Espritmodel.com Heli Air
Old Jan 08, 2004, 08:22 PM
farmington, mn
Joined Sep 2003
anyonw know if i could move my top wing on the gws pt-17 to make the CG more aft?
ok my gws pt-17 bi plane is just two tail heavy, i need 11 ounces of weight in the nose to make the CG right. my lipos are only 4 ounces so i need to add 6 opunces which is alot of weight for nothing. any one know what would happen if i moved the top wing back and left to bottom wing where it was. would it still fly correct? would that throw the CG farther aft or not
thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Jan 08, 2004, 09:03 PM
Backyard Bomber
Bsmooth's Avatar
Joined May 2002
this does not sound like you have it completely assembled. if you haven't done so allready, build it up completely and then see what happens.
Bsmooth is offline Find More Posts by Bsmooth
Old Jan 08, 2004, 09:08 PM
farmington, mn
Joined Sep 2003
yes actuaaly i have finished it and i need to put 10 ounces in the nose to make the CG right. the top wing is connected with struts that's why i was wondering if i could move it back more
Old Jan 08, 2004, 09:51 PM
wanabefoamey's Avatar
Joined Dec 2003
cg change
is the top wing foward of the bottom wing
if so you can move the top wing back till the top and bottom wings are even.
wanabefoamey is offline Find More Posts by wanabefoamey
Old Jan 08, 2004, 09:54 PM
Joined Dec 2003
picks
do you have any picks of your plane
may be move the motor foward
or can you make lightening holes in the rear.
For Sale large decal for top of wing on .40 raven pval3 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 08, 2006 09:14 AM
Discussion How do I know if I am running my Kokam to hard Dave K Power Systems 14 Apr 09, 2006 01:08 PM
Discussion drf4 I want to use my radioI would want to know if it is possible to use my radio gra frankogh Micro Helis 1 Feb 26, 2006 08:36 PM
Anyone Know How I Can Make My Eclipse Run On 49MHz?? nickpapagiorgio Radios 5 Feb 15, 2005 11:43 PM
will my lipos die on gws 350? crashingagain Batteries and Chargers 1 Dec 27, 2003 10:54 PM
