This thread is privately moderated by symdnn, who may elect to delete unwanted replies.
Old Apr 07, 2013, 02:31 PM
symdnn is offline
Find More Posts by symdnn
Trader Rating: 0
Dive now work later
symdnn's Avatar
Houston, Texas
Joined Dec 2010
Trader Rating: 0
Sold
HET F16 90mm Composite Thunderbird RC Jet
Selling HET F16 composite RC Jet ready to fly. You just need to drop in you receiver and battery. I built this plane and flown it once. It flies great with plenty of power. This kit is made of composite epoxy glass with high quality glossy finish. You will need two 5s 5000mah lipos connected in series to make 10s 5000mah, its also recommended to use high discharge rate batteries like 65C or more. All high end components, here is the component list below:
HET F16 90mm composite thunder bird $350
HET Typhoon 700-60 1485kv 90mm Brushless Motor $115
HobbyWing Flyfun ESC 100A High Voltage $110
5 X HET Micro Digital Servo $75
Hobbywing ESC 5A High Voltage (HV) Switch BEC Input 8-42V $20
RC Lander F16 scale retracts $200
Everything with shipping was close to $1000. If you are interested, you can make me an offer
Call or text 832.675.0048
symdnn is offline Find More Posts by symdnn
Old Apr 07, 2013, 11:45 PM
rutanman is offline
Find More Posts by rutanman
Trader Rating: 6
USA, PA, Alexandria
Joined Sep 2004
Trader Rating: 6
With the possibility that the Thunderbirds have flown their very last performance. This might be a collectors item. Years ago, I had worked on the F-16 and always thought that the Thunderbird paint scheme was one of the best paint schemes on a fighter jet. Hope that you don't mind the note.
Good luck on your sale.
rutanman is offline Find More Posts by rutanman
Old Apr 08, 2013, 10:28 AM
x3dflyer is offline
Find More Posts by x3dflyer
Trader Rating: 33
x3dflyer's Avatar
United States, MA, Hingham
Joined Jan 2010
Trader Rating: 33
sent a pm
Anthony
x3dflyer is offline Find More Posts by x3dflyer
Old Jul 19, 2013, 12:32 AM
konviser is offline
Find More Posts by konviser
Trader Rating: 1
konviser's Avatar
Joined Jul 2013
Trader Rating: 1
pm sent
pm sent
konviser is offline Find More Posts by konviser
Discussion Looking for a composite lightweight 90mm jet? firehawkzach Electric Ducted Fan Jet Talk 25 Dec 27, 2015 03:32 AM
Discussion HET Composite F-18 keithtsr Electric Ducted Fan Jet Talk 341 Apr 10, 2015 12:45 PM
Build Log Jet Teng Models Full Composite 90MM Bae Hawk V2 From RC-Warbirds Build & Video's FlyBoyTha1 Electric Ducted Fan Jet Talk 701 Mar 23, 2015 06:32 PM
Discussion het f16 90mm cg recommended natiho2 Electric Ducted Fan Jet Talk 2 Jan 16, 2013 04:50 PM
Sold Tam Jet F16 1/12 Thunderbird scheme jet warbirds Aircraft - Electric - Jets (FS/W) 0 Jan 11, 2011 05:49 PM
