Dar and I agree on something, incredible.
jeffie8696 is online now Find More Posts by jeffie8696
Old Apr 11, 2013, 10:41 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
If it doesn't keep lit at idle, you may have to take out the head shim, or put a thinner one in. If the plug blows or is mangled you will know you went too far. My .46 has .030" head clearance which is a lot. It has a .015" shim which if taken out might be about right, for no nitro fuel. It should be ok with just a hot plug IMHO. You don't need nitro really, it just is easier that is all. This is the first time two people got in before I typed my answer.
aspeed is offline Find More Posts by aspeed
Old Apr 11, 2013, 10:45 AM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
Merlin will probably be able to suggest a plug for it. I would guess a 2009 or 2010.
Old Apr 11, 2013, 11:38 AM
DarZeelon's Avatar
Joined Nov 2003
Gary,
The LC3/4 glow-plugs don't care and don't know what engine they are installed in.
Their heat range is the same and as far as fit goes; they are actually long-reach and fit better than the #6/#8 glow-plugs that are medium-reach; and remain recessed in the combustion chamber of all larger OS aircraft engines.
I consider them superior replacements and they also cost less (at least compared to the #8).
I suggest the LC3 for engines that need a hot plug and the LC4 for engines that need a medium-heat one.
Jeff,
With the exception of bearing brands, we agree on almost everything...
Sold OS .46 LA Almost New $50 Shipped gllucero Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 04, 2013 08:09 AM
Sold OS LA.46 Silver, NIB rycomm Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 16, 2013 08:05 PM
Sold Blue os 46 la SammyKY Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 23, 2013 09:13 AM
Sold OS-Max LA 40 and LA 46 with mufflers. 5 Engines in all 85.00 shipped VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 22, 2013 04:39 PM
Discussion OS .46 LA or OS .46 AX? gsmayfield Engines 136 Apr 18, 2009 08:07 PM
