Old Apr 09, 2013, 03:13 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
DX8 Sailplane Q&A
Ask here for help on DX8 Sailplane-specific questions.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Apr 09, 2013, 03:24 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Thanks for opening this thread, Andy!
I see there is no motor ramping function default. Any thoughts about this? (In reference to throttle on the trainer switch and with 2 or 3 point throttle spool up).
I also noticed that when assigning throttle to the trainer switch, the monitor gives zero change in throttle input when the button is pressed. Why is that?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Apr 09, 2013, 03:29 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
After assigning the motor activation you need to click on it again and assign the active positions.
aerocal is offline Find More Posts by aerocal
Old Apr 09, 2013, 03:30 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Please provide the SPM file. Also some details on why trainer should move the switch? If the master and slave are set up correctly, that's exactly what should happen.
Andy
Site Sponsor
Old Apr 09, 2013, 03:32 PM
Arcteryxxx's Avatar
Joined Feb 2010
Do you mean the 0 and 1 values in the boxes in the setup menu? If so, checked!
Old Apr 09, 2013, 03:35 PM
Arcteryxxx's Avatar
Joined Feb 2010
Andy
I did not mean for the trainer switch to move anything but the throttle output signal. Push the button: 100%, release the button: 0%.
Old Apr 09, 2013, 03:37 PM
aerocal is offline
Central California
Joined Dec 2006
Yes.If you assign both/all positions it will be active all the time.Only assign the position(s) you want it to be active in.
Old Apr 09, 2013, 03:38 PM
aerocal is offline
Central California
Joined Dec 2006
Make the 1 position Black and leave the 0 position White.Default is all Off.
Old Apr 09, 2013, 03:40 PM
Arcteryxxx's Avatar
Joined Feb 2010
Ok thanks.
Old Apr 09, 2013, 03:47 PM
krafty is offline
Find More Posts by krafty
krafty's Avatar
France, Aquitaine, Duras
Joined Jan 2006
Dumb question
The Airware V3.0 update file seems to have the same name as the previous one for the V2.06 update. So presumably the V2.06 file must be removed from the card before copying the new file to the card?
krafty is offline Find More Posts by krafty
Old Apr 09, 2013, 03:58 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
I replied in your other thread already!
Site Sponsor
Old Apr 09, 2013, 04:00 PM
aerocal is offline
Central California
Joined Dec 2006
When you D/L the file to the card from your account it will be saved as spmtx.sax
It will only autoload with that filename.After the update is complete the file on the card should get ammended.Your 2.06 update should still be on the card but it should be named SPMTX.SAX206.After this update you will also have SPMTX.SAX300 as well.
Old Apr 09, 2013, 04:20 PM
RLundtz is offline
Find More Posts by RLundtz
Joined Mar 2013
tagscribed...
RLundtz is offline Find More Posts by RLundtz
Reply With Quote  (Disabled)
Old Apr 09, 2013, 04:21 PM
Barry2020 is offline
Find More Posts by Barry2020
United States, CA, Camarillo
Joined Jul 2012
Just loaded the new DX8 AirWare 3.0 firmware. I see the Sailplane features as much more flexible than before, using Acro.
Have some questions for my 2-Ail, 2-Flp wing configuration motor/glider.
Four Flight Modes offered include: Launch, Cruise, Speed, Thermal. Is ‘Camber’ used in the same context as ‘Thermal’?... ‘Reflex’ same as ‘Speed’?
No ‘Land’ Flight Mode like on DX18; so which Flight Mode should I use for landing with Crow braking? Or should I ignore these and just consider using the Flap switch for landings?
I figured out how to enable the motor (MOT) with Throttle Stick (Spoiler) from the Wing Type configuration menu ('Motor' setting set to 'Spoiler' with option to disable with any of the FM switch positions). That also allows enabling the Throttle Cut Menu. Nice!
What’s the best way to add Crow braking using the Camber System? Do I program Crow for Speed, Thermal, Cruise, or all three Flight Modes? Before, the update, I was using Crow Braking on Throttle Stick with Throttle Cut. So I only want to enable Crow braking with Throttle cut.
Since the Camber System menu only works with Flight Mode switch, it looks like I would need to do 'Crow with Throttle Stick (Spoiler) while Throttle Cut' outside Camber System menu, using Flap Switch and two free mixes. One mix: MOT>MOT with -100 rate1 and -100 offset, this to disable the motor. And another mix: MOT>LAL, to enable Crow using the same Flap switch position(s).
Barry
Barry2020 is offline Find More Posts by Barry2020
Old Apr 09, 2013, 04:22 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If you use the Thread Tools you can Subscribe without actually having to post.
freechip is offline Find More Posts by freechip
Discussion DX8 Sailplane update is here. Suggestions, how-to, optimization, post it here! RCBlackSheep Radios 3 Apr 09, 2013 06:30 AM
Discussion diamond 2500 - dx8 sailplane mixing blackswans Electric Sailplanes 4 May 22, 2012 10:12 AM
Discussion F27-Q Stryker and DX8, best settings? Madivad Flying Wings 1 Jan 13, 2012 12:07 AM
Found Fly Q Sailplane Lou Aircraft - Electric - Airplanes (FS/W) 0 Sep 08, 2009 01:25 AM
Question Basic q. re unpowered sailplane electronics. Zerts Sailplane Talk 4 Feb 13, 2009 10:47 AM
