Old Jan 07, 2004, 10:33 PM
gr8johnson3 is offline
Find More Posts by gr8johnson3
clinton township, michigan
Joined Sep 2003
yet another battery charger question.
if i buy a 7.2v 1200mah pack(2 cell). would i need a charger that goes up to 1200. can i use one that charges lower than 1200. can i use one that goes above 1200?
gr8johnson3 is offline Find More Posts by gr8johnson3
Old Jan 08, 2004, 02:21 AM
wacko is offline
Find More Posts by wacko
Joined Dec 2003
when charging a 1200mAh lipo pack, make sure your max charging current is 1200mA. thus you can use a lipo charger that charges lower than 1200mA, and you can also use a lipo charger than can charger higher then 1200mA, provided the charging current can be set to 1200mA or lower.
wacko is offline Find More Posts by wacko
Old Jan 08, 2004, 02:57 AM
Awakened is offline
Find More Posts by Awakened
Nimble with Gimbals
San Diego, CA
Joined Apr 2003
Never charge at greater than 1C. You can certainly use a lower charge rate, it will simply take longer.
Awakened is offline Find More Posts by Awakened
Old Jan 08, 2004, 06:25 AM
Joined Sep 2003
so, 1c is one amp. correct? and 1200mha is actually 1.2 amps? i think that is what the guide said in the beginning of this forum. ok i dont want to charge higher than 1c or 1000mah.
Old Jan 08, 2004, 07:19 AM
Wheazel is offline
Find More Posts by Wheazel
Tech freak
Sundsvall Midlanda, Sweden
Joined Aug 2002
No, 1c= 1 times the capacity
1c for Etec 1200 is 1,2 amp
1c for kokam 340 is 0.34 amp
1c for Thunderpower 2100 is 2.1 amp
Wheaz
Wheazel is offline Find More Posts by Wheazel
Old Jan 08, 2004, 07:33 AM
Joined Sep 2003
oh ok. so it varies depending on the battery mah you are charging. it is the rate of charge with the vaiable being the mah of the battery you are charging.
Old Jan 08, 2004, 08:49 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Be sure to read the Ultimate Guide to Lithium Polymer Batteries sticky at the top of the messages in this forum, as that will have the answers to most of your questions about Li-poly charging.
Dave Hederich is offline Find More Posts by Dave Hederich
Yet another battery cable length question nik_leeson Castle Creations 4 Sep 28, 2007 02:50 PM
yet another battery question jeddy11 Batteries and Chargers 3 Jul 08, 2003 06:46 PM
Yet another battery question theKAT Parkflyers 5 Jan 31, 2002 09:10 PM
battery charger question on Sky Scooter Pro LuckyArmpit Beginner Training Area (Aircraft-Electric) 14 Jul 08, 2001 09:36 PM
