Old Apr 10, 2013, 02:39 AM
sawitup is offline
Find More Posts by sawitup
Joined Feb 2013
Servo extentions
Hi, I'm building a plane and mounting the aileron servos out in the wing. I need to put in some extension wires, but want to put my mind at ease about something...
Do the extension wires cause any problem for the servo operation? I'll be using the standard servo wire plus two extensions per servo.
Any issues here?
sawitup is offline Find More Posts by sawitup
Old Apr 10, 2013, 03:12 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The main potential issues are too-thin wire and too many connectors causing too much electrical resistance.
My preference is to solder an extension lead on, using "heavy duty" servo wire, so that I still have only one connector per servo. In fact, with one-piece wings I solder my opposite servo leads together to make a Y, so that I only have one connector for the two servos.
If you must use pre-made extension leads, try to get ones that are long enough, rather than connecting two together to make up the length. And for the connectors that will be buried in the wing, tie a piece of dental floss around them so they can't come apart.
abenn is online now Find More Posts by abenn
Old Apr 10, 2013, 04:20 AM
sawitup is offline
Joined Feb 2013
The voltage issues you mentioned are along the lines of what I am concerned with... How difficult is it to solder the ends on custom made leads? I solder like I weld... Not beautiful but it works haha
Old Apr 10, 2013, 07:19 AM
abenn is online now
Joined Jul 2004
I can't weld, so you're ahead of me
Anyway, soldering servo leads is simple so long as you have the right equipment -- a decent iron, some resin-cored solder, and a "helping hand" device (or some home-made jig) to hold the wires in position while soldering.
I strip about 1/4" of each wire end, twist them so they're neat and tidy with no little bits sticking out, and then tin them with solder. Then I lay the two tinned ends side by side, facing each other, and a quick dab (maybe two seconds) with the iron with a little bit of solder on the bit, and the job's done. Look carefully and you'll see the two wires sort of melt into each other when it's done correctly.
Don't forget to slide a bit of heat-shrink onto one side before you solder the joint, then slide it over the joint when it's cooled down, and shrink.
You can solder the cut-off end of the wire, with the plug attached, onto the other end of your extension lead, or you can crimp on a new servo plug (one solder joint less) and discard the old one.
Old Apr 10, 2013, 01:25 PM
kenh3497 is offline
Find More Posts by kenh3497
Comfortably Numb
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
If you use connectors in the wings I like a dab of dielectric grease in the connector to help prevent corrosion or at least slow it down.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Apr 10, 2013, 03:23 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
If you don't want to cut connector ends off and solder, etc. You can use the extensions as is, but what I do is use some string, or twine and tie the connectors so that they don't unplug later. There are gaps between the3 wires making it easy to thread the string through so you can tie them together so they don't accidentally come unplugged on you later.
earlwb is offline Find More Posts by earlwb
Old Apr 10, 2013, 03:53 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Where connections are necessary (batteries, detachable wings, etc) I use plastic retaining clips. With extensions, I solder. I wrote a tutorial on the subject - it's on my website if anyone's interested:
http://www.grosbeakrc.ca/tutorials/splice.html
grosbeak is offline Find More Posts by grosbeak
Old Apr 11, 2013, 06:20 PM
sawitup is offline
Joined Feb 2013
Thank you for all the replies! I feel much better about it now. I didn't think about snipping the plug ends off and soldering the wires together inside the wing.
sawitup is offline
Joined Feb 2013
And thanks for the link Grosbeck
Old Apr 11, 2013, 06:22 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
I have heard that if you have really long extensions (2 feet or better) tie a simple overhand knot in the wire as a substistute for chokes. Of course, if you DON'T tie a knot, you may not need a 24" extension......
howell
gwinhh is offline Find More Posts by gwinhh
Old Apr 11, 2013, 11:08 PM
sawitup is offline
Joined Feb 2013
Hi, what do you mean by chokes in the wire?
Old Apr 12, 2013, 10:44 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
The only time that chokes (or twisted lines) would help is if the source of any adverse signals were generated in the servos and that would minimise any feedback from the servo into the receiver. There is no need for such devices in most (if not all) servo installations. All extrainious signals (if such signals exist) picked up by the leads to the servo will be "common mode" and will not effect the servo performance.
Rodney is offline Find More Posts by Rodney
Old Apr 13, 2013, 04:18 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
For reliability
I suggest that only one connector be used at the receiver and any servo extensions be soldered.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Apr 14, 2013, 02:46 AM
abenn is online now
Joined Jul 2004
A choke is that little ferrite ring that you sometimes see the wires wrapped around on an ESC or stand-alone BEC. It allows dc current to flow as if it were just the wire, but it provides an impedence (I think that's the term) that limits how much ac current can flow through. That reduces the chance of interference getting through to the receiver, though I've never found it necessary on servo leads, nor indeed on any leads, when using 2.4GHz. I used them on ESC and BEC leads when I was on 35MHz.
Old Apr 14, 2013, 11:18 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
I sometimes use shrink material, slip over the connections and use a heat gun to shrink the material. About the same as using plastic retainers and whole lot easier than tying knots. I also use as a minimum 6v (five cell) receiver batteries. No brown out and helps with the potential voltage drop across the connectors. I also solder in extended wires, I cut the servo lead in half and add what I need. I also use shrink spaghetti on those solder jobs.
Chip01 is offline Find More Posts by Chip01
Discussion looking for servo extentions for hk micro servos Roy!! Scratchbuilt Indoor and Micro Models 9 Aug 29, 2012 12:56 PM
Sold Futaba/Hitec servo extentions,servo and battery wire kg4min Aircraft - General - Radio Equipment (FS/W) 2 Feb 19, 2012 09:12 AM
Wanted Servo Wire Extention Kit Ampy Aircraft - General - Radio Equipment (FS/W) 14 Aug 18, 2008 01:04 PM
For Sale Servos and extentions and connectors 'OH, MY'! glowfuel Aircraft - General - Radio Equipment (FS/W) 0 Aug 03, 2008 11:17 AM
FS. (8) Futaba 36" long servo extentions bfraser Aircraft - Electric - Airplanes (FS/W) 1 Jun 19, 2003 07:47 PM
